tire tread and transfer case - JeepForum.com
post #1 of 16 Old 01-07-2009, 04:34 PM Thread Starter
minimodes89
minimodes89's Avatar
Hey I have a 98 ZJ with full time 4 wheel drive, and when I went to the dealer to get an inspection they said I had to replace all for tire because one of them had more tread than the others or else it would mess up my transfer case. I was wondering is this true or are they just trying to get more money.
minimodes89 is offline
post #2 of 16 Old 01-07-2009, 04:39 PM
CMARJEEP
CMARJEEP's Avatar
Its true. If you have AWD your tires have to be all the same size. So that means getting 4 new tires. If not, you will eventually wear out your transfer case because that one mis sized tire will be turning faster/slower than the others.
CMARJEEP is offline
post #3 of 16 Old 01-07-2009, 05:26 PM Thread Starter
minimodes89
Alright thanks alot
post #4 of 16 Old 01-07-2009, 06:06 PM
subliminal
1997 XJ Cherokee
Before you waste money on new tires how bad are they? If 1 or more of them are bald then maybe that MIGHT throw it off but even that I doubt it. As long as the tires are all the same size you should be okay. It sounds to me like theyre just trying to get more money.
subliminal is offline
post #5 of 16 Old 01-07-2009, 06:25 PM
4jeepers
I have to agree with subliminal, if you still have tread on all the tires and they are the same size you should be alright unless one or two are worn a heck of a lot more then the other two. Even then damaging the T-case is iffy!
4jeepers is offline
post #6 of 16 Old 01-07-2009, 07:58 PM
my96grand
as long as they are the same size,i don't see a major problem.tire wear is something that i would assume would be considered by the engineers who designed the tc.now i would consider, if you have some really worn tires,changing all 4.
new here,hello everyone. 96 zj,4.0. skyjackers,flow 40 series,2.5 tailpipe,hiflow cat.memphis amps,10 memphis sub,mb quarts all around.acell cap,rotor wires and coil.
my96grand is offline
post #7 of 16 Old 01-07-2009, 08:27 PM
Mickey_D
I keep my front tires at 36psi and my rears at 32psi so they are EXACTLY the same diameter.
1997 ZJ 5.2 Orvis, Baby!
1953 Willys M100 trailer Tagalong
________________
[_][][][][][][][][_]
#4
Mickey_D is offline
post #8 of 16 Old 01-07-2009, 08:46 PM
nashmd454
nashmd454's Avatar
never ever go to a stealership...all they want is your money and will conjure up crap to get it. Though it is true that if one tire is not of the same size then it will burn up the Viscous Coupler in your 249 tcase....that doesn't mean that you need a new tcase at all. I would say take a coin to all 4 tires and place it in between the threads and if they are roughly all the same then you are fine. It is a good practice though with that style of tcase to replace all 4 at a time....just not through the dealer...you can get tires much cheaper somewhere else too.
96' JGC V-8 5.2L ltd.
way too much to list.
Thought for the day:
If GOD gave HIS only son for us...can't we at least give HIM an hour of our time a day.
nashmd454 is offline
post #9 of 16 Old 01-07-2009, 08:58 PM
Kramer H
Built and Supercharged 47
Kramer H's Avatar
for an awd t-case on a jeep, your allowed 3 3/32nds of tread difference before it starts to damage components and/or cause premature drivetrain wear.. (i work at Les Schwab here on the west coast) hope this helps
Built Beater 01 WJ
Swapped, SUPERCHARGED Locked, Lifted and Long Armed.
02 Cummins. It has a smoking problem, And it wont quit.
K8 GSXR 1000- Racefit,Comp Werks,Puig,Woodcraft,B2 Industries,55W HID'S, R&G Engineering, Two brothers, ASV, DDM, "The pantie dropper"
Kramer H is offline
post #10 of 16 Old 01-07-2009, 10:39 PM
trailblazr81
How much is 3 3/32nds? Is that the same as 9/32nds?
1996 ZJ, 318, F>R, no sways, CAI, Glasspack Exhaust, 265/75/16 Muds
trailblazr81 is offline
post #11 of 16 Old 01-08-2009, 01:41 AM
Kramer H
Kramer H's Avatar
no, thats 6 32nds more haha, if you go to your local tire shop or even a stealership, they should have a "tread depth gauge) i have one, all it does is measure your tread depth, a "32nd" is the measurment, you could have anywhere from 2 32nds (the most worn out your tire can legaly be until cops can start writing tickets, also know as the penny measurment) to 24 32nds which is like a brand new mud tire, all of your tires should be atleast within 3 32nds of eachother..
Built Beater 01 WJ
Kramer H is offline
post #12 of 16 Old 04-01-2013, 02:49 PM
kappa080
So I am the guy bumpin a four year old thread.... I am a student/ski bum who bought tires and wheels of craiglist after big o told me i cant just buy two tires for my Qd Zj. Even after i made the statement "thats fine sale me two and I will just drop the front drive line." So my question is can I do that will it save my transfer case?
kappa080 is offline
post #13 of 16 Old 04-01-2013, 02:57 PM
ratmonkey
R.I.P.
ratmonkey's Avatar
it'll burn the one in your vehicle up even faster. you have the early version and it's not the same as the later one. the later one can be disconnected from the front. the early can not. you would also roll in park.
3/32" is the maximum tread depth difference allowed. and all tires must be the same BRAND, MODEL, and MARKED SIZE.
ratmonkey is offline
post #14 of 16 Old 04-02-2013, 09:33 AM
kappa080
So two summers ago my front driveline need to be rebuilt so I rolled around all summer with out it. never once rolled in park and when i put it back in the fall, never once had an issue. I work at a ski resort and four wheel still works great. With all due respect to your 19000 post but I don't think your right
kappa080 is offline
post #15 of 16 Old 04-02-2013, 10:44 AM
ratmonkey
R.I.P.
ratmonkey's Avatar
Needs a bit of a hill to roll, and it rolls slowly.
It wouldn't make 4wd not work, it makes the front locked all the time. So you get skipping in tight turns and heavy wear on front end components.
Its OK, you're new and don't know much about the unique problems these vehicles have over others.
rear aussie locker + difference in tire tread = potential problem? the88thpianoman ZJ Grand Cherokee Forum 3 10-06-2008 07:09 AM
need tire or (TIRES) AND TRANSFER CASE briguy55 ZJ Grand Cherokee Forum 7 09-15-2008 11:26 PM
Silly tire tread question... beepbeep13 WK Grand Cherokee & XK Commander Forum 4 09-15-2007 02:39 PM
L-R rear tire tread depth difference -- will this hurt the limited slip diff? jo8243 ZJ Grand Cherokee Forum 9 05-21-2006 04:09 PM
Tire Deler damage transfer case??? Slightly_Off ZJ Grand Cherokee Forum 1 12-21-2002 01:02 PM
