Tire size on OEM 5.9L wheels? - JeepForum.com
post #1 of 5 Old 02-02-2010, 12:47 AM Thread Starter
WJOverland
2003 WJ
If i was to run an IRO 3.5" in the near future...
IRON ROCK OFF ROAD: ZJ 3.5" Lift Kit
what size tire would i be able to clear (i read 31s or 32s somewhere here i believe) but the width is what bothers me as i am unaware of how wide one can go safely on these wheels
2003 WJ Overland (Brilliant Black Crystal Pearl Coat) 76k & Counting
1998 ZJ 5.9L Limited (Dark Slate Grey) 79k & Counting
I want a CJ-8 Scrambler.
WJOverland is offline
post #2 of 5 Old 02-02-2010, 11:45 PM
madZJ
I'm running 265/70R16 with no problems. Thats 26.5 centimeters wide or just over ten inches I belive. You might be able to go 11.5, the shop you get your tires from should know.
madZJ is offline
post #3 of 5 Old 02-03-2010, 01:57 PM
Scottso699
2006 WK
I have 285/75r16s on my 5.9 Rims. That's about the limit I'd imagine.
Scott
2006 WK Overland, OME HD Springs F&R, Bilstein 4600 Struts, 1.5" Rear Spacer, 265/70/r17 BFGs
Scottso699 is offline
post #4 of 5 Old 02-03-2010, 02:14 PM
Zwildm30
Yeah Im running the 285/75r/16s on my 5.9
1998 Jeep Grand Cherokee 5.9 Limited
Zwildm30 is offline
post #5 of 5 Old 02-03-2010, 02:46 PM
rustynail
I'm running 285's as well and would say that is for sure the limit otherwise your tires will wear in the middle.
If you want to squeeze 33's onto a 3.5 inch lift you might want to look at running 255 85 16's otherwise run 265 75 16.
- Russ
5.9 ORVIS 33x12.5 MTR-Kevlar, 7" fr adj IR LA's, 7" rr adj RE SF SA's, adj JKS TB's, RE SB disc, RE Springs, JKS ACOS, 13" RS9000XL's, OME SS, NP231, Durango box, IR Sliders, IR Skid, 3" Flowmaster 70, K&N, Superwinch EPi9.0, Optima Yel, 2 air comp, Alpine, Garmin, Sunroof
rustynail is offline
WJ spare tire, max tire size in back? EarpWJ WJ Grand Cherokee Forum 18 09-08-2010 03:30 PM
Tire size- stock wheels cyberZJ ZJ Grand Cherokee Forum 3 01-27-2010 03:01 PM
Tire size match to lift size zjeepin ZJ Grand Cherokee Forum 5 09-04-2005 12:26 PM
Tire Size v. Lift Size Chart Meerkat ZJ Grand Cherokee Forum 10 02-01-2005 04:56 AM
What size wheels? kfcforlife ZJ Grand Cherokee Forum 1 01-08-2005 02:05 PM
