Track bar brackets & adjustments - JeepForum.com
post #1 of 2 Old 07-06-2013, 12:48 PM Thread Starter
ZJMatt
My new jeep has a 4.5" Rough Country spring lift and the P/O installed a rear drop bracket. After doing some REAL wheeling for the first time yesterday and hearing some nasty sounds I got looking and see that the track bar is rubbing on the upper control arm mount. I also noticed the other day that the rear axle is noticeably shifted toward the driver's side. The driver's side tire sticks out past my mud flaps, and the passenger's is barely covered. That's making me think that the stock track bar + The bracket is making it too long.
Other issues that are stemming from the axle being off center are the rear passenger's shock is rubbing on my exhaust, and my rear passenger's tire rubs on the coil spring while flexing. Driver's side does not.
At 4.5" it seems as though the stock track bar (with no bracket) would be too short. My rubbing issues would be solved but it would still be noticeably off center, just the opposite way.
Also has me wondering about the front.
So with a fully adjustable track bar, how do you dial it in? Do most people just eyeball it, or is there a certain place you take measurements? When I installed my adjustable in my other jeep I found the center point of my bumper, and measured from the same point on either side in a triangular fashion and used math to determine how the axle was situated. But I can't imagine the average person doing that and it was kind of tedious..
The "Mall Crawler" - 1998 ZJ Grand Cherokee 5.2 V8, 5.5" LongArms, 32s, 12000lb winch & more.
ZJMatt is offline
post #2 of 2 Old 07-06-2013, 12:57 PM
WhiteOut
WhiteOut's Avatar
On a flat surface, disconnect both ends, bounce and shake the rear of the Jeep around and it will find its center. Install the trackbar.
WhiteOut is offline
