Quantcast tire pressure monitoring - JeepForum.com
Go Back JeepForum.com > Models > Jeep Grand Cherokee & Commander Forums > ZJ Grand Cherokee Forum > tire pressure monitoring
Old 04-08-2009, 11:02 PM   #1
shanhuber
I have a 2004 Grand Cherokee overland 4.7L I have a message Bad/missing tire sensor. But all the tires register the pressures, and I have re-trained the tires (including the spare) but still get this message. What do I need to do to get rid of this?
shanhuber is offline   Reply With Quote
Old 04-08-2009, 11:05 PM   #2
Kramer H
Built and Supercharged 47
Kramer H's Avatar
wait, so your positive you dont have a bad/broken sensor? including the spare? will it pull up the pressures off the display in the cab? do you have the tires set at the right pressure? (32psi i belive?) if its too low or too high, it will set it off too. and you must do a relearn, some shops have a special comp for this.
Built Beater 01 WJ MY BUILD THREAD
Swapped, SUPERCHARGED Locked, Lifted and Long Armed.
02 Cummins. It has a smoking problem, And it wont quit.
K8 GSXR 1000- Jardine,Comp Werks,Puig,Woodcraft,B2 Industries,55W HID'S, B&N
Kramer H is offline   Reply With Quote
Old 04-08-2009, 11:11 PM   #3
PioneerRob
1985 XJ Cherokee
I have been dealing with this exact some problem. I used this link to run a test on the sensors and I found out that they were not sending a signal as often as they should. So I am replacing all of the sensors. Here is the website:
http://www.wjjeeps.com/tpms.htm
It is towards the bottom, it is called "Tire Pressure System Test"
1985 Jeep Cherokee
2003 Jeep Grand Cherokee Overland
PioneerRob is offline   Reply With Quote
Old 04-09-2009, 11:20 AM   #4
shanhuber
All tire pressure is set correctly. On the overhead display, it only shows the 4 tires. The spare tire info only displays if the tire pressure in the spare is low. At start up, I get a bad sensor message, but then when I press the button to display the tire pressure, the message disappears, and will only re-appear after re-start up.
Old 04-10-2009, 09:19 AM   #5
shanhuber
took it to goodyear to get new tires. They hooked it up to 2 different scanners and still can't figure which one is bad. They have one scanner just for TSP monitoring and it said all 5 work fine. But I still get the message at start-up
Old 04-10-2009, 09:33 AM   #6
gatorayde
If you have replaced the tires since you've owned it, someone could have broken the sensor installing the tires. I know I did this once at work, a nice ~$90 sensor
I'd say take it to the dealer at this point. As much as you don't want to, they will probably be able to figure it out.
gatorayde is offline   Reply With Quote
Glock Forum
