Torque shaft bushing, urgent! - JeepForum.com
post #1 of 12 Old 08-18-2013, 08:06 PM Thread Starter
Rook87
2011 JK Wrangler
On my roadtrip right now and while running Alpine loop and Engineers Pass in Colorado ( so awesome!) the bushing came out. Just got off the trail and only called autozone so Far with no luck. What's my best option while I search around tonight, junkyard? Going to Moab in the morning, any help?
Rook87 is offline
post #2 of 12 Old 08-18-2013, 08:17 PM
HighLonesome
Belief In All Things Jeep
HighLonesome's Avatar
what bushing exactly are you talking about?
HighLonesome is offline
post #3 of 12 Old 08-18-2013, 08:28 PM Thread Starter
Rook87
2011 JK Wrangler
I'll post a pic in a second of the diagram I found on here. Google searching while headed back to town and people are saying it's may be
green?
Rook87 is offline
post #4 of 12 Old 08-18-2013, 08:43 PM Thread Starter
Rook87
2011 JK Wrangler
Ya I was in 4low most the trail and went to put it in 2 wheel but what a task that was, lots of slop so looked underneath and saw it missing, the shaft was all over the place
Rook87 is offline
post #5 of 12 Old 08-18-2013, 08:52 PM Thread Starter
Rook87
2011 JK Wrangler
What about slide a small pvc tube over the shaft for temporary fix? That would fill up the space I'd think
Rook87 is offline
post #6 of 12 Old 08-19-2013, 08:08 AM
speedbucket
Just clamp some vise grips on the shifter tab with the post through it through it or jus put the vise grips onto the shift lever on the transfercase and hop out and shift it manually
V8 zj at 6" . Double tri rear and true 3 link front. Stretched to 108"
speedbucket is offline
post #7 of 12 Old 08-19-2013, 08:40 AM
HighLonesome
Can you just pop the bushing back in?
post #8 of 12 Old 08-19-2013, 08:43 AM Thread Starter
Rook87
2011 JK Wrangler
Good call on the vise grips, it's holding it. Parts store here has a variety pack of bushings I'm going to try aswell when they open up.
Rook87 is offline
post #9 of 12 Old 08-19-2013, 08:46 AM Thread Starter
Rook87
2011 JK Wrangler
It's out on the trail somewhere
Rook87 is offline
post #10 of 12 Old 08-19-2013, 08:51 AM
HighLonesome
ok, I had a green bushing pop out and I put it back years ago and its still there. But I'm talking about the one that goes into the transmission.
Pretty sure this is what you need and good luck.
http://www.quadratec.com/products/52218_0014.htm
post #11 of 12 Old 08-19-2013, 01:15 PM
jnicewan
^ If its the bushing mentioned above you should be able to find them at any parts store. I got my last one from o-reillys it came in a package of other shift linkage bushings from the "help" section, part number ( dorman-help #14041)
jnicewan is offline
post #12 of 12 Old 08-20-2013, 08:27 AM Thread Starter
Rook87
2011 JK Wrangler
Exactly the kit I got from the OReilly here in moab, and I found the stock green bushing
Torn up bad while I was under there. New part didn't fit smoothly but good enough. Thanks guys!
Rook87 is offline
