Trac-Loc - JeepForum.com
post #1 of 5 Old 02-26-2003, 07:51 PM Thread Starter
KillerZJ
KillerZJ's Avatar
Trac-Loc
what is everyones opinions on the trac loc for the jeeps? i have heard they are lmited slips and i have heard they are full lockers. i think the clutches are worn down on mine because we drove it on concrete in 4 wheel drive and it probobly did something to it. it doesnt work like it did when we bought it. what are your opinions?
Looking for E36 325i(s) 5 speed only. Jeep is for sale $3,000 takes it. E-mail only.
*Sale Pending*
Wow no pictures in sig? F*cking gay.
KillerZJ is offline
post #2 of 5 Old 02-26-2003, 09:35 PM
ChrisinVA
Oh jeez...who told you Trac-Lok is a full locker?
Anyways, its a limited slip. It requires a special fluid and/or additive for it to work properly. They do wear out over time, and is totally rebuildable by a $60 kit (replaces clutch disks, similar to whats in an auto tranny).
To check for operation, jack up both back wheels, put the tranny in neutral and rotate one tire. If it's working, the other will rotate the same direction.
Driving in 4wd on dry pavement is never a good idea, but not for the reason you think (bad for transfer case). Remember, the truck sends power to the rear wheels all the time, regardless of position. 4wd, 2wd...doesn't matter. Trac-Lok works all the time.
You probably just need a rebuild.
ChrisinVA is offline
post #3 of 5 Old 02-27-2003, 07:37 AM Thread Starter
KillerZJ
KillerZJ's Avatar
but in 2 wheel drive it is not engaged...correct? So you could only tell in 4 wheel drive if it is working by doing what you said...again...am i correct? thanks
*Sale Pending*
KillerZJ is offline
post #4 of 5 Old 02-28-2003, 09:19 AM
automan25
No, the Trac-Loc differentials work completely independent of the four-wheel drive system.
1993 ZJ Limited 5.2 - no mods - Red with Gold (what were they thinking) trim.
automan25 is offline
post #5 of 5 Old 02-28-2003, 11:33 PM
ChrisinVA
Ditto.
Liberty Selec-Trac vs Commander Quadra-Trac II jthomaslambert WK Grand Cherokee & XK Commander Forum 13 10-30-2009 05:17 AM
quadra trac to selec trac convertion in wj JeepWJBob ZJ Grand Cherokee Forum 4 01-26-2009 10:14 PM
Can i replace my qudra trac with selec trac? Bekim ZJ Grand Cherokee Forum 12 10-02-2007 07:09 AM
Select-trac or quadra-trac or drive. preferences? wrigleylaredo ZJ Grand Cherokee Forum 25 10-21-2004 01:42 PM
Buying Used GC: V8 + Quadra-Trac or I6 + Selec-Trac?? matt.x ZJ Grand Cherokee Forum 13 09-30-2004 11:23 PM
