tow hitch restoration - JeepForum.com
post #1 of 14 Old 06-19-2013, 11:56 PM Thread Starter
drobes34
Anyone know if taking a rusty tow hitch off and sanding it down and repainting will compromise the structural integrity
drobes34 is offline
post #2 of 14 Old 06-20-2013, 12:15 AM
cgcarpenter
Depends how bad the rust is...
cgcarpenter is offline
post #3 of 14 Old 06-20-2013, 12:25 AM Thread Starter
drobes34
Mostly surface but old paint is falling off bc of it
drobes34 is offline
post #4 of 14 Old 06-20-2013, 12:34 AM
caseyliffick
You'll be fine. Just take an electric or air powered wire brush to it, pull all the surface rust off and hit it with 4 coats of rustoleum.
caseyliffick is offline
post #5 of 14 Old 06-20-2013, 12:37 AM
xcaliber81
Or wait for the recall?
xcaliber81 is online now
post #6 of 14 Old 06-20-2013, 08:04 AM
AmishFury
at this point... this
AmishFury is offline
post #7 of 14 Old 06-20-2013, 08:04 AM
AlphaLorde
x2
1998 ZJ Laredo 5.2L 139k 231 w/SYE artec trussed 8.8 4.25"F/5"R lift
AlphaLorde is offline
post #8 of 14 Old 06-20-2013, 08:58 AM
96zedjay
X3 On the recall.
96zedjay is offline
post #9 of 14 Old 06-20-2013, 09:24 AM
PolkaPower
I can't say for you all but I would feel like a huge A-hole going to get a free tow hitch because the one I have has a little surface rust on it.
Just clean up the one you have unless it doesn't work for some reason.
PolkaPower is offline
post #10 of 14 Old 06-20-2013, 09:40 AM Thread Starter
drobes34
Works just fine pulled myself out couple times with it I was just under it and saw It as something else I could do before it does have problems. And I thought they weren't covering anything over like 10 years or something for free. I was told u gotta pay for it
drobes34 is offline
post #11 of 14 Old 06-20-2013, 09:46 AM
PolkaPower
The jury is still out on that but it looks like they are going to install some hitches on ZJ's. We will supposedly receive letters in the mail. I assume only the ZJ owners who don't have a tow hitch in their build sheet will get letters but who knows.
Either way going to the dealer is a huge PITA in my opinion. I would rather go to a JY and pull some useful parts and spend the day installing them than waiting around at a dealership. Tow hitches at the yard are only like 30 bucks.
I was hoping they would hand out some skid plates. Even then I would just go and pick it up and put it on myself.
post #12 of 14 Old 06-20-2013, 09:56 AM
a70eliminator
Mine is unique to the factory tire carrier, they can inspect it but I seriously doubt I'm actually going to hassle with it, I'll sign off the recall.
a70eliminator is offline
post #13 of 14 Old 06-20-2013, 01:26 PM
ajmorell
ajmorell's Avatar
Yeah, especially if I had a functional one already. An hour with a wire wheel on a grinder will clean it right up. Here's a few pictures of how mine cleaned up.
You can see how it was to begin with, structurally intact but surface rust
In process, before it got painted
All done
ajmorell is offline
post #14 of 14 Old 07-21-2013, 06:29 PM
alyman85
1985 FSJ Wagoneer
Do you know what size the bolts are for the hitch? I am going to install one but I need to re-tap the threaded hole and cant find what size the hole is. I believe it is a 14 mm but not sure
alyman85 is offline
