Is torque converter supposed to lockup? - JeepForum.com
post #1 of 10 Old 11-07-2013, 08:22 PM Thread Starter
Malachi73
Ok, not sure what exactly its called, but I understand that after OD, you should drop a few more RPMs when the Torque Converter locks up, right? Or, am I missing something?
Reason I ask is my 98 doesn't seem to be doing that. My last drop in RPM is OD, I run about 2300 or so RPM at 65mph. Is that normal?
Malachi73 is offline
post #2 of 10 Old 11-07-2013, 08:42 PM
ZeeJay1997
If the overdrive control switch is in the normal ON position, the clutch will engage after the shift to fourth gear, and above approximately 45 mph. If the control switch is in the OFF position, the clutch will engage after the shift to third gear, at approximately 35 mph at light throttle.
you should feel it unlock as you coast down from cruise. mine runs 2k at 65
ZeeJay1997 is offline
post #3 of 10 Old 11-07-2013, 09:09 PM
JasonStebbins
48mph/38mph in my ZJ.
I'm around 1900-2000 @ 65mph. With overdrive off, around 2300 @ 55mph.
Poop
JasonStebbins is offline
post #4 of 10 Old 11-07-2013, 09:13 PM
ZeeJay1997
yeah, mine comes in around 48 too.
post #5 of 10 Old 11-07-2013, 09:25 PM
zj97ltd
My converter stopped locking up on a Monday morning. Wednesday it quit all together and I couldn't move...
zj97ltd is offline
post #6 of 10 Old 11-07-2013, 11:49 PM
dnuccio
you can see if its working by getting up to a cruising speed (45+) and very lightly tap the brake pedal. RPM should jump slightly as the converter unlocks
Reliability is relative
R.I.P. Ratmonkey
dnuccio is offline
post #7 of 10 Old 11-08-2013, 04:19 AM
Candymancan
Like everyone said... You can also keep your foot on the gas (when your above 50mph) and slightly touch your brake pedal it should kick right out and unlock and youll see rpm rise.. If not then your torque convertor isn't working...
Our 4.0 locks at like 50mph, the 5.9 locks at around 35-40mph depending how light im tapping the pedal
Candymancan is offline
post #8 of 10 Old 11-09-2013, 12:55 PM
Mickey_D
Using this evidence, sounds like the OP isn't getting into OD, but the TCL is working fine.
1997 ZJ 5.2 Orvis, Baby!
1953 Willys M100 trailer Tagalong
________________
[_][][][][][][][][_]
#4
Mickey_D is offline
post #9 of 10 Old 11-10-2013, 07:11 AM Thread Starter
Malachi73
Thanks all for the replies.
I'm pretty sure my OD is working, cause if I turn it off my rpms jump up, and if I turn it back on they drop.
But, if I tap the brake pedal at 65mph, the rpms do not jump up. And, I do not get another drop in RPM after 4th gear (OD).
So, it sounds like my TCL is not working.
Any ideas as to the cause.
FWIW, I just bought the Jeep with 158K on the Odometer, but was told by the seller that he just had an engine put in with only 104K on it. So, could it be something that was done wrong with the engine swap?
post #10 of 10 Old 11-11-2013, 12:02 AM
dnuccio
could very well be
R.I.P. Ratmonkey
dnuccio is offline
