Torque Specs - JeepForum.com
post #1 of 8 Old 06-15-2006, 08:07 AM Thread Starter
wmm_16
Torque Specs
I think I'm going to be replacing my exhaust manifold either this weekend or next. Can someone give me the torque specs for the intake and exhaust manifolds, also any other tips that will save me a headache.
1996 Jeep Grand Cherokee Limited
4.0 I6 2WD
Clear corners
K&N Filter
Alpine head unit
Firestone Destination LE's
wmm_16 is offline
post #2 of 8 Old 06-15-2006, 08:18 AM
Wheelin98TJ
JEEP FREAK
Wheelin98TJ's Avatar
Tightening sequence:
Torque specs:
Its not too bad of a job. The most difficult part of it is getting at some of those bottom bolts. Just have some wobble sockets on hand and you'll be fine. Or better yet, ratcheting wrenches.
You also may need a fuel line disconnect tool ($5-10 at any auto parts store). Some people just leave the intake kind of hanging there, but I think its quicker to just get it out of the way. If you don't have a fuel line tool, you can just pull each of the injectors.
You have to loosen the power steering pump since its bolted to the intake.
When reinstalling, be sure to get the header seated properly on the alignment pins. It seems like people have problems with this sometimes and end up with an intake leak when its all done.
Be sure to use a quality gasket. I recommend an OE gasket. They are raised around the ports for a better seal and cost around $15.
Here's a decent write-up from Banks website that also may help:
http://www.bankspower.com/im_ora-may03.cfm
Wheelin98TJ is offline
post #3 of 8 Old 06-15-2006, 08:47 AM
greasefingers
greasefingers's Avatar
1994 ZJ
Wheelin: nice schematics
And donít forget the exhaust manifold donut gasket. I could not find one at any of my local auto stores.
Cheers Steve
94 Black Laredo 4-Liter with QuadraTrac (42RE trans & NP249 TC) 200,000 + miles purchased new
88 Cherokee 2-door with 5speed manual 139K miles(deceased) purchased new
greasefingers is offline
post #4 of 8 Old 06-15-2006, 12:38 PM Thread Starter
wmm_16
I just put in a new doughnut thinking that was the culprit. I ended up breaking one of the bolts off with my cordless impact though. I'm just going to do the new manifold now, then I know it's all good. The manifold kit I am getting has new flange bolts and gaskets too, though I'll probably get a good Fel-Pro gasket for the manifold.
4.0 I6 2WD
Clear corners
K&N Filter
Alpine head unit
wmm_16 is offline
post #5 of 8 Old 06-15-2006, 01:14 PM
Wheelin98TJ
JEEP FREAK
Originally Posted by wmm_16
...though I'll probably get a good Fel-Pro gasket for the manifold.
I think you're better off with an OE gasket.
post #6 of 8 Old 06-15-2006, 01:16 PM Thread Starter
wmm_16
I'll check it out, I used to work at a parts store and was trained by Fel-Pro. You know how it is, almost like they brain wash you.
4.0 I6 2WD
Clear corners
K&N Filter
Alpine head unit
wmm_16 is offline
post #7 of 8 Old 06-15-2006, 01:21 PM
greasefingers
1994 ZJ
I consider Fel-Pro as one of the best out there.
Cheers Steve
post #8 of 8 Old 07-22-2012, 04:34 PM
VAzj
My Felpro Gasket smoked for a little bit.
Wayyyyyy quieter now and the reverse doesn't shutter violently like it did before.
A little bit more power and doesnt mind going over 3k rpm's.
New timing chain and it should be good to go.
VAzj is offline
ZJ axle torque specs Johnyakimo1855 ZJ Grand Cherokee Forum 4 02-17-2009 05:45 AM
Oil Pan torque specs Inavacuum ZJ Grand Cherokee Forum 3 11-03-2008 10:24 PM
torque specs Inavacuum ZJ Grand Cherokee Forum 2 12-27-2007 09:12 PM
torque specs NickL ZJ Grand Cherokee Forum 4 06-07-2007 01:42 PM
Torque Specs KAB 04 WJ ZJ Grand Cherokee Forum 5 01-17-2007 07:23 AM
