Quantcast Towing a Jeep BEHIND a motorhome. - JeepForum.com
Go Back JeepForum.com > Models > Jeep Grand Cherokee & Commander Forums > ZJ Grand Cherokee Forum > Towing a Jeep BEHIND a motorhome.
Rock Krawler Suspension's for BLOW OUT prices!!!Great deals on Mickey Thompson Tires @ Jeephut.comRCV Heavy Duty Axle Shafts Now Shipping at Baseline4x4.com
Old 01-09-2009, 12:00 AM   #1
Yankee802
I just got a 2004 Jeep Grand Cherokee Overland and need some information on getting the equipment in order to tow it behind my motorhome. The Jeep dealership said they don't have anything, and suggested I go to U-Haul. I can't believe they don't have this, so I figured I'd ask here. Is there anyone here that had their Jeep configured to be towed? If anyone can tell me what to get and where, I would appreciate it.
TIA,
Geoff
Yankee802 is offline   Reply With Quote
Old 01-09-2009, 12:07 AM   #2
xJoshxx
xJoshxx's Avatar
2011 WK
i believe u can configured something called a BLUE OX? and when ur towing it Put the Tcase in Neutral and the Transmission anit it? or just the Tcase Ethier way make sure ur wheels spin!
xJoshxx is online now   Reply With Quote
Old 01-09-2009, 05:45 AM   #3
_Kyle_
Hmmmm....
_Kyle_'s Avatar
For the 242 (and I think most others are the same, but CHECK YOUR MANUAL), the tcase is in neutral and the transmission is in park. BlackZJ52 didnt believe me on that one last weekend so I made him read my owners manual while I drove to his Jeep to tow it back .
As for towing, you should be able to get a dolly or something from u-haul. Maybe check some RV enthusiast websites and see what they all use to tow? I know there is a way to use straight bars and let all 4 wheels ride on the ground but I have no idea what it's called. I've just seen it on the highway before all the time.
-Kyle
1996 Grand Cherokee
RIP Troy (bigbluezj94)
1996 ZJ FOR SALE
_Kyle_ is offline   Reply With Quote
Old 01-09-2009, 08:22 AM   #4
merkur92
camping world will have everything you need.I tow my 2002 overland all time without problems.I use a roadmaster tow bar,and homemade tow bar mounts.Transfer case in nuteral,trans in park,steering wheel unlocked,and you are ready to tow.
2002 Overland wj,JK rubicon dana 44s, np231, 6" rock krawler long arm lift,ARB front bumper,warn winch,JCR rock sliders,33" toyo M/T,s.
merkur92 is offline   Reply With Quote
Old 01-09-2009, 08:55 AM   #5
JeepOrvis97
One of 2733 :)
JeepOrvis97's Avatar
Does that still roll your mile forward on these newer vehicles?
My Classifieds
JeepOrvis97 is offline   Reply With Quote
Old 01-09-2009, 09:07 AM   #6
Mr. Breeze
Go to an RV shop, they should be able to hook you up (no pun intended.)
'97 ZJ, 4wd, 4.0, 3" Pro Comp lift, 31" BFG MT KM2s, JKS Front & Rear trackbars, JKS Disco's, Rear Aussie
Mr. Breeze is offline   Reply With Quote
Old 01-09-2009, 10:17 AM   #7
merkur92
Miles dont roll foward on odomoter.You really just need to buy the tow bar and the mounts to bolt to your jeep.You can buy them anywhere.I got my tow-bar,brand new on e-bay for under half of retail.The mounts that bolt to where the tow hooks go are harder to find deals on and they are not cheap.Not to hard to put on once you get the bumper cover off.You are also going to have to figure out what you are going to do about lights and brakes.Its nice to have your tow lights wired into the jeep lights.If you get all the mounts and a light kit anyone with basic skills and tools could install everything in a afternoon.
