Torn between 4 inch and 4.5 inch lift for my ZJ - JeepForum.com
post #1 of 22 Old 10-03-2009, 09:18 AM Thread Starter
givemeazj
2016 JK Wrangler
ok, so i am torn between what size lift to go with... obviously its 4 in and 4.5 in
i need some help from you guys on 2 things, first what size and second which kit to purchase.
what i would like to maintain:
-good ride quality
-relatively the same gas mileage
-good clearance for some weekend wheeling once in awhile
-reliability of the kit (i dont want to replace things every 6 months)
this would be the 4 inch lifts that i am looking at
IRON ROCK OFF ROAD: Rough Country ZJ 4" Lift Kit
ZJ 4" Performance System
and the 4.5 inch kit:
IRON ROCK OFF ROAD: ZJ 4.5" Lift Kit
any opinions, pictures, suggestions, and/ or advice would be GREATLY appreciated.
givemeazj is offline
post #2 of 22 Old 10-03-2009, 02:29 PM
Area.3.Fiftyone
I always say: "Go big or go home".
If you are going to go through all of the work to install a lift, why not go as big as you can? I'd do the 4.5 if it were me and the kits were the same price.
In either case, you'll want to go bigger later so it really doesn't matter which kit you choose. Once you go up.....it's never high enough IMO.
79' CJ7 - 82' CJ8 - 94' YJ - 96' ZJ
Diagonally parked in a parallel universe.......
Area.3.Fiftyone is offline
post #3 of 22 Old 10-03-2009, 02:45 PM
Tiggerrrrr
I'd rule out the Zone kit as it has fixed control arms.
Either the IRO lift and get adjustable arms later or the rough country lift + track bars and get the missing arms later.
'95 ZJ Limited 4.0
2.25" BB , 31 10.5 15 Treadwright MTG's on Black Rock steelies
Everything "pimpin' Gold" REMOVED!
Looking for a REAR tow hook and bracket!
Tiggerrrrr is offline
post #4 of 22 Old 10-03-2009, 03:06 PM
Kota04SXT
2006 WK
I would personally go with the IRO 4.5.
2013 Ram Express QC 4x4
2006 WK
Kota04SXT is offline
post #5 of 22 Old 10-03-2009, 04:08 PM
soccerfreak3377
IRO 4.5". no even a question, hands down better then Zone
4.5" Lift, 33" BFG KM1, 15x8 Black steelies, RE adjustable trackbars, IRO Sway Bar Links, Pro Comp SS, K&N Intake, Prerunner Front Bumper, Flowmaster Super 44 with turn down, Cobra CB + PA
soccerfreak3377 is offline
post #6 of 22 Old 10-03-2009, 07:04 PM
ZJcrawler45
i'd go with the rough country 4". Its the only one that includes 6 CA's, but no TB's. The 4.5" included none but comes with TB's. 2 TB's is a lot cheaper than 8 CA's
Captain Nate
ZJcrawler45 is offline
post #7 of 22 Old 10-03-2009, 09:20 PM
KDog223
Keep in mind the price of the 4.5" IRO will go up considerably when you add the control arms.
KDog223 is offline
post #8 of 22 Old 10-03-2009, 10:35 PM Thread Starter
givemeazj
2016 JK Wrangler
so it seems like a lot of people are leaning 4.5....
and a lot of people say the 4 inch...
so CA.... control arms...
TB??? (sorry to sound like a noob even though i pretty much am)
post #9 of 22 Old 10-03-2009, 11:33 PM
Virmagicus
Virmagicus's Avatar
Originally Posted by givemeazj View Post
s...
Trackbar
______
Jeff
Virmagicus is offline
post #10 of 22 Old 10-04-2009, 06:20 AM Thread Starter
givemeazj
2016 JK Wrangler
Originally Posted by Virmagicus View Post
Trackbar
______
thanks,
so as far as ride quality, is it safe to say that they are both going to be about the same?
post #11 of 22 Old 02-16-2011, 04:29 PM
Cody1
I would go with the 4.5, The go to rusty'soffroad.com and get fron and rear lower control arms.
