towing on a zj - Page 2 - JeepForum.com
post #16 of 26 Old 05-14-2012, 05:38 PM
MTBlue
Originally Posted by whiteylovesbeer View Post
@ sebian- turn off the OD? is that possible with a 96 ZJ with 4.0, im new to these but i dont see any button that they usually have to do that, all it has is OD,2,1. thanks
Dirt Deprived
MTBlue is offline
post #17 of 26 Old 05-14-2012, 08:12 PM
Roskoe
does any one read the owners manual anymore
"aut viam inveniam aut faciam"
I hate when old people poke me at weddings, point and whisper, "You're next." So I've started doing the same thing to them at funerals
Roskoe is offline
post #18 of 26 Old 05-14-2012, 08:17 PM Thread Starter
Cmense
I think that all the time when I read these threads. sit down read the owners manual and learn a few things
Cmense is offline
post #19 of 26 Old 05-14-2012, 08:28 PM
jtackerman28
Only thing is that the owners manuals were for a new Jeep. I wouldn't put my 200k Jeep up to a 5000 lbs trailer. Personally.
But yet reading would help a lot.
3.5 re lift, double sheer front tb, 31" wrangler duratecs
jtackerman28 is offline
post #20 of 26 Old 05-15-2012, 08:01 AM
Bale
I occasionally pull a double horse trailer (around 3,700 lbs) with my 4L. Steady as a rock, but just adequate power. Keeps up with traffic most of the time.
It is approved for 7,700 lbs trailers over here, by the way. Have no idea how those limits are determoden.
1998 ZG (ZJ) Grand Cherokee Ltd, 4L 4x4
Bale is offline
post #21 of 26 Old 05-15-2012, 09:06 AM
BigClay
A 1/2 ton truck will be a much better option than a ZJ. Factory ZJ brakes can barely stop itself, much less try to stop a trailer that doesn't have brakes. I pulled a small u-haul with my jeep when it was stock, it did OK, and the loaded trailer wasn't more than 1500 lbs. Coil sprung, unibody vehicles were not meant to tow.
Current: 98 TJ, 33" TSLs
Past: 94 ZJ, built for the rocks
BigClay is offline
post #22 of 26 Old 05-15-2012, 09:55 AM
V8jeepinVA
I towed my yj with my zj no problems had brake controller and its a 5.9
But this seemed better to haul up to Pennsylvania last year
But aslong as your smart keep toung weight down and a level trailer easy throttle and enough braking plus od off and staying under limit youll be fine. Dose put stress on drivetrain so if its already loose expect a possible break but always hope for the best
V8jeepinVA is offline
post #23 of 26 Old 05-15-2012, 11:03 AM
hdrocknroll
Talking about towing a trailer !
Check out these cool ideas !!
Mini Harbor Freight (type) Trailer Ultimate Build-Up Thread
Always !! Keep A Firm Grip On Your Tool !!
Watch Out For The Air Hose Gone Wild!! Or Wear A Cup,: True Story
Originally Posted by rooster51 View Post
Whats the worse that can happen? Your jeeps already broke.
hdrocknroll is offline
post #24 of 26 Old 05-15-2012, 04:24 PM
greyhnd
I've used my ZJ with 4.0L and 2wd to boot to pull a 12 hole dog trailer 3 times so far. The trailer isn't that heavy, about 1200lbs or a bit more and even full of dogs not much more than 1600lbs or so. It also has trailer brakes and it rolls right on down the road and stops without a problem as long as I take the proper precautions.
greyhnd is offline
post #25 of 26 Old 05-15-2012, 05:15 PM
neonhomer
I used my I6 ZJ to pull a 20' trailer w/ my friend's 94 V8 ZJ out of the woods. Had to drag it through the dirt and sand.
Mind you, I had to be in 4Lo, and wasn't in a big hurry. Once we got out to the road, the trailer's owner used his Dodge 2500 diesel to take the ZJ back to it's home shed... Meanwhile, I treated my ZJ to a tranny and transfer case fluid change.
NeonHomer
Mid-Florida Jeep Club - Member
1996 Jeep Grand Cherokee, 4.0L/42RE/242 - Rebuilt motor w/ Comp cam (4/12), 3.5" Junkyard F>R lift, 31x10.5.x15 M/T's, Spartan Locked D44a, TC & tank skids, F&R adj trackbars, V8 steering arms
Galaxy DX99V CB, 102" SS Whip, Yaesu FT-2900R 2m, Larsen 1/4w mag mount, Sony HU, Massive 3way - F Door, Pioneer 3way - R Doors, MB Quart ONX304 Subs (x2), Lanzar 1600w amp.
"No Matter Where You Go... There You Are."
"Oh me oh my a lovely day is dawning. Oh what a joy I didn't wake up dead. So I can go to work and then resume my yawning, and get my sleep on site instead of in my bed" - Daria Morgendorffer (with my twist)
neonhomer is offline
post #26 of 26 Old 05-15-2012, 05:28 PM
hdrocknroll
I used the ZJ a couple of times, since I got it, with my 6X10 trailer, no problems except with the trailer tire.
But I had a spare
towing
