tires cant outward - JeepForum.com
Go Back JeepForum.com > Models > Jeep Grand Cherokee & Commander Forums > ZJ Grand Cherokee Forum > tires cant outward
Rockridge 4WD IS Taking Zone Offroad Suspension Lift Kits Rough Country Jeep Suspension Deals at Rockridge 4WD!NEW JK WRANGLER GRAB BARS NOW at ROCKRIDGE4WD
Unread 08-28-2014, 08:53 PM   #1
derekroth91
tires cant outward
my front two tires look like the cant in an outward direction? is this normal?/bad? also it looks like drivers side wheels have spacers and passenger side doesnt, in other words drivers side tires stick ou more than the other. is that bad/does it matter?
derekroth91 is offline   Reply With Quote
Unread 08-28-2014, 09:17 PM   #2
Bear304inc
If your tires are both trying to turn away from each other it cant be good. Sounds like time for an alignment. As far as your wheels, take them off and see whats on there. If you have spacers on one side only id take them off, possible cause of your toeout.
Bear304inc is online now   Reply With Quote
Unread 08-29-2014, 02:46 AM   #3
PolkaPower
Is it lifted?
PolkaPower is offline   Reply With Quote
Unread 08-29-2014, 05:06 AM   #4
Technohead
Old School
Technohead's Avatar
Its looks like spacers or it has spacers? Only you can answer that by opening your eyes and looking.
Signature says Rough Country 3" lift. Chances are the kit did not include an adjustable track bar hence the whole axle shifts to the driver's side.
Technohead is offline   Reply With Quote
Unread 08-29-2014, 07:19 AM   #5
derekroth91
Would an adjustable track bar fix the problem? Can I just get under it and see spacers with the naked eye or do I have to take the wheel off for that? If there only one side can I assume that they were put on for looks and not to get the wheels away from the suspension so nothing rubs?
Unread 08-29-2014, 12:52 PM   #6
kg6mov
Hears the voices
kg6mov's Avatar
Stock trackbar with 3" lift would cause the driver side shift on the axle.
Either check the toe yourself or have a shop check it. It is possible that it is out of alignment.
1996 ZJ Green Laredo V8, 2.5" OME and Bilsteins, 31's, Holes drilled in the roof.
1998 ZJ Platinum Limited 5.9, New engine and trans, no front driveshaft, but it's pretty
"Whats wrong with a PT Cruiser?"
"Coulda had a V8!"
96 build thread
Niner build thread
kg6mov is online now   Reply With Quote
Unread 08-29-2014, 01:03 PM   #7
derekroth91
I just had it aligned no more than a week and a half ago thinking that could be the problem. The driver side axle shift refers to the wheel sticking out on one side of the car correct? The tires though loom like this when standing front the front / \ a little exagerrated but gets the point across. Is that alignment also or because of the stock track bar? What kind adjustable track bar should I get? Some just say adj. Track bar and others say adj. Track bar 3in 4 in or so on and so on
Unread 08-29-2014, 01:58 PM   #8
PolkaPower
How can you not know if you have a lift or not?
Unread 08-29-2014, 02:18 PM   #9
derekroth91
I didn't ask if it was lifted. Someone else did
Unread 08-29-2014, 02:37 PM   #10
PolkaPower
I asked if it was lifted you dummy! If it's lifted with no adjustable track bar, then the front axle will be pushed out to the drivers side and the rear axle will be pushed out to the passenger side. That's why you need adjustable track bars, so you can center the axles under the Jeep.
Unread 08-29-2014, 02:40 PM   #11
derekroth91
Okay thanks! And any idea why my tires would do that?
Unread 08-29-2014, 02:44 PM   #12
Texas ZJ1
Jeep Jedi Master
Texas ZJ1's Avatar
1994 ZJ
It was never aligned after the lift. Causing your tire cant.
00 4.7 Laredo...stock
94 5.9 Laredo 6.5 RE lift with 35 Maxxis Bighorns
and 33 Bridgestone Duelers
Detroit and true trac
Red Jeep Club Member
REDNECK JCM
Texas Jeep Owner #6
USN Jeep Club #4
http://www.kevinsoffroad.com/
602.841.3355
For your performance needs:
kolak@kolakperformance.com
480.998.3661
Texas ZJ1 is offline   Reply With Quote
Unread 08-29-2014, 02:54 PM   #13
derekroth91
Okay thanks a bunch guys! One more question though. Do I need adj control arms as well ? Whats their purpose and what problems arise without adj co trol arms when they're needed? I have wide tires and rims if that has anything to do with any of these scenarios as well
Unread 08-29-2014, 04:44 PM   #14
PolkaPower
Without the specs on your lift and tire combo it's hard to give advice. Now I have a wine tasting in Tourasi tomorrow and then Pompeii on Sunday so I probably won't be able to to answer until Tuesday unless I let the wife drive the Lambo.
Unread 08-29-2014, 05:21 PM   #15
Mickey_D
One thing I think everyone trying to answer questions here isn't getting is that the OP isn't asking about toe in/out. He's asking about pos/neg camber (which to my understanding is next to impossible unless the axle is bent). I asked about this a while back myself, except it sounds like mine is opposite of his.
1997 ZJ 5.2 Orvis, Baby!
1953 Willys M100 trailer Tagalong
________________
[_][][][][][][][][_]
Mickey_D is offline   Reply With Quote
