Tire pressure, recommend? or max ? - JeepForum.com
View Poll Results: Max or recommended
Max Cold PSI 3 13.04%
Factory Recommended 20 86.96%
Voters: 23. You may not vote on this poll
post #1 of 19 Old 06-09-2010, 03:01 AM Thread Starter
ZJ5point2GCL
Do you run the recommended tire pressure (what it says in the door) which i believe is 33
Or do you run the max cold pressure is says on the tire (which in my case is 44)
Please vote then explain why or what.
And i am talking about for daily driving not wheeling.
98 Deep Slate Niner- 6''s on 35's ---11 F150 Platinum Pearl White- Modded Tiny V6 with Two Turbos. ---93 Black 5.2 limited- Slowly dying in my Parents Driveway
ZJ5point2GCL is offline
post #2 of 19 Old 06-09-2010, 03:12 AM
CJ7-Tim
Real Jeeps have dents
CJ7-Tim's Avatar
If you run non-stock size tires you should perform the chalk line test to determine the correct tire pressure for your specific tire/wheel/vehicle combination. Mark a chalk line across the tread of the tire from sidewall to sidewall. Drive in a straight line for 50-100 feet. Examine the chalk line, if the line remains at the edges of the tire treads, you have too much air pressure and the tire tread is bulged. If the chalk line remains in the center of the tread, you have too little air pressure. Adjust the air pressure until the chalk line wears away evenly across the tire treads.
Max tire pressure (printed on the tire itself) is the line in the sand you shouldn't cross. If you are towing or carrying lots of cargo, you should increase the normal air pressure in the tires accordingly. The recommended tire pressure is just that, a recommendation for the factory original, stock size tires.
CJ7-Tim is offline
post #3 of 19 Old 06-09-2010, 05:34 AM
ratmonkey
R.I.P.
ratmonkey's Avatar
Max pressure is for max load rating of the tire. Never drive on max inflated tires without a full load on them. It will shrink your contact patch and cause poor tire wear characteristics.
Stock tires should be inflated to recommended unless you just enjoy playing with chalk. Larger tires must be checked for even contact with chalk. You will need to run lower than stock pressure. The tire will tell you how much lower by the chalk test.
ratmonkey is offline
post #4 of 19 Old 06-09-2010, 12:51 PM
lateralus3
1994 ZJ
i run about 25 psi on my 33s
lateralus3 is offline
post #5 of 19 Old 06-09-2010, 01:29 PM
Bl@ck06Rubi
Chalk test, max preassure will knock the fillings out of your teeth....much too hard/harsh....
2004 Grand Cherokee Overland, 4.7HO V8, 6" Clayton Longarm, JK Rubicon Wheels, 285 70 17 MT/R, 2001
Bl@ck06Rubi is offline
post #6 of 19 Old 06-09-2010, 04:15 PM
zjdamien
1977 J-Series Truck
im running 32psi in my 32x11.50r15LT sport kings 3 psi lower then recommended due to the larger tire
1977 J-20 stock stock stock
1993 zj (traded)
zjdamien is offline
post #7 of 19 Old 06-09-2010, 04:43 PM Thread Starter
ZJ5point2GCL
i am running a 32x11.5 on an 18, so would 30 sound good? i will do the chalk test eventually, but right now its doesn't look like it will stop raining anytime soon. once my 4inch lift is on (this weekend if my shocks get here) i can run any pressure, but right now i need all the pressure i can get so my tires don't rub the inner fender.
not that it would be affected that much in such a thirsty vehicle, but has anyone notice a fuel economy difference? with more or less pressure?
