Tool to remove Power Steering Pump Pulley? A few questions... - JeepForum.com
post #1 of 9 Old 01-14-2009, 12:27 PM Thread Starter
Jsun
Hi all,
Luckily I pulled out of rush hour traffic before my power steering pump seized on me & leaked out all the fluid.
I have an idea of how to remove the pump, seems simple enough, but my question is... Will I need a special puller of some sort to remove the old pulley to the new pump? Is it held on by a torx screw?
Also, seeing as tho it seized up on me or close to it, I probably have debris in the fluid, so I'm thinking I'll need to completely flush the power steering fluid from the gear box? Could I have done any damage to the gear box? Is there a chance of debris being in there?
And last, what type of fluid is required? Just your normal day to day PS fluid?
Thanks!
95 GC Ltd. V8
(in search of a owners manual)
"It aint no thang but a "Jeep" thang baby..."
Jsun is offline
post #2 of 9 Old 01-14-2009, 01:17 PM
BLACKzj52
go to autozone and rent a pulley puller/pusher tool
ull get all ur money back when u return it as long as u didnt break it. it works great, i had to use one
oh and i used just standard dot approved ps fluid
BLACKzj52 is offline
post #3 of 9 Old 01-14-2009, 01:20 PM
ZJPunk98
I agree with black.. rent the puller and then return it. a flush is probably a good idea.
160K on my jeep and i haven't personally flushed the fluid yet. Its on my todo list this spring.
Erik
98 ZJ 5.2L JGC Limited Sold
02 4.7L HO JGC Overland
ZJPunk98 is offline
post #4 of 9 Old 01-14-2009, 01:28 PM Thread Starter
Jsun
What about the torx screw?
The reason I ask, it was late when I pulled in & it appeared to have a bolt holding the pulley in place, but couldn't tell if it was a hex head or torx?
Thanks guys!
95 GC Ltd. V8
Jsun is offline
post #5 of 9 Old 01-14-2009, 03:09 PM
MeWJWifeZJ
There shouldn't be any bolt holding the pulley on, it's a pressure fit design
Praise to a Child is like Sunlight to Flowers
Traded away the WJ to get a commuter
We finally got another Jeep after 5 years without. Too bad it's ALL stock.
MeWJWifeZJ is offline
post #6 of 9 Old 01-14-2009, 03:17 PM Thread Starter
Jsun
That would explain why I couldn't tell...lol
Thanks!
95 GC Ltd. V8
Jsun is offline
post #7 of 9 Old 07-03-2013, 05:42 PM
Lone Gunman
Looks like I will be doing this in the next few days.
Lone Gunman is offline
post #8 of 9 Old 07-03-2013, 06:05 PM
Lone Gunman
Also, do I have to remove power steering pump to remove pullet or can I remove while still on the motor?
post #9 of 9 Old 07-06-2013, 08:00 PM
kodenz
I want to add to his last question. If the pulley is already off( let's say it exploded) do you need the pump off to replace it? And is there anything else I must do beside put a new pulley on and belt? Sorry if I hijacked ur thread here but I just so happen to read this post then my wife called saying the power steering went out
5.2L 1997 ZJ limited Up-Country+2in BB
kodenz is offline
Noisy power steering pulley- 5.9 squashman702 ZJ Grand Cherokee Forum 5 08-22-2009 06:46 AM
A few questions on power steering pump speedbullet2 ZJ Grand Cherokee Forum 4 01-22-2008 12:54 PM
power steering pump pulley jeepzj9304 ZJ Grand Cherokee Forum 3 03-13-2006 01:18 AM
Need Power Steering Pulley HokieZ ZJ Grand Cherokee Forum 4 08-23-2005 08:11 AM
