Towing Package or Towing Prep Package? - JeepForum.com
post #1 of 27 Old 01-07-2007, 07:35 AM Thread Starter
lma1973
My GCL came with a Towing Prep Package according to the window sticker and i do indeed have a hitch and the factory trailer hitch wiring. What i want to know is what is the difference between the Prep package and the Towing Package or are they one and the same? Thanks.
2005 Jeep GCL Hemi
Gibson 3" catback exhaust
Airaid Intake
Superchips Flashpaq
lma1973 is offline
post #2 of 27 Old 01-07-2007, 08:58 AM
micifus
Original GC'er
micifus's Avatar
Does it have a tranny cooler? The towing package useually means hitch and tranny cooler.
- OME Springs - 30"x9.5" Yokohamma's A/T-S -RE Shocks - JKS Quicker Disconnects - FM70 - E-Fan Conversion - 249->242 Swap -
32"x11.5" BFG A/T
4" Lift
"For every one thing I fix two things break"
micifus is offline
post #3 of 27 Old 01-07-2007, 09:00 AM
aphex
It means that that hitch is only held on by 2 sheetmetal screws so DO NOT USE IT.
In all honesty i think you have the towing package - its just different verbage on the window sticker. The only other thing I think it could be is that its a smaller receiver or is not designed to carry as much weight (all though I doubt this). If everything you need to carry a trailer is there then you should be good to go. Towing prep package may also indicate better drivetrain components than standard to handle towing also.
aphex is offline
post #4 of 27 Old 01-07-2007, 09:34 AM
nierace
nierace's Avatar
2003 WJ
Towing prep would mean, tranny cooler/gearing but no hitch.
Towing package means, tranny cooler/gearing/hitch.
Nickerdoodle
03 WJ 4.7 242HD Kolak/IRO 5" Clayton LA's
35" BFGoodrich KM2
North East Offroad Club
nierace is offline
post #5 of 27 Old 01-07-2007, 09:53 AM
jeep_zj98
2012 WK
My 98 ZJ has the towing prep package. When asked the mechanic many years ago, he said it is just the gearing and components to handle towing. No tranny cooler installed.
If I had to tow something, I need to buy a hitch and wiring. If necessary, I also need to add the tranny cooler.
jeep_zj98 is offline
post #6 of 27 Old 01-07-2007, 04:34 PM Thread Starter
lma1973
Yeah im not sure about the tranny cooler? But i definitely have the hitch bar but it looks aftermarket, i dont know.
2005 Jeep GCL Hemi
Airaid Intake
Superchips Flashpaq
lma1973 is offline
post #7 of 27 Old 01-07-2007, 10:26 PM
j.love
j.love's Avatar
1994 ZJ
I have the prep package and I have the trany cooler but no hitch.
David.
94 ZJ laredo 5.9 V8 swap D44a posi
Originally Posted by ratmonkey View Post
I wouldn't drive down a driveway on that.
''If we do everything right, if we do it with absolute certainty, there's still a 30% chance we're going to get it wrong.''
Joe Biden
j.love is offline
post #8 of 27 Old 01-07-2007, 10:53 PM
Woody
Retired back to Bowties
Woody's Avatar
1985
The towing prep package from the dealer meant you have a cooler, and 3.73's.
If you don't have a tranny cooler, you don't have the towing prep package, which could mean you don't have 3.73's if you have the 4.0L engine.
Woody
1985 1 ton K-5, Detroit diesel, 36" tires (going bigger when money permits), 4-speed manual swap, Rockwell T-case, Hybrid lift, 12.5K winch.
Woody is offline
post #9 of 27 Old 01-09-2007, 02:01 PM
jeep_zj98
2012 WK
Hmm... my window sticker, which I still have, says it has towing prep group and it shows it has the gearing. Where will the cooler be? Behind the radiator, right?
post #10 of 27 Old 01-09-2007, 02:32 PM
Woody
Woody's Avatar
1985
Mine was in front of the rad.
Woody
Woody is offline
post #11 of 27 Old 01-09-2007, 02:47 PM
FPKites
ZJjazzyJim
FPKites's Avatar
Cooler is in front of the rad, passenger side. It's actually an auxiliary cooler. The radiator does the primary cooling.
We've discussed this one in the past. Towing prep means the cooler is there, gears are there. Towing package means cooler, gears, wiring, receiver.
Jim Karlin
"Duh! Big RED Jeep!!!"
or
96 ZJ Laredo
5" lift, Claytons, KOR radiator support, rear bumper, steering brace, etc, etc, etc.
04 WJ Overland
Clean.... :D
FPKites is offline
post #12 of 27 Old 02-20-2012, 02:12 PM
jimirig
I am sending out for my build sheet @ jeep.com . My 1996 GCL has Tranny Cooler and no hitch . I put the hitch and wire harness on myself but not sure about steering and gearing.
jimirig is offline
post #13 of 27 Old 02-20-2012, 02:32 PM
SAR-Swimmer
I'd pretty much guarantee you have steering. As to your gearing, you should be able to find a metal tag on your rear differential that will give you the gearing in it
SAR-Swimmer is offline
post #14 of 27 Old 02-20-2012, 02:46 PM
nicklopic
Once you get your build sheet, you'll find the gearing on there next to where it says what axles you have
98' ZJ 4.0
4.5" short arm, 33" Courser MXTs, custom stubby bumper, skids, someother stuff
nicklopic is offline
post #15 of 27 Old 02-20-2012, 05:57 PM
V65Ozzie
Wondering about my trailer lights..... I installed a mopar hitch that I got that has a 7 pin built in, but The wires inside the rear quarter panel aren't where I expected, so much for plug and play....however, that's been addressed in another thread, gotta look in the *other* side....
But, in the meantime I have a flat 4 pin plug with a converter hooked up to my taillights. Trailer lights work great on the Dodge minivan with the same setup, but with the jeep, if the taillights are on, the turnsignals at he trailer are really weak. Vehicle lights working fine. Wondering if it's a TS relay thing. Pretty sure I have the wiring correct, and spliced and soldered all connections. Moot problem if I find the factory connector buried in the left rear fenderwell....but I like having that 4 pin, just wished it worked better. Testing with a test light shows that I've got power when and where I'm supposed to. And trailer works fine on Minivan.
V65Ozzie is offline
How do i know if i have towing package? lma1973 ZJ Grand Cherokee Forum 11 11-07-2006 08:02 PM
Towing Package? redgrandcheroke ZJ Grand Cherokee Forum 6 02-11-2006 06:48 PM
Towing Package countertop ZJ Grand Cherokee Forum 9 10-23-2005 03:44 PM
Factory Towing Package bryanbaeta WJ Grand Cherokee Forum 5 03-15-2004 11:10 AM
Adding a Towing Package? jplush76 ZJ Grand Cherokee Forum 18 09-02-2003 03:57 PM
