tires rubbing and wheel spacers - JeepForum.com
post #1 of 7 Old 10-11-2009, 08:32 AM Thread Starter
Izzy
I have 265/75/R16's mounted on stock 97 limited rims and a 2.25" BB. I looked through the tire size sticky which indicated that the stock rim had the appropriate backspacing before buying the tires, but they bind at full lock and rub on the sway bar and control arms.
What size wheel spacers should I look for? I know that getting new rims would take care of it, but I like the look of the stockers.
Cheers,
Izzy
Izzy is offline
post #2 of 7 Old 10-11-2009, 08:43 AM
GraKee99
Rapist Wit
GraKee99's Avatar
1.25 or 1.5". You could just adjust your steering stops.
Brian
WJ, WK, CJ5
GraKee99 is offline
post #3 of 7 Old 10-11-2009, 08:48 AM Thread Starter
Izzy
I was thinking about that option as well. I like it because it only costs washers!
Izzy is offline
post #4 of 7 Old 10-11-2009, 03:29 PM
Colorado 5.9
Colorado 5.9's Avatar
Like the other guys have said. You don't really need spacers with 265's. Just ad one or two warshers to the steering stops. That will stop the rubbing.
ZJ 98 5.9 LTD. Lots of mods. 7" T&T's Long Arm Lift ,BFG KM2"s,35X12.50x16's,4:56's, Vanco brake upgrade, M1intake,Holley52mmTB,MikeLeach Headers,, Arb'ed HP D30,Aussie Locked rear,Procomp MX6 Shocks,Arb front,RearTR bumpers,ECT.ECT.
Colorado 5.9 is offline
post #5 of 7 Old 10-11-2009, 05:10 PM
southernmudzj
where are the steering stops. my 31 10.50s rub on my lower control arms at full lock.
sorry to jack the thread
96 zj. 31x10.50 uniroyal awts. 2.25 bb rough country 9000 shocks. rustys transmission crossmember
cobra radar detector future mods:rustys 5.5 long arm kit and smittybilt xrc8
southernmudzj is offline
post #6 of 7 Old 10-11-2009, 05:25 PM
sadass
I used 1.25 inch spacers. I wanted to use my stock rims with my 265/75/r16's , before the spacers I was hitting my rear Springs on full flex and both my front lower control arms on a full turn. I wanted not to affect my turn radius so I went with the spacers and all problems were resolved,
5NineZJ,35mtr/k IRO 7" LA F/R Detroit F/HP-4.56 R/Aussie 44A. ARB Snorkel/JRC Sliders/ Protofab w/9500S./Bushwhackers. Novak242 TCcable.
sadass is offline
post #7 of 7 Old 10-12-2009, 06:38 AM
Colorado 5.9
See the long bolt with the clean washer? You'll see that it's tack welded to the nut. Just take it out & throw a washer or two in there. Start with one & then see if they rub still.
2" BB, 5" wheel spacers, 16x7 wheels...biggest tires? TX02WJ ZJ Grand Cherokee Forum 9 07-07-2010 01:15 PM
steering wheel rubbing noise? steve0410 ZJ Grand Cherokee Forum 2 04-26-2009 09:18 PM
WJ Rubbing Rear of Back Wheel Well PSYCH0 ZJ Grand Cherokee Forum 12 09-14-2007 01:18 PM
fitting 31x1050-15" tires with wheel spacers jdk3034 ZJ Grand Cherokee Forum 15 11-21-2006 12:09 PM
Another BB question: Tires, wheel spacers & trimming 01bluegray ZJ Grand Cherokee Forum 11 03-30-2006 10:35 PM
