tire on the roof - JeepForum.com
post #1 of 48 Old 08-29-2005, 07:20 PM Thread Starter
Arkansas_WJ
Arkansas_WJ's Avatar
tire on the roof
i have been seeing alot of full sized tires on the roof of other GC i see on the road. is there a reason to put it in a basket insted of just keeping it under the cover in the back?
Mitch
2000 WJ Limited - 4.7l, 4x4, pioneer HU w/ ipod interface, upgraded front calipers, yakima lowrider system, uniden cb w/ 4 ft firestick, 3.5" tweeter upgrade
Arkansas_WJ is offline
post #2 of 48 Old 08-29-2005, 07:28 PM
Meerkat
Cool factor.
Additionally, some folks use that space on the WJ's for sub woofers.
If the Jeep is lifted, and they are running larger tires, they may not fit in the stock storage position (ZJ or WJ).
But mostly the cool factor
HTH
Warren
Black 1996 5.2L ZJ Limited
Meerkat is offline
post #3 of 48 Old 08-29-2005, 07:31 PM Thread Starter
Arkansas_WJ
ah yeah i agree it does look pretty cool thanks for the responce man
Mitch
post #4 of 48 Old 08-29-2005, 07:36 PM
Phil Gerard
Former Mod
Phil Gerard's Avatar
I do it for the room!! I'm too cool to be cool!!
Phil
'95 ZJ Ltd. White 4.0L
TW DC DS; ARB Bull Bar, F&R Air Lockers; Superior Axles; Warn Winch; 4.56 gears; ACOS, Addco F&R Sw Bar, JKS Discos, Rr Track Bar & Nerfs, 249>242 Swap, Stillen rotors+Kolak pads, 3 pc. Armor, RE 4.5 Kit + 2.5"BB, Adj. UCAs&LCAs, OME SS, Bilstein 5150s, 15x8 AR Diamond Backs, 33 Truxus MTs, K&N FIPK, RE 62mm TB, Perf. Distr. 4.0L Kit, Exhaust: 2.5" Kolak exhaust FM 70: Optima Yellow, Mean Grn Alt., PIAA 520s, 540s, Kevins Rack, & TB Conversion
Phil Gerard is offline
post #5 of 48 Old 08-29-2005, 07:38 PM
Meerkat
downright frosty!
Warren
Meerkat is offline
post #6 of 48 Old 08-29-2005, 08:03 PM
Phil Gerard
Former Mod
Originally Posted by wvd
downright frosty!
WVD,
That's COLD!!!
Phil the unruly banana
post #7 of 48 Old 08-29-2005, 08:05 PM
Woody
Retired back to Bowties
Woody's Avatar
1985
I haul too much crap in the rear to keep a spare there.
Woody
1985 1 ton K-5, Detroit diesel, 36" tires (going bigger when money permits), 4-speed manual swap, Rockwell T-case, Hybrid lift, 12.5K winch.
Woody is offline
post #8 of 48 Old 08-29-2005, 08:40 PM
JeremyBelnap
JeremyBelnap's Avatar
*IDEA* tire on roof
just running this by you guys to see what you think. People are asking about putting their full size spare on the roof. I know you can buy a cross member that mounts to the roof rack already, and you put your two existing cross members together and then it ties down to this new metal cross member and you can lock it...
BUT what if you bought another cross member, a factory one, off ebay maybe, just like your existing ones (so that you have 3...I'm assuming that is possible) You then can put the three together and put a hole in the middle one to tie down the tire and lock it in place and all.
The reason for this thinking is that it is expensive to buy the metal cross member that is made just for this, and I looked on ebay and you can buy additional crossmembers for real cheap.
Let me know what you think and if it would work!!
Jeremy Belnap
1998 White ext/ Tan int., Limited, 4.0L, 100K miles, 249 TC, Zacatal Rack, Clarion Head unit, 6 speaker system w/ custom gate speakers install w/ 2 amps and a sub.
Stock infinity gold amp for sale ifinterested
JeremyBelnap is offline
post #9 of 48 Old 08-29-2005, 09:00 PM
PlatinumZJ
Senior Moment Member
PlatinumZJ's Avatar
I think that if you drilled a hole in the crossmember it would weaken it too much, better to get two and a couple plate bolted together to clamp the cross members without drilling hole that would weaken them.
Doug
When all is said and done, more is said than done.
Platinum '97 ZJ LTD, I6 (see profile) Paid for!
Links:
for ZJ & WJ stuff,
for performance stuff. I6 performance info at
Other stuff: Kevin's Roof Rack. KOR sliders, Bored 62mm TB, Blaupunkt Bermuda w/ ipod, Brembo Slotted rotors,
OME steering stabilizer, H4 headlight upgrade...
PlatinumZJ is offline
post #10 of 48 Old 08-29-2005, 09:06 PM
Meerkat
The crossmembers on my stock roof rack only come about halfway up the tire....
Warren
Meerkat is offline
post #11 of 48 Old 08-29-2005, 09:26 PM
OSCAR326
OSCAR326's Avatar
I used to just scoot the two just far enough apart so that they were still almost (Each) near the wheel. Then I would just ratchet them down with two straps diagonally. It stayed up there many times at 40-50mph on fire trails....not to mention 80 on the highway.
2004-WJ 4.0, Loredo
Kevin's 2.5" BB
265/75R16 Goodyear AT/S
Pro-Comp ES3000 shocks
Westin Safari-Bar
Maxtel 6" Off-Road lights
360? of Tint
Thule Roof Rack
Do my new seat covers count?!
OSCAR326 is offline
post #12 of 48 Old 08-29-2005, 10:10 PM
EMTimZJ
GSMW!
EMTimZJ's Avatar
1994 ZJ
I just did it so I could locate my rig easier at the mall. My power antenna is stuck down so I couldn't just put a little colored ball on the top. I had no choice but to buy KOR roof rack.
It clears out a lot of room in the back and allows me to put more stuff I think I need in the back of the ZJ.
-Tim
KD8EBC
'94 ZJ 5.2 LTD
JCR Rock Sliders
EMTimZJ is offline
post #13 of 48 Old 08-29-2005, 10:15 PM
PumaZJ
yea.. cool factor.
1998 ZJ - 36's & bent unibody - RIP
2004 WJ - Expedition build
2011 A4 - DD
PumaZJ is offline
post #14 of 48 Old 08-29-2005, 10:50 PM
grandman97
grandman97's Avatar
i'm w/ woody mines on the roof cuz i need the space
grandman97 is offline
post #15 of 48 Old 08-29-2005, 10:57 PM
grandman97
grandman97's Avatar
yea i just have mine sitting on the crossmembers and have 4 tie downs..one to each corner of the roof works great.. i've actually hit large low branches pretty hard w/ the tires and it didnt budge
Spare Tire on Roof BHand89 ZJ Grand Cherokee Forum 28 07-03-2014 06:48 PM
wj roof mounted tire rack JeepWJBob ZJ Grand Cherokee Forum 1 01-22-2009 08:37 PM
Spare Tire In The Roof Rack skisprinkle686 ZJ Grand Cherokee Forum 19 08-01-2006 07:04 AM
$25 roof rack tire carrier Airborne Lee ZJ Grand Cherokee Forum 16 02-16-2006 08:51 PM
roof mounted spare tire grandman97 ZJ Grand Cherokee Forum 1 02-22-2005 12:07 PM
