torque converter lockup at 70 - JeepForum.com
post #1 of 2 Old 08-16-2009, 04:45 PM Thread Starter
bigstinger
bigstinger's Avatar
I just took a trip into the mountains of Bristol VA. During that trip, my 2004 WJ 4.7l did the following
would jump rpms from about 2k to 2.3k when I would hit a bump doing 70
would not increase rpms when I hit the brake while cruising steady.
Would keep steady rpm at 80.
I stopped off at a shop and asked for a transmission flush. the gentlemen said that he didn't do that anymore, trannies would go bad shortly afterwards. He indicated that he thought it was a bad solenoid.
That follows, because if you hit the brakes, the torque convertor should unlock, right?
I'm a fair wrench, and am pretty sure I can drop the pan off and swap the solenoid. As far as I know, the tranny fluid has never been changed, nor the filters.
I reading this http://hotrodlane.cc/New%20HEMI%20Te...mi%20trans.pdf for info as well.
Anybody got any advice? I'm thinking I should just drop the pan, replace the filters, replace the solenoid and see what gives.
Thougts/advice/writeups?
Many thanks!
4.0L Ford 8.8 4.56 lsd D30 SOA, 4.56 BFG 35 X 12.50 AT's
Ebay Bushwacker knock-off TJ flares - tuffy security console.
Stainless steel braided brake lines skyjacker pitman arm skyjacker hydros
Buy my unit bearings!
bigstinger is offline
post #2 of 2 Old 08-17-2009, 03:31 AM
ratmonkey
R.I.P.
ratmonkey's Avatar
sounds like the brake switch.
ratmonkey is offline
P0740, Torque Converter Clutch, No RPM Drop at Lockup darylkern ZJ Grand Cherokee Forum 3 12-17-2009 01:37 AM
Torque converter lockup cherokeeswede ZJ Grand Cherokee Forum 15 07-02-2008 04:19 PM
Torque converter lockup chrono4 ZJ Grand Cherokee Forum 14 04-17-2008 03:44 PM
Help with torque converter daytondb ZJ Grand Cherokee Forum 0 12-26-2007 02:11 PM
what is a torque converter? pygocentrus ZJ Grand Cherokee Forum 5 09-07-2003 09:09 PM
