Quantcast Torque Spec Question D30 - JeepForum.com
Go Back JeepForum.com > Models > Jeep Grand Cherokee & Commander Forums > ZJ Grand Cherokee Forum > Torque Spec Question D30
Old 03-03-2008, 03:26 PM   #1
midnghtshdow
Hey i have chilton for my 95 gc and i can not find the torque spec for the carrier in the front diff. i can find for the pinion but not the carrier. Is there some place i can get it off the net or maybe you guys might know.
MUD TRAILS HERE I COME
midnghtshdow is offline   Reply With Quote
Old 03-04-2008, 01:27 AM   #2
midnghtshdow
Well i guess no one knows hey did all zj come with crush sleevs on the pinion that is whats on it right
Old 03-04-2008, 05:06 AM   #3
a70eliminator
I think no one knows what you mean by carrier, carrier bearings preload maybe, bearing caps, ring gear bolts? not sure what they're calling the carrier, and I do beleive we have a crush sleeve for pinion depth.
a70eliminator is offline   Reply With Quote
Old 03-04-2008, 06:33 AM   #4
midnghtshdow
Ya i was just wondering if all zj's came with them? I mean for the torque spec on the carrier bearings for the 2 bolts on each side. Its wierd that the chilton does not have it.
Old 03-04-2008, 08:31 AM   #5
ArloGuthroJeep
Mr. Hyde!
ArloGuthroJeep's Avatar
The crush sleeve has no bearing on pinion depth. It is used to control pinion bearing preload.
ArloGuthroJeep is offline   Reply With Quote
Old 03-04-2008, 08:32 AM   #6
ArloGuthroJeep
Mr. Hyde!
To the OP, I think that they are torqued to 55 ft-lbs but I really can't remember.
Old 03-04-2008, 03:37 PM   #7
midnghtshdow
Ya i know about the crush sleeve, It says in my book to torque the pinion nut to 310 fp and then back it off to 210 fp is that right?
Old 03-04-2008, 03:47 PM   #8
midnghtshdow
Hey i found a sweet thing on the net for light axle torque specs this might help alot of people.
http://www.pirate4x4.com/tech/billavista/PDFs/Dana_light_axle_service_manual.pdf
Old 03-04-2008, 03:59 PM   #9
a70eliminator
Thats cool, I have yet to set up a dana, I'm speaking from experience on Ford 3rd members where the crush sleeve does set pinion depth and at the same time preloads the bearing, I myself like to use a solid spacer on my Fords. How do you set pinion depth on a Dana? Oh forget it I see now, shims are added to the pinion support at the nose of the pinion and not the crush sleeve.
Old 03-04-2008, 04:11 PM   #10
ArloGuthroJeep
Mr. Hyde!
No, that would be horrible to do. You would be crushing the crush sleeve, and then backing it off making it loose in there and removing any preload you had on the pinion bearings.
Pinion depth is set with pinion shims.
Old 03-05-2008, 05:56 AM   #11
midnghtshdow
I was told crush sleeve is to set pinion spacing and bearing preload..... I called the dealership and they said that the zj came with either a crush sleeve or a shim kit installed. Both the axles i took apart have crush sleeves and i asked them what the price was for the shim and they said 88 bucks compared to 5-18 bucks :O i was like ahhh i will stick with the sleeve But is that not right on the sleeve i am so confused i know when you take one out you really do not want to put it back in. what would you suggest? the site that i found say just to torque it between 160-500 fp what do you think about 350 or somthing?
Old 03-05-2008, 08:21 AM   #12
ArloGuthroJeep
Mr. Hyde!
500ft-lbs for the pinion nut? That is WAY too high. You don't tighten it to a specific torque, to tighten it until the pinion itself rotates to a certain torque, I think 14-19ft-lbs (not positive on that number) - and you measure that w/o the carrier installed (err pretty sure on that, has been a while since I did my gears).
Check out the gear installs on this forum (is my club) to verify against:
http://www.rockfrogs.org/phpBB2/viewforum.php?f=14&sid=893af7b7ed5ab87ebf05299f0d0 f33c4
Old 03-05-2008, 08:23 AM   #13
ArloGuthroJeep
Mr. Hyde!
This thread is your best bet probably: http://www.rockfrogs.org/phpBB2/viewtopic.php?t=2214
Old 03-05-2008, 02:45 PM   #14
midnghtshdow
Meh... So I cant use a torque wrench to measure the pinion resistance? Or can i? Cause that guy on that thread had every goody you need to do a diff i don't
Old 03-05-2008, 02:54 PM   #15
ArloGuthroJeep
Mr. Hyde!
If you were to constantly change it to figure out how much you're applying, but a torque dial would really be best. not expensive. In fact the only two tools he has that are expensive is the bearing puller ($300ish) and the case spreader. I think he got the dial indicator and torque dial thing for like $60. Don't try and set up gears w/o the proper tools or you'll just ruin them.
Glock Forum