Old 01-09-2009, 02:07 PM   #8
gcjeeping
I put mine together for 150 bucks. Also is the winch mount too.
gcjeeping is offline   Reply With Quote
Old 01-09-2009, 03:26 PM   #9
CanadianZed-J
I was considering buying this Jeep that had been towed behind an RV. Guy said the last owner said 60,000km was in tow so the odometer doesn't reflect its operating mileage. If the odometer doesn't roll, then buddy may have been lied to. Hmm.
Anyway, you can see the setup on this one. I like it because it's pretty hidden in there. But I don't have a clue what brand it is.
(Sharp lookin' '99 too, eh?)
CZJ.
So I installed the flux capacitor but the Jeep just won't do 88 mph.
-'99 WJ Limited, 4.7, Patriot Blue, 2" BB, 31" Mall-Terrains, Pavement Princess
-'97 TJ, Stone White, 4" Superlift, 33" SSRs, lunchboxed rear, 12K Titan winch, and 2.5 litres of exhillirating performance.
CanadianZed-J is offline   Reply With Quote
Old 01-09-2009, 03:49 PM   #10
Mr. Breeze
The only thing that would really wear out is the bushings. That's what happened to mine and they weren't too hard to replace.
Old 01-09-2009, 04:28 PM   #11
CanadianZed-J
That and the wheel bearings, tires, gears (to a lesser degree having no load on them) and all suspension parts. What wouldn't be touched is electrical, engine, t-case, tranny, and everything connected to the serpentine belt.
Still a lot easier on a vehicle being flat-towed than driven though.
CZJ.
Old 01-09-2009, 05:08 PM   #12
SpoiledRotten
Roughin' it smoothly
SpoiledRotten's Avatar
I don't know if that is like the Wrangler, but when I turn on the key, I turn it to the position so that the steering wheel is unlocked but the instuments and accessories don't come on. That will keep the miles off of the odometer. Good luck.
BTW... nice set up, gcjeeping.
Christian Jeepers _ Member #2
United Four Wheel Drive Association _ Member
National Rifle Association _ Member
SpoiledRotten is offline   Reply With Quote
Old 01-09-2009, 07:34 PM   #13
Mickey_D
The Great White Ghost
Mickey_D's Avatar
You are correct, Spoiled. With the speed sensor being electronic, neither the speedometer nor the odometer will be operational with the key turned off. So no, you will not rack up odometer miles being towed so long as your ignition is off.
A big thank you to whomever sponsored my membership!!
1974 CJ-5 258 3spd SOA on 31's [Sold in 1991]
1995 ZJ Limited 5.2 on 31's [Sold in 2009]
1990 XJ Laredo 4.0, nothing special [Sold in 2010]
1955 Willys CJ-5 #12171 [Sold in 2011]
1997 ZJ Limited 5.2 The Great White Ghost
1953 Willys M100 trailer
Mickey_D is offline   Reply With Quote
Old 01-29-2009, 09:36 PM   #14
mekirk2
Four Wheels Down
****READ YOUR MANUAL****
I cannot stress this enough. Depending on your year and your 4WD type, you may or may not be able to tow. You CANNOT tow a 2WD, even on a dolly, without disconnecting the driveshaft! The back wheels cannot turn with the driveshaft installed, even if the transmission is in Nuetral. You will destroy your tranny if you tow with the rear wheels down.
4WD towing depends on the 4WD system. For example, the 2005 Grands have three different 4WD's. I dont remember their names but the first is ALL TIME 4WD without a low gear and Nuetral (I think Quadra trac I or something like that.) This one cannot be towed with any wheels down PERIOD. Major damage. On a dolly you will destroy your transfer case, 4 wheels down you will destroy your tranny.
The other two 4WD systems on an 05 can be put in Nuetral (transfer case) and towed per the manual.
Like I said, check your manual and know which system you have.
Michael
mekirk2 is offline   Reply With Quote
Glock Forum
