Torque Converter - JeepForum.com
post #1 of 5 Old 03-19-2014, 04:32 PM Thread Starter
Brint
Torque Converter
Have a '98 Grand Cherokee 5.9 stock 46RE trans and replaced the solenoid, valve and sensor because it threw a code. My question is, would a bad torque converter still allow me to run through all the gears? It seems to shift fine (I think) but I seem to have one hellofa rotational vibration at about 1900-2200 RPM but seems to smooth out from there.
Brint is offline
post #2 of 5 Old 03-19-2014, 07:36 PM
HighLonesome
Belief In All Things Jeep
HighLonesome's Avatar
At that RPM, I would inspect the motor and trans mounts.
HighLonesome is offline
post #3 of 5 Old 03-19-2014, 08:09 PM Thread Starter
Brint
With 232,000 on the odometer, those were replace 32.000 miles ago but I'll check the torque on all the mounts. Any other thoughts out there? My thinking (& I could be wrong) but if my torque converter were bad, I wouldn't feel it shifting 1st through 2nd, 2nd though 3rd and then into OD?
Brint is offline
post #4 of 5 Old 03-19-2014, 09:59 PM
Motorhead302
Your transmission would have erratic shifting and jerking if your tc was causing a vibration check all mounts bell housing bolts tc bolts and driveshaft ujoints
Motorhead302 is offline
post #5 of 5 Old 03-21-2014, 08:26 AM Thread Starter
Brint
Thanks people. I'm going to take a closer look at the drive shaft U-joints. Would low levels of fluid in the transfer case and front differential cause vibrations?
Brint is offline
