TNT Dana 44a Truss install Question... - JeepForum.com
post #1 of 39 Old 03-03-2014, 01:53 PM Thread Starter
evan1395
So before I get my locker and whatnot for the rear, i'd really like to truss that rear end. I ran across this truss, seems like a good price and great quality.
In the install instructions it mentions you having to drop the entire axle assembly from the vehicle. While using this truss, do I need to buy the bracket kit? Or can I utilize the stock control arm brackets. Can I simply just buy the truss by itself and have it go get welded on?
http://www.tntcustoms.com/rear_axle_.../Dana_44a.aspx
J.E.E.P (Just Empty Every Pocket)
evan1395 is offline
post #2 of 39 Old 03-03-2014, 02:36 PM
Technohead
Call them. It appears the truss itself is useless without the optional bracket kit.
-Eric
Technohead is offline
post #3 of 39 Old 03-03-2014, 02:43 PM
96zj4me
44a? Not much aftermarket support 9inch d60 d44 8.8 let the arguments begin
96zj4me is offline
post #4 of 39 Old 03-03-2014, 03:43 PM
riot1987
I looked at another truss from them as well. It seems they have great prices on their trusses. ...Until you add on all the necessary brackets and mounts. Then it really seems to add up quick. I too, would call or email them to see for sure
Build thread^^
riot1987 is offline
post #5 of 39 Old 03-03-2014, 04:11 PM
Technohead
BTW, why do you want to truss the rear end? Seems like a waste of money to me.
Lock it. Wheel it. Have fun.
-Eric
post #6 of 39 Old 03-03-2014, 04:13 PM Thread Starter
evan1395
I heard the 44a was notorious for warping if you lock it up and throw bigger meats on it. Its an aluminum housing, right? :P
evan1395 is offline
post #7 of 39 Old 03-03-2014, 04:32 PM
PolkaPower
A rear diff skid would be a good idea.
PolkaPower is offline
post #8 of 39 Old 03-03-2014, 04:50 PM Thread Starter
evan1395
I read about a skid/truss combo made by a "High Mountain" company or something? It was a bottom mount truss as opposed to the traditional top mount.
evan1395 is offline
post #9 of 39 Old 03-03-2014, 05:41 PM
SAR-Swimmer
SAR-Swimmer is offline
post #10 of 39 Old 03-03-2014, 06:01 PM Thread Starter
evan1395
Originally Posted by SAR-Swimmer View Post
Thats the one!!!
Thanks buddy!
evan1395 is offline
post #11 of 39 Old 03-03-2014, 07:08 PM
ejschultz
I'm skidded, I just need a truss then I think I'll have a pretty rock solid axle. Although I doubt 31s are going to warp my locked 44A.
ejschultz is offline
post #12 of 39 Old 03-04-2014, 09:21 AM
speedbucket
if your welding on a truss its much better to have the axle out from under the vehicle to weld anything on it. its alot easier to get it square and aligned properly. that being said, if your are welding on an axle its a very good idea to remove all the bearings easy to get to, pull the shafts and carrier and keep the ground cable as close as possible to where you are welding. if a charge looking for ground goes across a bearing it will leave a bur. An engineering friend was part of a project in college where a guy decided he was going to weld some stuff on their 120 mph go kart. he had the ground on the frame and was welding on the axle. he seized all the drive bearings and 1200$ worth of heim joints from the arc jumping through the heim liners.
V8 zj at 6" . Double tri rear and true 3 link front. Stretched to 108"
speedbucket is offline
post #13 of 39 Old 03-04-2014, 09:32 AM
PolkaPower
You can also warp the axle if it heats up too much. The shop back in Vegas I used said they got that a lot from customers bringing it in to have it fixed.
post #14 of 39 Old 03-04-2014, 09:55 AM
Technohead
Its fine unless you are jumping . . . in which case you need a lot more than a truss.
A truss does not get you further down the trail. A locker does.
-Eric
post #15 of 39 Old 03-04-2014, 09:57 AM
speedbucket
yup, weld in short sections and jump around. my buddy made this axle for his super secret project and used a really expensive alignment rod and turned down pucks to keep from warping.Eaton Ho72 center with kinpin outers...
linky - http://www.dso4x4.com/forums/showthr...707#post200707
