-   -   Tool to remove Power Steering Pump Pulley? A few questions... (http://www.jeepforum.com/forum/f13/tool-remove-power-steering-pump-pulley-few-questions-671190/)
Jsun 01-14-2009 11:27 AM
Hi all,
Luckily I pulled out of rush hour traffic before my power steering pump seized on me & leaked out all the fluid.
I have an idea of how to remove the pump, seems simple enough, but my question is... Will I need a special puller of some sort to remove the old pulley to the new pump? Is it held on by a torx screw?
Also, seeing as tho it seized up on me or close to it, I probably have debris in the fluid, so I'm thinking I'll need to completely flush the power steering fluid from the gear box? Could I have done any damage to the gear box? Is there a chance of debris being in there?
And last, what type of fluid is required? Just your normal day to day PS fluid?
Thanks!
BLACKzj52 01-14-2009 12:17 PM
go to autozone and rent a pulley puller/pusher tool
ull get all ur money back when u return it as long as u didnt break it. it works great, i had to use one
oh and i used just standard dot approved ps fluid
ZJPunk98 01-14-2009 12:20 PM
I agree with black.. rent the puller and then return it. a flush is probably a good idea.
160K on my jeep and i haven't personally flushed the fluid yet. Its on my todo list this spring.
Jsun 01-14-2009 12:28 PM
What about the torx screw?
The reason I ask, it was late when I pulled in & it appeared to have a bolt holding the pulley in place, but couldn't tell if it was a hex head or torx?
Thanks guys!
MeWJWifeZJ 01-14-2009 02:09 PM
There shouldn't be any bolt holding the pulley on, it's a pressure fit design
Jsun 01-14-2009 02:17 PM
That would explain why I couldn't tell...lol
Thanks!
Lone Gunman 07-03-2013 04:42 PM
Looks like I will be doing this in the next few days.
Lone Gunman 07-03-2013 05:05 PM
Also, do I have to remove power steering pump to remove pullet or can I remove while still on the motor?
kodenz 07-06-2013 07:00 PM
I want to add to his last question. If the pulley is already off( let's say it exploded) do you need the pump off to replace it? And is there anything else I must do beside put a new pulley on and belt? Sorry if I hijacked ur thread here but I just so happen to read this post then my wife called saying the power steering went out
The time now is 02:29 AM.
