tow hooks - JeepForum.com
post #1 of 16 Old 01-25-2005, 11:18 PM Thread Starter
grandman97
grandman97's Avatar
tow hooks
where can i attach tow hooks on the front of my zj?? and if i can will i be able to leave the stock bumper on ?
grandman97 is offline
post #2 of 16 Old 01-25-2005, 11:30 PM
Meerkat
Tow hooks attach at the frame (basically where the bumper attaches). Yes, you can leave the stock bumper and fascia intact. Check out Rusty's Offroad for the most complete, least expensive, OEM type tow hooks.
HTH
Warren
Black 1996 5.2L ZJ Limited
Meerkat is offline
post #3 of 16 Old 01-25-2005, 11:36 PM
CAHotRodBoy
Kevinsoffroad.com has a cool radiator support with tow shackles. I just installed one and built a custom front bumper.
http://www.kevinsjeepparts.com/zj/zj_rad_support.html
http://us.f1.yahoofs.com/users/f8a83...cIb9BBwUoBArhv
CAHotRodBoy is offline
post #4 of 16 Old 01-25-2005, 11:43 PM
Meerkat
It is, indeed, a great item. However, you have to trim your fascia in order to install and use it...
Warren
Meerkat is offline
post #5 of 16 Old 01-25-2005, 11:54 PM
CAHotRodBoy
Yup! I pulled mine off along with the bumper. You can cut wholes in the fascia for the shackles. I built a custom bumper and like the more rugged look. I also prefer shackles to tow hooks as there are less likely to have the tow strap slip off. The tow hooks are cheaper and easier to install though.
post #6 of 16 Old 01-25-2005, 11:59 PM Thread Starter
grandman97
grandman97's Avatar
WVD -i looked at that link u posted and it said it was like $120 for the hooks and brackets and hardware... i probably need all that stuff to mount them right? if so is that the going rate on tow hook assemblies ?
post #7 of 16 Old 01-26-2005, 12:04 AM
CAHotRodBoy
$120!? I guess they are NOT cheaper than Kevin's!
post #8 of 16 Old 01-26-2005, 12:09 AM
matt.x
matt.x's Avatar
Kevin's stuff is really good ... through Jan 31 he has a special, I got the radiator support and shackles for about $130 ...
attached is the picture...
Matt
Red Jeep Club Member #237
matt.x is offline
post #9 of 16 Old 01-26-2005, 05:41 AM
CoyoteCruiser
I took mine in to have a hitch put on and asked the guy if he had tow hooks and he had one so I had him install it $65.00 that was for the part and installed. He told me the holes were all ready there didn't have to drill any. this is the hook type. Its has come in handy used it a couple of times.
CoyoteCruiser is offline
post #10 of 16 Old 01-26-2005, 05:47 AM
Meerkat
That's $120.00 shipped. Yes, that's about the best price around.
Coyote, without the reinforcing bracket behind that hook, you are in danger of ripping the hook out under tension, creating a deadly missile and damaging your Jeep at the same time.
HTH
Warren
Meerkat is offline
post #11 of 16 Old 01-26-2005, 08:39 AM
Texas ZJ1
Jeep Jedi Master
Texas ZJ1's Avatar
1994 ZJ
Don't be crazy. If you mount the hooks without the towhook brackets, you're just fooling yourself.
Hunter
04 4.7 HO, limited
08 Z71 Suburban, front leveling kit with rear spacers. 285/65 18s Nitto TerraGrappler G2s
94 5.9 Laredo 6.5 RE lift with 35 Maxxis Bighorns
and 33 Bridgestone Duelers
Detroit and true trac
REDNECK JCM
Texas Jeep Owner #6
USN Jeep Club #4
602.841.3355
For your performance needs:
480.998.366
Texas ZJ1 is offline
post #12 of 16 Old 01-26-2005, 09:44 AM
Phil Gerard
Former Mod
Phil Gerard's Avatar
Rusty's Tow Hook Install Thread
Here's a thread I posted on installing Rusty's Tow Hooks. Yes, the bumper has to come off and you'll need 12 - 14 plastic rivets because you're gonna break most or all of them.
http://www.jeepforum.com/forum/showt...usty%27s+Hooks
Good Luck!
Phil
'95 ZJ Ltd. White 4.0L
TW DC DS; ARB Bull Bar, F&R Air Lockers; Superior Axles; Warn Winch; 4.56 gears; ACOS, Addco F&R Sw Bar, JKS Discos, Rr Track Bar & Nerfs, 249>242 Swap, Stillen rotors+Kolak pads, 3 pc. Armor, RE 4.5 Kit + 2.5"BB, Adj. UCAs&LCAs, OME SS, Bilstein 5150s, 15x8 AR Diamond Backs, 33 Truxus MTs, K&N FIPK, RE 62mm TB, Perf. Distr. 4.0L Kit, Exhaust: 2.5" Kolak exhaust FM 70: Optima Yellow, Mean Grn Alt., PIAA 520s, 540s, Kevins Rack, & TB Conversion
Phil Gerard is offline
post #13 of 16 Old 01-26-2005, 03:06 PM
CoyoteCruiser
I didn't know that. The guy that installed my hitch put it in for me. Have to check it out. Thanks
post #14 of 16 Old 01-26-2005, 05:09 PM
wassupjamesd
Does anyone know if more hardware is needed on these Kragen tow hooks? Or if these are cool enough for a Cherokee?
http://www.partsamerica.com/PartDeta...goryCode=3206B
Other tow hooks I've seen have more hardware and cost a lot more.
Thanks!
1999 Cherokee Sport 4x4, RE 3.5" SF, SYE, DS, and Monotubes, Pro Comp adj track bar. Soft 8s wrapped in 31x10.5x15 Dik Cepek Mud Countrys, Silverstars w/ HD harness, Class III rear hitch, Yakima snowboard racks, cool sunroof. NP231, C8.25, and D30.
wassupjamesd is offline
post #15 of 16 Old 01-26-2005, 05:26 PM
PlatinumZJ
Senior Moment Member
PlatinumZJ's Avatar
Thanks!
This is the Grand Cherokee forum But, because the grands are unibody, the mounting points must be reinforced or under load they can pull the bolts out. Very bad. Post No 2 in this thread has about the best price on Hooks and mounting hardwear Kevin, in post 3 has a reinforced member with shackles for about the same price. I don't know about Cherokees.
Doug
When all is said and done, more is said than done.
Platinum '97 ZJ LTD, I6 (see profile) Paid for!
Links:
for ZJ & WJ stuff,
for performance stuff. I6 performance info at
Other stuff: Kevin's Roof Rack. KOR sliders, Bored 62mm TB, Blaupunkt Bermuda w/ ipod, Brembo Slotted rotors,
OME steering stabilizer, H4 headlight upgrade...
PlatinumZJ is offline
tow hooks nuey302 ZJ Grand Cherokee Forum 2 12-21-2008 11:14 PM
Tow hooks z_gilligan WK Grand Cherokee & XK Commander Forum 12 12-21-2007 02:55 AM
Tow Hooks Death-Mobile ZJ Grand Cherokee Forum 11 04-05-2005 05:33 PM
tow hooks rescue96zj ZJ Grand Cherokee Forum 8 03-28-2005 10:32 PM
