tire size 96 grand cherokee - JeepForum.com
post #1 of 11 Old 05-06-2013, 08:19 PM Thread Starter
larados
I put a 3.5 IROR suspension lift and bushwhacker flares on my 96 zj laredo 4.0 L 373. I did fender cutting following the instructions. I primarily use this for commuting to and from work a few miles from home. I plan on buying wheels and tires. What tire size and wheel offset would you recommend. I would love to stuff 33" but my dad thinks we should go smaller due to fuel economy and possible rubbing issues. Also I would like duratrac wrangler 33x12.5 would these work or are they too tall and or wide, also should I go 16 in rims or 15 considering I'm replacing the wheels anyways. thanks
larados is offline
post #2 of 11 Old 05-06-2013, 08:42 PM Thread Starter
larados
Here is a pic. I will post more tomorrow. I painted all the cladding and bumpers black to match flares! Also painted the frame and undercarrage with black rustolium. I got in there " all deep like".It looks trick!
larados is offline
post #3 of 11 Old 05-06-2013, 11:36 PM
BigJohn96ZJ
Since you got the bw flares and a 3.5" lift i would think you could squeeze 33/12.50s with very minor rubbing but 32/11.50s would fit better. Most recommend 4" backspacing for the wheels. Run 15 or 16 inch rims depending on what you want.
96 ZJ Laredo 4x4, 5.2l, 2.25" budget boost, 31 bfg m/t KM2
BigJohn96ZJ is offline
post #4 of 11 Old 05-07-2013, 05:33 AM Thread Starter
larados
Thank you! I just want as much info as possible before dishing out $1400 for wheels and tires. If any one else has this setup or knows anyone running this setup please post your findings. You guys rock!
larados is offline
post #5 of 11 Old 05-07-2013, 08:42 AM
98LIZJ
What kind of flares are those? And how much if you don't mind me asking, they look awesome
98LIZJ is offline
post #6 of 11 Old 05-07-2013, 08:57 AM
WhiteOut
WhiteOut's Avatar
Stick with 32x11.5
You'll still probably need to trim your bumper though. I'd spend more money by improving the suspension (control arms and bumstops) rather than on rims which you don't really need to run 32x11.50. Stock wheels and some 1.25" spacers will work fine for that width.
WhiteOut is offline
post #7 of 11 Old 05-07-2013, 04:55 PM Thread Starter
larados
After clad paint to match BW fender flares pics. Please advise. Tire size recommendations. Wheel offset. Will my bearings and stuff wear extremely quickly if I go 33 x 12.5 w 4 inch offset. Would smaller tires be better? [ATTACH][ATTACH][ATTACH]jeep-jeff-011a.jpg[/ATTACH][/ATTACH][/ATTACH]
larados is offline
post #8 of 11 Old 05-07-2013, 04:58 PM Thread Starter
larados
Bushwacker fender flares ZJ. $400 4wheelonline.com
larados is offline
post #9 of 11 Old 05-07-2013, 05:02 PM Thread Starter
larados
Originally Posted by WhiteOut View Post
Stick with 32x11.5
I assume you mean front fender? BW flare instructions indicated nothing of the sort.
larados is offline
post #10 of 11 Old 05-07-2013, 05:07 PM
WhiteOut
WhiteOut's Avatar
Front bumper means front bumper. Larger tires are going to catch on the plastic bumper cover, so it needs to be trimmed. How much will be determined after you have the new tires installed.
As for increased wear on bearings and other parts, any tire size over stock and with less backspacing will increase wear due to weight and how that weight is located. With 3.75" BS and 33x12.5 on steel wheels I used a set of wheel bearings about every 14 months. Like it was said above, I would stick with 32x11.5r15 on an 8" rim and 3.75-4.00" of backspacing or on stock rims with 1.25" spacers.
WhiteOut is offline
post #11 of 11 Old 05-07-2013, 05:08 PM
AnotherRedZj
Prob wanna start to look at regearing if going 33 or bigger. I would expect more wear in that dept. 32 would prob look a lot more proportioned with your lift.
AnotherRedZj is offline
