Tow Strap Question - JeepForum.com
Go Back JeepForum.com > Models > Jeep Grand Cherokee & Commander Forums > ZJ Grand Cherokee Forum > Tow Strap Question
All viair onboard air systems ship free to lower 48! Www.Spartan Locker Promo Running now @ ROCKRIDGE 4WD plus FREEJEEP Gear Change Packages From ROCKRIDGE 4WD. We Are DIFF
Unread 09-26-2005, 05:08 PM   #1
JCDubya
2009 WK
Tow Strap Question
Which of these straps is better for recovery?
"Tow Strap, Loop Ends, 3 in. Width x 30 ft. Length, 30,000 lbs. Rating, Gray, Nylon, Each
Towing made easy and safe.
Made of durable, high-strength nylon, these Explorer Pro Comp tow straps resist weather, moisture, and abrasion, and have super-stitched, leather over-wrapped end loops for added durability. $70.95"
"Tow Strap, Loop Ends, 3 in. Width x 30 ft. Length, 30,000 lbs. Rating, Yellow, Polypropylene, Each
Free stuck or disabled vehicles.
These heavy duty tow straps can be real lifesavers in emergency situations. They feature nylon webbing that stretches up to 20 percent during use, and then recoil to their original length when done. They're stronger and lighter than a chain, and more compact than a rope, so there's no excuse for not having one in your truck or SUV. $47.88"
I like the Procomp because it seems to be better made but it doesn't say anything about stretching for recovery. Does it? Which would you go with? I'm trying to get all my recovery gear ready for winter.
JCDubya is offline   Reply With Quote
Unread 09-26-2005, 05:14 PM   #2
zaq123
1941 JK Wrangler
Cheaper one
zaq123 is offline   Reply With Quote
Unread 09-26-2005, 05:46 PM   #3
RAAB3485
Viewer Discretion Advised
RAAB3485's Avatar
Originally Posted by zaq123
Cheaper one
Don't you mean "Keeper One"? Sorry. Stupid humor.
Eric
Colorado Jeep Club Member #1
RAAB3485 is offline   Reply With Quote
Unread 09-26-2005, 05:50 PM   #4
Woody
Retired back to Bowties
Woody's Avatar
1985
Go with the Keeper!
Woody
1985 1 ton K-5, Detroit diesel, 36" tires (going bigger when money permits), 4-speed manual swap, Rockwell T-case, Hybrid lift, 12.5K winch.
Woody is offline   Reply With Quote
Unread 09-26-2005, 05:50 PM   #5
10achik
I ate what?
10achik's Avatar
Maybe if you get lucky they will send you two like they did me. I bought the keeper one and then about 3 months later another one showed up out of the blue. For what it's worth, I've never had any problems with it.
Ken
99 GC Limited - 4.7L HO V8, 6.5" IRO HC LA lift, F&R D44s locked & trussed, 242HD, IRO TC Skid, KMA Bumper, 35's
2006 Saturn Redline -2.0L Eaton supercharged I4, GMPP Stage 2, Custom Tune, AEM CAI, Ebiach Pro Kit w/ swaybars, EVO Ventus V12s (13.76 @ 103.85)
2006 Pontiac G6 GTP
2012 Nissan Juke - (hers)
2000 SV650 - naked, integrated tail light, sliders, corbin, pilot roads, RK chain & sprokets, D&D full exhaust, FactoryPro Stage I jet kit, +4 Ignition Advancer, Barnett race clutch
2006 Triumph America 900 - Full Dresser
January 2009 Grand Cherokee of the Month (GCOTM)
10achik is offline   Reply With Quote
Unread 09-26-2005, 05:54 PM   #6
JCDubya
2009 WK
Thanks guys, so the Keeper it is...
Unread 09-26-2005, 06:05 PM   #7
zaq123
1941 JK Wrangler
It's the good one I didn't even look at that
Unread 09-26-2005, 09:48 PM   #8
Texas ZJ1
Jeep Jedi Master
Texas ZJ1's Avatar
1994 ZJ
I bought a yellow one from Walmart for 30 bucks. Had it for ten years and never had a problem.
Hunter
94 5.9 Laredo 6.5 RE lift with 35 Maxxis Bighorns
and 33 Bridgestone Duelers
Detroit and true trac
Red Jeep Club Member
REDNECK JCM
Texas Jeep Owner #6
USN Jeep Club #4
http://www.kevinsoffroad.com/
602.841.3355
For your performance needs:
kolak@kolakperformance.com
480.998.3661
Texas ZJ1 is offline   Reply With Quote
Unread 09-26-2005, 10:19 PM   #9
K-Pax
K-Pax's Avatar
i'm not sure what brand i carry where i work....i think it's Safewaze. if it's the same company i'm thinking of, they also make lifelines, safety harnesses for construction workers to prevent deaths from falls. i'm gonna have to look into that tomorrow when i go to work and maybe buy a strap for myself.
Graphic Design student at NWACC (Northwest Arkansas Community College).
Kevin's rig:
94 Grand Cherokee Laredo
I-6 4.0L, Quadra-Trac on demand
2" budget lift
pro-comp steelies
kevin's radiator support bar
JKS quick discos
e-mail me
K-Pax is offline   Reply With Quote
Unread 09-26-2005, 10:45 PM   #10
PumaZJ
awhile back there was a misprint on www.pirate4x4.com that they were selling the pro-comp straps for $19.99. when they are normally like $50. I got one then and has worked fine ever since, only been used twice though.
[size=4][b][color=blue]98 ZJ - Clayton 4-link - 35's - 8.8 - HP30 - LOCKED[/color][/b][/size]
[url=http://www.mallcrawlin.com/forum/showthread.php?t=4421]Buildup and wheeling pics [/url]
PumaZJ is offline   Reply With Quote
