TIres and gears - JeepForum.com
post #1 of 16 Old 03-19-2003, 08:34 AM Thread Starter
sneezeweed
TIres and gears
I have a 93 ZJ limited (straight 6 Alltime 4wd, Automatic) all stock except for a 1 inch body lift and rancho 5000's (thats how I bought it) I am putting on an additional 4.5 in RE suspension lift and replacing the 1 inch w/ a 2 inch body lift. I also want to run 31 or 33 MT/r's. Will I need to change gears when I run these bigger tires or will the stock ones perform well enough. I am also installing ARB lockers front and rear will this have any effect on the gear ratios?
93 zj in the works
http://community.webshots.com/user/sneezeweedzj
sneezeweed is offline
post #2 of 16 Old 03-19-2003, 04:38 PM
RufftyTuffty
RufftyTuffty's Avatar
You might struggle with 33's and the I6 using the stock 3.73.
4.10 for 33's will be fine...you might want to jump straight to 4.56 gears if you plan on running 33+ tires in the future.
Check out some of the gear calculator charts.....
97 V8 TSi 7" RK LA/36s/4.88s/ARBs/TERA 60/8.8/Crane/PSC
RufftyTuffty is offline
post #3 of 16 Old 03-19-2003, 05:33 PM
Black96ZJ
no body lift
FYI You can't put a body lift on a grand cherokee
Black96ZJ is offline
post #4 of 16 Old 03-19-2003, 05:55 PM
KillerZJ
KillerZJ's Avatar
yea, and how do you have full time 4WD with the I6?
Looking for E36 325i(s) 5 speed only. Jeep is for sale $3,000 takes it. E-mail only.
*Sale Pending*
Wow no pictures in sig? F*cking gay.
KillerZJ is offline
post #5 of 16 Old 03-20-2003, 10:03 AM Thread Starter
sneezeweed
It has all time 4hi. And you can put a body lift on a ZJ. Quadretec has a 2 inch bodylift for the 93 - 98 ZJ. Thanks for the gearing info.
93 zj in the works
post #6 of 16 Old 03-20-2003, 10:04 AM Thread Starter
sneezeweed
Sorry it has all time 4hi.
93 zj in the works
post #7 of 16 Old 03-20-2003, 10:06 AM Thread Starter
sneezeweed
will the 4.56 gears work with 31's also?
93 zj in the works
post #8 of 16 Old 03-20-2003, 01:38 PM
Intrepidjeep
Intrepidjeep's Avatar
I was thinking the Grand Cherokee was unit-body with integrated frame? Just wondering how a body lift would work?
-- Marcus
Cape Canaveral, Florida
2005 Jeep Grand Cherokee Laredo 4.7L
2005 Dodge Durango SLT 4.7L
Intrepidjeep is offline
post #9 of 16 Old 03-20-2003, 04:30 PM
Black96ZJ
you CAN NOT put a body lift on it, it is impossible. what is the link to this " body lift" for a ZJ?
post #10 of 16 Old 03-21-2003, 08:45 AM Thread Starter
sneezeweed
It is in the quadratec monthly catalog. I will double check but I do believe they had a 2 inch body lift for the 93-98 ZJ.
93 zj in the works
post #11 of 16 Old 03-21-2003, 08:55 AM
Texas ZJ1
Jeep Jedi Master
Texas ZJ1's Avatar
1994 ZJ
Sneeze,
the lift (body) is actually a coil spacer. You can add that to the top of the 4.5. You're going to go from stocker to Tonka very quickly. You will need to regear for tires because your 3.55s aren't going to cut it.
You will need to get all adjustable control arms and a new front drive shaft if yours is the CV one.
Hunter
04 4.7 HO, limited
08 Z71 Suburban, front leveling kit with rear spacers. 285/65 18s Nitto TerraGrappler G2s
94 5.9 Laredo 6.5 RE lift with 35 Maxxis Bighorns
and 33 Bridgestone Duelers
Detroit and true trac
Red Jeep Club Member
REDNECK JCM
Texas Jeep Owner #6
USN Jeep Club #4
602.841.3355
For your performance needs:
480.998.366
Texas ZJ1 is offline
post #12 of 16 Old 03-21-2003, 08:55 AM Thread Starter
sneezeweed
I was wrong
93 zj in the works
post #13 of 16 Old 03-21-2003, 08:56 AM Thread Starter
sneezeweed
I apologize it is a polyurethane suspension lift.
(PRODUCT DESCRIPTION
Here's a great way to lift a '93-'98 Grand Cherokee to fit 30" and most 31" tall tires without spending lots of time and money in the process. It's a simple yet well engineered method of suspension lift. The Kit includes coil spring spacers for the front & rear along with longer bump stops. Allows for greater tire clearance without compromising the factory ride quality and with a less complex installation. )
Sorry I mistook this for a body lift
93 zj in the works
post #14 of 16 Old 03-21-2003, 08:58 AM Thread Starter
sneezeweed
Where would i get the appropriate driveshaft. Are you talking about the U joint equipped ones.
93 zj in the works
post #15 of 16 Old 03-21-2003, 01:25 PM
Beerman
there are 249 t-cases in the limited with the inline 6 or the v8
93 Grandcherokee limited V8 with lockers,lift,winch and other things
Beerman is offline
WJ Speedo with 35" tires and 4.56 gears Wheelin98TJ ZJ Grand Cherokee Forum 14 11-23-2009 01:12 PM
4.0 + stock tires + 4.11 gears? the88thpianoman ZJ Grand Cherokee Forum 14 02-14-2009 01:15 PM
What gears should I run for 38" tires? Tigggger ZJ Grand Cherokee Forum 12 02-13-2009 02:58 AM
Opinions on gears for 32 to 33 tires? 04WJfreedom ZJ Grand Cherokee Forum 16 04-15-2008 01:36 PM
Noise Tires & Gears cynthiaj WJ Grand Cherokee Forum 1 06-27-2003 07:01 AM
