Tow hooks - JeepForum.com
post #1 of 19 Old 12-19-2012, 09:56 AM Thread Starter
Bigdjs123
Tow hooks
I'm going to pull a part in a few and figured I'd ask on here before I carry a 50 lbs tool box around. What size sockets/wrenches do I need to take them off?
Bigdjs123 is offline
post #2 of 19 Old 12-19-2012, 10:57 AM
x10radsponge
I had to use SAE on the bolts mounting the hooks, but a larger metric, i'm thinking 17 mm or higher on the bolts to the frame. Had to use adjustable for the SAE ones. Also, bring 1/2 drive for the frame ones as the ones I tried to get off were on there quite good and a longer handle would have been much nicer.
x10radsponge is offline
post #3 of 19 Old 12-19-2012, 10:59 AM
kg6mov
Hears the voices
kg6mov's Avatar
Most of the front end is 15mm and 17mm
kg6mov is offline
post #4 of 19 Old 12-19-2012, 11:02 AM Thread Starter
Bigdjs123
Ok thanks guys
post #5 of 19 Old 12-19-2012, 11:45 AM
Technohead
Dont be surprised if you need a torch and sawzall.
-Eric
Technohead is offline
post #6 of 19 Old 12-19-2012, 12:05 PM
95_ZJ_Limited
Bring a breaker bar
1995 ZJ Limited. Lifted, AW4 & 4X4 swapped
Build Thread: Jeep Grand Hilton
Built Not Bought # 529
95_ZJ_Limited is offline
post #7 of 19 Old 12-19-2012, 02:41 PM Thread Starter
Bigdjs123
Got a set of an orvis. One side came of in tact but took forever and the other side the bolts snapped in the piece that goes inside the frame. Alls I used was an 18 in break bar and 1/2 in ratchet.
post #8 of 19 Old 12-19-2012, 05:25 PM
dnuccio
when i got my JY tow hooks and brackets, 3 bolts snapped off, so i cut the old nuts off the backing plate and welded on some regular nuts. the factory ones are nylon lock nuts and a major PITA to work with in such a tight space. now i just used lock washers and theyre been there for 3 months and havent loosened up a bit.
Reliability is relative
R.I.P. Ratmonkey
dnuccio is offline
post #9 of 19 Old 12-19-2012, 06:08 PM Thread Starter
Bigdjs123
I'm just gonna leave the nuts on there since I can't weld. But I got the 4 broke studs out pretty easily. Heated me up with a propane torch til I knew the lock tite was on fire/melted I used vice grips to twist me out. Nice and clean now lol
post #10 of 19 Old 12-20-2012, 09:28 AM
x10radsponge
An Orvis, good grab. All I can find is basic laredos and if I do find one near a 98 they are 2wd. There are about 15 jeeps at the one near me and none have a sunroof I am looking for. I did get the hooks but because I did not have a hammer and prybar to get the other bracket off due to body damage, when I went back they had crushed it. So I got the hooks but no brackets.
post #11 of 19 Old 12-20-2012, 09:32 AM Thread Starter
Bigdjs123
Ya I wanted to take the seats too but the windows were smashed out so they were ruined
post #12 of 19 Old 12-20-2012, 09:50 AM
Candymancan
The bracket is really nothing more then a peice of steel with nuts welded on it.. Grab some steel take a drill and line the hole up and mark em and drill hole in them and there is your bracket
Candymancan is offline
post #13 of 19 Old 12-20-2012, 10:25 AM
PolkaPower
I don't know, it might be easier to make a whole bumper than to engineer these brackets.Looks like a PITA.
PolkaPower is offline
post #14 of 19 Old 12-20-2012, 10:25 AM
zarnold
What did you pay for the hooks? Curious as to what a JY will charge for them.
zarnold is offline
post #15 of 19 Old 12-20-2012, 10:27 AM
PolkaPower
Just the basic hooks are like 8-10 bucks new. Warn hooks are like 18.
