trac bar loose? - JeepForum.com
post #1 of 9 Old 05-02-2013, 06:46 AM Thread Starter
funkness
trac bar loose?
ok so here my story with this been slowly rebuilding this jeep have replaced all the blushing and joints (except ball joints)( the tires have no "play in them) but anyway there is still this very bad clunk clunk noise when turning but its a distinctive clunk not pop coming from the.passenger side of the jeep i had my wife jump up and down on the driver side and looked and i am watching the bolt from the track bar to the axle moving from side to side is it spose to do that?
Any help would be great
Thanks
Mike
funkness is offline
post #2 of 9 Old 05-02-2013, 07:11 AM
WhiteOut
WhiteOut's Avatar
No, all track bar bolts should be tight.
WhiteOut is offline
post #3 of 9 Old 05-02-2013, 07:15 AM Thread Starter
funkness
Thing i am scared about is its moving from side to side guess ill mess with it tonight and see if the hole is ovaled out
funkness is offline
post #4 of 9 Old 05-02-2013, 10:00 AM
Oldfrog
2007 WK
Might want to check the other side too. The mounting bracket tends to work loose.
2007 5.7 Hemi, Ltd. QD II -
1997 ZJ, 4,0 select trac, Up country, track lok.
Oldfrog is offline
post #5 of 9 Old 05-02-2013, 11:06 AM
mig1289
Could also be the sway bar end links if you didn't replace them when you did the bushings
2wd zj...
mig1289 is offline
post #6 of 9 Old 05-02-2013, 11:16 AM
ratmonkey
R.I.P.
ratmonkey's Avatar
The hole is wallowed out. You'll need to weld in new metal, a set of washers, or if it isn't too bad you can drill it out to 1/2".
ratmonkey is offline
post #7 of 9 Old 05-02-2013, 12:25 PM
KyleSekora
I have the same problem with my track bar. I'm getting two metal washers and having someone weld them in. And buying a grade 8 nut and bolt to hold it in place. Just like ratmonkey said.
______ooooo
/__l_l_,\____\,___
l_---l_l__l---[ ]llllll[ ]
_.(o)_)__(o)_)---)_)
KyleSekora is offline
post #8 of 9 Old 05-06-2013, 07:07 AM Thread Starter
funkness
Ok so i was messing with it and you know that little bracket thing that holds the nut on the other side well.. That's gone Idk where it went but the nut was still there anyway long story short i went and got a one from a junk yard and good as new
funkness is offline
post #9 of 9 Old 05-06-2013, 08:56 AM
dnuccio
Was probably just loose
Reliability is relative
R.I.P. Ratmonkey
dnuccio is offline