__________________________________________________ ______________________________
Rusty's long arms, RE 4.5 F+R inch coils, Rusty's HD front track bar, JKS rear track bar
Rusty's shocks, Drop pitman, 265/75R16 BFGoodrich AT's, Ultra wheels, rear sway bar deleted,
Cody1 is offline
post #12 of 22 Old 02-16-2011, 05:00 PM
coloradojeeper9
If you want to keep as close to the stock ride as possible do long arms. Not only will it give you a smoother ride but better flex on the trails. Only lift kits I have used is rubicon express. But at this point they are closed and you wont be able to buy a new 1. Hopefully they will re open there doors. As for the gas milage doing any kind of lift and larger tires will make it worse. Best thing you can do is replace you gears to handle the larger tires better.
Bigger lift is not always best. I think its crazy to go as big as you can on the lift. The bigger you go the more top heavy you will be. 4.5 inch should be the largest he needs. I got a 4.5 inch rubicon express lift and will not go larger. Right now I got 33 inch tires and will be going to 35's soon with out lifting. I got a friend getting ready to put 37's on his zj with 4.5 inch lift. Yes that is possible but it requires a lot of trimming on the finders. To do 37's he will be cutting the inner and outer finders and sliding the front axle foward 2 inches and rear axle back 2 inches. Ya going through that requires a lot more work but is safer on the trails cause its not as top heavy
It does not matter what you drive as long as you are having fun
"A tree's a tree. How many more do you need to look at?" -Ronald Reagan
"The most terrifying words in the English language are: I'm from the government and I'm here to help." -Ronald Reagan
coloradojeeper9 is offline
post #13 of 22 Old 02-16-2011, 05:17 PM
Mike97ZJ
FYI - you're going to lose gas mileage. The decreased aerodynamics due to the extra height is part of it, but the larger tires that you'll be able to fit are much heavier than the stockers, and the engine will work much harder to turn them and maintain speed unless you regear. Also, if you go with steel wheels, those only compound the problem, as they add yet more weight since they are heavier than alloys. Rotational weight has a big effect on performance, it's not just the fact that you add say 20 or 30 lbs per corner to the Jeep, but the fact that it's in rotational mass.
Between the two kits I like the RC 4" kit, The fact that it comes with new control arms is a big plus.Yes, you'll need to shell out another 190 for a track bar for the front (IRO double shear is a GREAT piece), but if you go 4.5" without control arms, chances are that you'll end up having to buy control arms anyway to make it work right.
I tried 4.5" once on stock arms, the handling was downright scary. I took the lift off within a month of installing it, since I didn't have the $$ for new CA's.
And it's only .5" diff between the two kits...don't let that be the deciding factor.
What size tires do you want to run? That's a big help in determining the correct lift height.
Mike97ZJ is offline
post #14 of 22 Old 02-17-2011, 02:19 AM
ZJ5point2GCL
I say rough country, but you need upper adjustable control arms in the front (trust me) and you need front and rear track bars.
then your getting to the point you might as well go for their 5.5 front long arm kit, it is complete and will ride the best.
your milage will go down, no way around it, to help with it, you can re-gear, stay away from steel rims, find some nice 16 or 17'' alloys or keep your stock rims and add some spacers (nothing wrong with them and they look better than allot of aftermarkets) also dont go all out with the baddest nitto mud tire you can find, stay with something conservative like an A/T like a BFG AT or a nitto dune or tera grappler.
also budget in a new front drive shaft if yours is the CV/ repezza style (with a boot at the diff)
98 Deep Slate Niner- 6''s on 35's ---11 F150 Platinum Pearl White- Modded Tiny V6 with Two Turbos. ---93 Black 5.2 limited- Slowly dying in my Parents Driveway
ZJ5point2GCL is offline
post #15 of 22 Old 02-17-2011, 02:59 PM
Cody1
or you could just throw on a BB for $200 and some 31's and it will ride great....haha
Cody1 is offline
4 inch springs on a 3 inch lift?? zj333 ZJ Grand Cherokee Forum 8 12-20-2009 05:02 PM
3 inch lift.. 1 inch bb? coopdc78 ZJ Grand Cherokee Forum 8 11-09-2009 07:03 PM
just did my 4 inch iro lift str8stock4l ZJ Grand Cherokee Forum 2 12-10-2008 10:08 AM
4 inch lift help joshall ZJ Grand Cherokee Forum 3 12-06-2008 02:25 PM
2 Inch lift vs. 2 Inch Spacers jeep_05 WK Grand Cherokee & XK Commander Forum 19 06-06-2008 01:57 PM
