Track Bar "walk" - JeepForum.com
post #1 of 8 Old 06-21-2009, 12:09 PM Thread Starter
bigjeep39
bigjeep39's Avatar
Track Bar "walk"
I have the IRO 6.5" lift with their trac bar. I just recently noticed a weird knocking and vibration that i can feel in the floor board and i also hear a loud annoying squeak during my turns.
I got under the jeep and had someone turn the wheel, the frame mount side of the track bar is the issue. The trac bar walks back and forth (so to speak) i tried to tighten the ever living crap out of the bolt but it still moves fore and aft.
Any ideas??
1998 TJ
Slow steady project.
bigjeep39 is offline
post #2 of 8 Old 06-21-2009, 12:13 PM
Virmagicus
Virmagicus's Avatar
Sounds like you mean the actual bolt that goes through the TB and not the mount ?
Jeff
Virmagicus is offline
post #3 of 8 Old 06-21-2009, 12:13 PM
WhiteOut
WhiteOut's Avatar
Is the nut bottomed out on the threads? My BDS TB is doing that and I think I'll have to get it taken in and the threads lengthened since I still have a little bit of play in it.
WhiteOut is offline
post #4 of 8 Old 06-21-2009, 12:22 PM
MACHJGC
a common issue on lifted WJ's is the axle track bar mount oval's out. This may have happened to the frame side mount as well. A fix for that is to weld a hardened washer or metal plate to the outsides of the mount.
I personally had the same problem, so i welded a hardened washer to the mounts and enlarged both mounting holes to 9/16" and used grade 8 bolts and hardware. If you upgrade size of hardware, you will probably have to ream the metal bushing out. What I did was take my stock track bar, and removed the metal bushings. The OEM ones have thicker wall and allow to ream to a 9/16" without losing rigidity. I then installed these into my JKS adjustable track bar, which required reaming of the rubber isolator ( I had KOR's hardened ones) So far, everything works great.
IRO 3" & Bilsteins
OE Skids & Recovery
255/70/16 Grabber AT2
Bumper & Roof Lights
MACHJGC is offline
post #5 of 8 Old 06-21-2009, 12:36 PM
Greengc4x4
KOR ftw. I never had issues with mine
Greengc4x4 is offline
post #6 of 8 Old 06-21-2009, 02:01 PM Thread Starter
bigjeep39
bigjeep39's Avatar
Very helpful and informative. Looks like I will be spending some time fixing this issue. Thank you again
1998 TJ
post #7 of 8 Old 06-22-2009, 12:55 PM
MACHJGC
I apologize but I made a mistake.... I actually used the metal bushings I had left over from my IRO fixed length track bar. If I recall correctly, I had noticed that the OEM metal bushings were a little smaller in outside diameter to be used.
IRO 3" & Bilsteins
OE Skids & Recovery
MACHJGC is offline
post #8 of 8 Old 06-22-2009, 01:10 PM Thread Starter
bigjeep39
bigjeep39's Avatar
Well i figured, i got mine all taken a part. the bushing is the same diameter is the bolt. So where there is slack i do not know. This is aggravating. I even tried to lube the ever living crap out of it and still ::Squeek::
1998 TJ
"xenon" or "true white" headlight bulbs .. exist? sanboy ZJ Grand Cherokee Forum 16 10-12-2010 09:23 PM
Rear end "squirrely" after track bar bracket install psychoworks ZJ Grand Cherokee Forum 1 11-24-2008 08:12 PM
IRO 4.5" lift track bar soccerfreak3377 ZJ Grand Cherokee Forum 1 04-23-2008 01:01 PM
2" BB without Adj. Track Bar speedfreak04 ZJ Grand Cherokee Forum 6 02-18-2007 04:30 PM
5.5" lift... axle walk... b1pig ZJ Grand Cherokee Forum 3 03-04-2005 08:11 PM
