track bar centered, but wheel not straight. - JeepForum.com
Go Back JeepForum.com > Models > Jeep Grand Cherokee & Commander Forums > ZJ Grand Cherokee Forum > track bar centered, but wheel not straight.
All viair onboard air systems ship free to lower 48! Www.Spartan Locker Promo Running now @ ROCKRIDGE 4WD plus FREEJEEP Gear Change Packages From ROCKRIDGE 4WD. We Are DIFF
Unread 06-24-2008, 07:54 PM   #1
vwmaniacx
So, I centered the axle on my wj. I was just wonder if the steering wheel should be straight or not? Or if i'll need to get a alinement for that to happen.
I'm loving the 4'' LA kit so far.
you can go a long way with a smile . You can go a lot farther with a smile and a gun . -Al Capone
If you own a VDUB this is where you should be!
Western Mass 4x4
vwmaniacx is offline   Reply With Quote
Unread 06-24-2008, 08:06 PM   #2
skain8
yes, you're steering wheel should be straight.
adjust your draglink to center your steering wheel. If you didn't get an alignment after the lift, you should, and the shop should center your wheel for you.
'02 WJ: 4.7L, 5", 44/9, 231HD w/SYE, 35's, Clayton's
'99 XJ: stock
'98 XJ: stolen
231HD build guide
skain8 is offline   Reply With Quote
Unread 06-24-2008, 08:31 PM   #3
ajmorell
You just need to make an adjustment on the adjusting sleeve - it connects the drag link to the TRE at the pitman arm.
ajmorell is offline   Reply With Quote
Unread 06-25-2008, 08:14 AM   #4
WJ04
WJ04's Avatar
even if you got an alignment when you lifted it, i would still get another alignment because you were messing with the trackbar. and X2 on what skain8 said.
2004 WJ Laredo-selectrac 242-I6- Custom XJ intake w/Amsoil cone filter- PSC HD Pump & Res- PSC ported box- B&M trans cooler- B&M PS cooler- Custom chevy 1 Ton over the knuckle steering- Rough Stuff 1 Ton tierod & draglink ends- Saguaro 4x4 Front 3/4" shackles, Rear hitch & Warn 3/4" shackle-Mopar Front skid,Gastank skid -IRO TC skid- RRO super sliders- 6.5'' IRO critical path lift -IRO extended rear arms-Bilstein 5125 shocks -IRO F&R 6.5'' Bump stops-Carolina drive shaft-16x7 black soft 8's - 34'' Super swampers-Yukon 4.11 gears -Ultimate RCV shafts - LockRight Locked ECGS bolt in rear D60 -35 spline Chomloy shafts -BTF HD diff cover -IRO Adj A-arm-OX Locked super D30 -OX HD diff cover -OX drive away lock-Rock Krawler d30 truss-Stillen rotors & Matrix pads-JKS Adj Track Bar-JKS Quicker discos -Relocated OME SD-40 Steering Stabilizer-BDS stabilizer brackets-Relocated washer bottle-Removed rear sway bar-Cobra CB-TomTom one XL navi-alpine deck
Still to come: Flowmaster 50suv
October 2011 GCOTM Winner
Some of my videos: http://www.youtube.com/user/LockedWJ?feature=mhee
Originally Posted by billyjp2 View Post
I burnout on puppies and kittens
Originally Posted by vwmaniacx View Post
Lets not and say we didn't.
WJ04 is offline   Reply With Quote
Unread 06-25-2008, 09:18 AM   #5
Wheelin98TJ
JEEP FREAK
Wheelin98TJ's Avatar
Adjusting the trackbar has no effect on the alignment.
It will move the steering wheel, but it will not change the toe in, caster, or camber settings.
There is no reason to get an alignment after a trackbar adjustment.
Wheelin98TJ is offline   Reply With Quote
Unread 06-25-2008, 10:10 AM   #6
WJ04
WJ04's Avatar
well when i installed my JKS trackbar, for some reason my allignment was off and i had just done it 2 weeks prior. thats the only reason i said i would...just incase. also i had a problem with my camber that also went away after install of the trackbar.
Unread 06-25-2008, 10:15 AM   #7
allenjp
Alignments never hurt...
This is my JEEP. There are many like it but this one is mine...
1996 ZJ 318 Laredo Quadra Trac -SOLD (I'm gonna miss her!)
2002 WJ 4.7 Limited Quadra Drive (sharing it with wifey for now...)
allenjp is offline   Reply With Quote
Unread 06-25-2008, 10:51 AM   #8
5.9 ANDY
zj tractor
5.9 ANDY's Avatar
except your check book.
hard working private first class in the United States Marine Corps.
Originally Posted by shift_grind View Post
It's threads like this that make me wonder why people lift there jeeps
its comments like this that make me wonder why some people are jerks.
build thread:http://www.jeepforum.com/forum/f197/...ndard-1056365/
5.9 ANDY is offline   Reply With Quote
Unread 06-25-2008, 04:46 PM   #9
vwmaniacx
I've got a buddy who only charges me 30 bucks..
Western Mass 4x4
Unread 06-25-2008, 04:50 PM   #10
vwmaniacx
I was going to get alignment today, but then I had to help my dad with brakelines on his car.
Western Mass 4x4
Unread 06-25-2008, 06:17 PM   #11
97 ZJ Steve
http://go.jeep-xj.info/HowtoAlignment.htm
97 ZJ Steve is offline   Reply With Quote
Unread 06-25-2008, 06:25 PM   #12
sandman
upper adjustment sleve on the drag link will straighten your steeringwheel.
1993 Jeep ZJ. 4.0
sandman is offline   Reply With Quote
