Tire questions - JeepForum.com
post #1 of 30 Old 02-14-2013, 03:53 PM Thread Starter
McHiVeSlY637
Tire questions
What size tires would I be able to get with stock jeep and 15's.. I have 215 75 r15's right now but they are shot
McHiVeSlY637 is offline
post #2 of 30 Old 02-14-2013, 03:59 PM
jmonty0523
I know 225/75 15 will fit for sure, I've heard 235/75R15 might rub slightly at full wheel lock
...________oooo_
/ ./.\...,\_____ \,_____
[_---_______---_\-\\\\\\-\
(o) )-o---) ) (o) )-o---) )______
jmonty0523 is offline
post #3 of 30 Old 02-14-2013, 04:04 PM
tinktinkTJ
I ran 235/75r15's on both of my zjs, they weren't even close to rubbing.
tinktinkTJ is offline
post #4 of 30 Old 02-14-2013, 04:19 PM Thread Starter
McHiVeSlY637
What about the speedometer? Would it mess with that going bigger. Or is their a way to calibrate
post #5 of 30 Old 02-14-2013, 04:24 PM
LunaMoona
30x9.5xr15 is the biggest you can go with no lift.
LunaMoona is offline
post #6 of 30 Old 02-14-2013, 05:11 PM
paintballwannab
On stock wheels 235/75-15 will rub the sway bar slightly on full lock. Aftermarket wheels with a better off set will have no issues rubbing.
paintballwannab is offline
post #7 of 30 Old 02-14-2013, 05:13 PM
LunaMoona
I have 235/75-r15s on my stock height GC and do not rub at all.
post #8 of 30 Old 02-14-2013, 05:16 PM
WhiteOut
WhiteOut's Avatar
No they won't, there is more clearance than that.
WhiteOut is offline
post #9 of 30 Old 02-14-2013, 05:17 PM
jmonty0523
Changing the size will mess with the speedometer, not really that much, so I wouldn't worry too much about it
...________oooo_
post #10 of 30 Old 02-14-2013, 05:32 PM
tinktinkTJ
As stated above it won't change ure speed by much, maybe 1-3mph.
I was running 235/75s on stock canyons, as others have said there's plenty of room.
post #11 of 30 Old 02-14-2013, 05:37 PM
paintballwannab
sway bar must be bent then. On mine they rubbed at full lock. Bigger tires on Cragars and no issues now.
post #12 of 30 Old 02-14-2013, 06:13 PM
jmonty0523
For those who had rub issues, did you ever measure to make sure sway bar was centered? how were your bushings? it might have shifted to cause rubbing, or shifted so it didnt rub...
...________oooo_
post #13 of 30 Old 02-14-2013, 07:23 PM Thread Starter
McHiVeSlY637
Thanks for all the help in deciding. Ill try and get a good picture if the jeep tomorrow and post it so you can give me some pointers on it!
post #14 of 30 Old 02-14-2013, 09:02 PM
JeepDaddy1993
running at stock height i had 245/70/15 on stock wrangler wheels and never rubbed and now im on a 2" BB and still no rub
JeepDaddy1993 is offline
post #15 of 30 Old 02-14-2013, 09:30 PM
Bear304inc
I run 235's on 15in on stock canyons and really dont even consider it a very big tire at all. No rubbing, hell ive got plenty of room to spare.
Bear304inc is offline
