Track bar bolt - JeepForum.com
post #1 of 31 Old 10-22-2013, 04:50 PM Thread Starter
jbsj33p
Track bar bolt
Does anyone have a source for the front track bar bolt that goes to the axle side. The PO replaced mine with a grade 5 M8 bolt for some strange reason and I cant seem to dig up a replacement. I have tried all the local hardware and bolt places but no luck, apparently its an odd bolt. Just got back from the junkyard and all the ones there were rusted to the jeeps.. so I'm all out of luck. Any help would be greatly appreciated, I want my jeep back!
Never trust a Jeep that doesn't leak oil.
jbsj33p is offline
post #2 of 31 Old 10-23-2013, 08:58 PM
JohnnyZJ
if you can get the flag bolt off stock jeep you can order the bolt from Chrysler. I've done it and it cost 18$
I just pulled a bunch at pnp. much easier.
07' JKUR rollin on 35s
JohnnyZJ is offline
post #3 of 31 Old 10-23-2013, 09:08 PM
AVR2
For the 1993 ZJ, the PN for the bolt is 6502 554. If you want the flag nut as well, it's 6506 264AA.
AVR2 is online now
post #4 of 31 Old 10-23-2013, 09:10 PM
misfit77
While we are here..... My rear track bar was clunking so I bought a urethane bushing kit but the metal sleeve is looser than the OEM. So I just tightened the crap out of the OEM bolt.
This happened to anyone else?
misfit77 is offline
post #5 of 31 Old 10-23-2013, 10:59 PM Thread Starter
jbsj33p
Thanks for those part numbers! I think I will have to bite the bullet and order the bolt. $28 for a nut and bolt makes me cringe, but my local pnp is fresh out of zjs and the other junk yards like to conveniently put all the cars in the dirt without wheels on, making pulling a bolt from the bottom of the axle somewhat difficult
jbsj33p is offline
post #6 of 31 Old 10-24-2013, 12:05 AM
Uniblurb
Uniblurb's Avatar
Don't you have a shovel to dig a tunnel under them? Lol.
Yeah, I made the $18 mistake in not taking the tension off of the track bar before removing the bolt and stripped the threads right off of it while removing. Then I couldn't get the track bar hole aligned to install the new bolt. Nice to have some knowledgeable people around here to offer some real good tips!
http://www.jeepforum.com/forum/f13/t...-bolt-1367135/
96 4.0 ZJ Laredo, 2004 4.7L WJ Limited, 93 4.0 XJ (spare), 96 4.0 XJ (son's)
Uniblurb is online now
post #7 of 31 Old 10-24-2013, 04:55 AM
AVR2
How do you take the tension off the bolt? Just jack the axle up a bit? Or pop the balljoint at the upper end of the bar first?
AVR2 is online now
post #8 of 31 Old 10-24-2013, 07:09 AM
Uniblurb
Uniblurb's Avatar
The trick for taking the tension off the track bar bolt or aligning the bolt hole was mentioned in the link/thread I posted. You turn the steering wheel with the front wheels/tires on the ground and let the unibody twist/do the work while it takes the tension off of it.
This is where a helper would come in real handy to move the steering wheel while you remove/install the bolt. Since I didn't have one for aligning the bolt holes on bolt install I just turned the steering wheel a little w/o it running then put bungees on the steering wheel to the shifter to hold it in place when I had it exactly lined up. I did have the body/axle jacked up some to create some room but really don't think you need it jacked up at all to do this.
post #9 of 31 Old 10-24-2013, 02:51 PM Thread Starter
jbsj33p
Will this bolt and nut also be found in an xj? Pnp has xjs but no zjs.
My track bar bolt just came right out, but that might have something to do with the fact it was an M8 and not an M10. I'm still amazed how it wasn't broken.
jbsj33p is offline
post #10 of 31 Old 10-24-2013, 03:02 PM
JohnnyZJ
XJ/TJ/ZJ/MJ yes all the same bolt.
JohnnyZJ is offline
post #11 of 31 Old 10-24-2013, 03:46 PM
Dukcaln
took mine off today cause it was popping when turning. reinstalled the bushing and bolt. All fixed. but on a side note my buddy had an extra bolt. PM me you address and I will ship to you if you want.
1996 zj-v8-79k miles-corbeau seats-exhaust-hood vents-3 1/2 lift-safari rack-arb bumper-amps-subs
Dukcaln is offline
post #12 of 31 Old 10-24-2013, 04:07 PM
JeepForever
I almost bought the bolt from the dealer because I wanted a new bolt and flag nut since I had to saw mine off to get it out. I found out that Chrysler didn't have the flag nut (even though the description said it was a flag nut). I went to the hardware store (Ace Hardware and MENARDS near me each have a good selection). I got a metric bolt and matching nut an it worked great. The bolt was a M10 (10mm) x 70mm (grade 10.9, I think; this is metric's version of Grade 8 or better). In hindsight I should have tried to recover the flag nut but thought about that after I sawed the nut off to weld a new flag nut. The original flag nut has a coarse thread and I bought the finer thread, but it worked OK for me since I bought a matching nut.
Last edited by JeepForever; 10-25-2013 at 11:32 AM. Reason: Changed bolt size from "I'm not sure" to "M10 x 70mm"
JeepForever is offline
post #13 of 31 Old 10-24-2013, 06:30 PM
Dukcaln
I talked to my buddy about the extra bolt, he said he got it at ace. Perfect match. I didn't think about asking him the size. He just took it in and they matched it. Our local ace is crazy stocked piled with stuff. Its a great store
Dukcaln is offline
post #14 of 31 Old 10-25-2013, 01:33 AM
Uniblurb
Uniblurb's Avatar
In completing various searches it looks like the TB bolt size is a M10 x 1.75 x 70mm, grade 8 or higher, if you want to avoid the dealer.
post #15 of 31 Old 10-25-2013, 07:21 AM
zjosh93
Are you sure that M10x1.75 Uniblurb? That's not one of the standard M10 threads. http://mdmetric.com/tech/M-thead%20600.htm
Not saying that Jeep didn't do something crazy but M10x1.5 is as coarse as they usually go.
The equivalent of grade 8 in metric is usually grade 10.9 but metric bolts have many more grades than the usual standard grades http://www.engineeringtoolbox.com/st...es-d_1428.html
Grade 10.9 is easy enough to find that I usually go with that. Grade 12.9 is harder to come by. FWIW the pinion flange bolts on a Ford 8.8 are grade 12.9 12-point heads, stock.
zjosh93 is offline