post #8 of 19 Old 06-09-2010, 05:54 PM
89blkcomanche
damm that seems a little to low to me, have you done the chalk test? on my 32's 33psi feels good
93' ZJ 4.0l 4x4 auto, trail rig, 6 kc's, green and gray, 3.73 swap, 32x11.50 bfg mudd terrain
89' comanche, 2.5L 80k original miles, single stage paint- sold
89blkcomanche is offline
post #9 of 19 Old 06-09-2010, 05:58 PM
steelstr45
I put in 35 on stock. But of course my rims un-repairably leak so that'll be down to 30 psi on one side by the end of the week
steelstr45 is offline
post #10 of 19 Old 06-09-2010, 05:58 PM
lateralus3
1994 ZJ
no i havent done a chalk test but it seems to ride pretty good. my buddy is running 20 psi on his 33s and he has very even wear and does the 5 tire rotation
post #11 of 19 Old 06-09-2010, 06:04 PM
Bl@ck06Rubi
I am not positive my grand (04) Overland, I do know in my Rubicon with 315 75 R16 MT/Rs 28-30 psi is plenty to get nice even wear and about as good road manners that you can get...But those are load range "D"...probably didn't help you one bit!
Will
post #12 of 19 Old 06-09-2010, 07:22 PM
rustynail
I run 27 psi in my 285's city and highway. If I ran them a 65psi the Jeep would drive like garbage.
- Russ
5.9 ORVIS 33x12.5 MTR-Kevlar, 7" fr adj IR LA's, 7" rr adj RE SF SA's, adj JKS TB's, RE SB disc, RE Springs, JKS ACOS, 13" RS9000XL's, OME SS, NP231, Durango box, IR Sliders, IR Skid, 3" Flowmaster 70, K&N, Superwinch EPi9.0, Optima Yel, 2 air comp, Alpine, Garmin, Sunroof
rustynail is offline
post #13 of 19 Old 06-09-2010, 09:06 PM
Falkon
About 38 or so on factory spec tires. Like a little firmer ride and better response etc. Probably helps milage a little bit too. They wear evenly. If the center goes down more than the edges I'll lower it .
Falkon is offline
post #14 of 19 Old 06-09-2010, 09:57 PM
ajmorell
ajmorell's Avatar
Neither. The proper tire pressure depends on many things (which may have already been mentioned) including tire size, vehicle weight, & tire load range.
ajmorell is offline
post #15 of 19 Old 06-10-2010, 07:00 AM
rugermack
32 psi, I didn't pick either choice in the poll, neither applied. The door jam tire psi is for stock tires, and max clod is for max loads. Depends on tires, size, load ect.
95' Jeep Grand Cherokee Laredo, 148k, 5.2, NP242, 46RH, 4" RC lift, all new adjustable ca's(2 IRO front uppers and the rest RC adjustables), nitro shocks, JKS TB's, Jet Chip, Dynamax cat back, Magnaflow cat, GTP hood vents. 31" Pro Comps with Rock Krawler "D"s. Westin brush/grill guard with Hella 500s, 411's, Solid diff covers, detroit locker rear, power lock in front, SYE and Tom Wood's front/rear shafts, RE discos, BPE's, d-rings front and back, factory tc and rad skid, hitch, Sliders next.
03' Jeep Grand Cherokee Laredo, (wifes Jeep) 99k, 4.7 5 speed auto, K&N, KYB shocks, drilled-slotted rotors, All the toys.
2000' Ford Superduty, F250, 7.3, 198K, 37's, too much to list.
Built Not Bought #257
Parts for sale d30 and d35 parts
rugermack is offline
what tire size do you recommend for my stock 1997 jeep grand cherokee? webhostingdesig ZJ Grand Cherokee Forum 26 10-30-2014 08:56 PM
Tire Pressure historyfool24 ZJ Grand Cherokee Forum 19 06-23-2014 12:54 PM
recommend tire jeep199044 ZJ Grand Cherokee Forum 4 01-24-2009 11:20 PM
Tire pressure memo_98 WK Grand Cherokee & XK Commander Forum 9 03-01-2008 06:23 PM
Tire pressure zaq123 ZJ Grand Cherokee Forum 3 07-12-2005 06:04 AM
