Tire Q? - JeepForum.com
post #1 of 3 Old 01-26-2005, 11:18 PM Thread Starter
laxwarriors21
laxwarriors21's Avatar
Tire Q?
With a 4.5'' lift, could i slip on 33'' x 11.50'' ?
--4.5'' RE Lift
--31'' x 10.50'' Firestone Desination MT's
--Trail ready bumpers
--Conferr roof rack
--Two Hella Model 500 driving lights
laxwarriors21 is offline
post #2 of 3 Old 01-27-2005, 12:41 AM
WVZJ
Yes, but you might have a rough time finding a 33x11.50. 12.50 wide tires will be much easier to find or you could run 33x10.50s. If you plan on using your stock rims you will need spacers. If you are getting new rims I would get 3.75-4" BS to keep from rubbing and have a good turning radius.
98 ZJ 5.2, LA n Locked, 242 sye, 35's
87 MJ, 4.0, 8.8, 33's, oba
07 Ram 2500 5.9 ctd
WVZJ is offline
post #3 of 3 Old 01-27-2005, 04:14 PM
Texas ZJ1
Jeep Jedi Master
Texas ZJ1's Avatar
1994 ZJ
The correct backspacing and 33s will fit with just some minor rubbing. However, if you plan on wheeling it hard, you'll need to do some more trimming.
However, you'll need to regear with the 33s to get the some acceleration that you're used to having.
Hunter
04 4.7 HO, limited
08 Z71 Suburban, front leveling kit with rear spacers. 285/65 18s Nitto TerraGrappler G2s
94 5.9 Laredo 6.5 RE lift with 35 Maxxis Bighorns
and 33 Bridgestone Duelers
Detroit and true trac
Red Jeep Club Member
REDNECK JCM
Texas Jeep Owner #6
USN Jeep Club #4
602.841.3355
For your performance needs:
480.998.366
Texas ZJ1 is offline
WJ spare tire, max tire size in back? EarpWJ WJ Grand Cherokee Forum 18 09-08-2010 04:30 PM
Spacer and tire combo to prevent tire sticking past fender tunacots WK Grand Cherokee & XK Commander Forum 3 10-16-2009 09:43 PM
Largest tire in spare tire area n8man1068 ZJ Grand Cherokee Forum 7 07-13-2009 01:40 PM
How to use the old spare tire mount on a 31" tire! NickkciN ZJ Grand Cherokee Forum 20 12-19-2008 03:25 PM
Tire size and spare tire canuckJGC ZJ Grand Cherokee Forum 4 10-22-2004 06:06 PM
