Tire Pressure - JeepForum.com
post #1 of 20 Old 04-29-2005, 10:32 AM Thread Starter
historyfool24
Tire Pressure
I know this is a new guy question and well I am a new guy. But I was wondering what is the tire pressure that the dealer recommands for a 2002 Jeep Grand Cherokee. I must have really bad eyes because I can read it off the tire and then my car, being used, did not come with a manual . so if anyone can help a guy out that would be great.
2002 Jeep Grand Cherokee Laredo
4x4 V8 engine
historyfool24 is offline
post #2 of 20 Old 04-29-2005, 10:51 AM
7thStranger
7thStranger's Avatar
There should be a sticker on the drivers side door.
98 Grand Cherokee I6
7thStranger is offline
post #3 of 20 Old 04-29-2005, 10:59 AM
Hooligan1
33 psi.
I'd get a manual if I were you:
http://cgi.ebay.com/ebaymotors/ws/eB...category=34224
That one looks like a really good deal. Any manual 99-04 should work, off the top of my head I can't think of much that would have been different for a Laredo, but there are so many on eBay that you can get an '02 manual. I thought I still had mine, which I'd send you for the cost of postage, but I can't find it.
Congrats on the new Jeep- what color/options?
Hooligan1 is offline
post #4 of 20 Old 04-29-2005, 04:24 PM
kensue49
kensue49's Avatar
You could go to the source.
https://techauthority.com
1994 ZJ Limited
Black Jeep Club V2.0 # 1994
5.2 engine
QuadraTrac
Black with Gold trim
133,000 miles
stock[
kensue49 is offline
post #5 of 20 Old 05-02-2005, 10:31 AM Thread Starter
historyfool24
yeah i love my jeep
its a 2002 they call it Woodland but it looks more like a dark brown. it a 4x4 with the upgraded sound system that is about as far as options go. my dad got it for a steal, he brought the price down by 5 grand and thats not counting the 2 grand i got for my 1994 Saab 900 trade in.
and about the sticker in the door was worn away, hence the thread.
4x4 V8 engine
post #6 of 20 Old 05-02-2005, 10:40 AM
rowdy1
rowdy1's Avatar
Re:Tire Pressure
I can't speak for anyone else,but I'm all for going with the recommended pressure rating on the tire sidewall
rowdy1 02 GC Laredo
rowdy1 is offline
post #7 of 20 Old 05-02-2005, 07:01 PM
Woody
Retired back to Bowties
Woody's Avatar
1985
Rowdy, the pressure on the sidewall is the maximum pressure. Most tires that fit on your Jeep do not require that much pressure, as our vehicles don't weigh as much as the Suburban and Excursion they can also be mounted on. Look at the label and door panel. With my 31" BFG's, I run about 28 psi, as their rating is more than double the weight of my ZJ, so I only need to run half of the recommended PSI. My tires have 55,000 miles on them, so I guess what I'm doing is about right. Or I could just be lucky.
Woody
1985 1 ton K-5, Detroit diesel, 36" tires (going bigger when money permits), 4-speed manual swap, Rockwell T-case, Hybrid lift, 12.5K winch.
Woody is offline
post #8 of 20 Old 05-02-2005, 07:08 PM
theone13
The recomended psi on the door is for the stock tires. Should I still follow this psi for new aftermarket tires even though they have a suggested max psi that is much higher?
-Steve
'95 ZJ Laredo 4.0L 4x4 : Stolen
theone13 is offline
post #9 of 20 Old 05-02-2005, 07:18 PM
Hooligan1
If the tires are what's listed in your sig, you're best off with around 32-34 psi.
NEVER RUN THE MAX PRESSURE! You'll have a bone-jarring stiff ride and the tires will not wear evenly.
2004 Grand Cherokee Limited 4.7HO 4WD
post #10 of 20 Old 05-02-2005, 07:47 PM
theone13
Awesome, thanks Hooligan.
-Steve
theone13 is offline
post #11 of 20 Old 05-02-2005, 09:54 PM
rowdy1
rowdy1's Avatar
Re:Tire Pressure
I understand what you are saying,Airmanwoody,but in light of all the problems Firestone and Ford had a few years ago I feel safer using the tire manufacturer's recommendations. You are absolutely right about the markings being for maximum inflation
rowdy1 02 GC Laredo
rowdy1 is offline
post #12 of 20 Old 05-02-2005, 10:14 PM
-Joe-
-Joe-'s Avatar
Also its best to measure the psi before you drive and warm up the tires.
http://www.tutorials.com/08/0817/08171.asp
- Joe -
'95 Jeep Grand Cherokee Laredo I6 4.0L
242TC - Extreme Engineering 2" Front Lift/1.75" Rear Lift - ES9000 Shocks + JKS BPEs
Moog Cargo Control Springs
Magnaflow Converter - Dynomax Muffler
235/75/15 AT Uniroyal Liberator Tires
-Joe- is offline
post #13 of 20 Old 05-03-2005, 06:53 AM
Stocker
I understand your concern, but the Firestone/Exploder problems were attributed to sidnificant underinflation to give a soft ride. They were not properly inflated. And as you just noted, those tire manufacturers' recommendations are indeed for maximum pressure, and as Hooligan points out, should not be used on our rigs under normal conditions.
It's your decision, of course, and I'm not trying to change your mind. Rather, I want our other (especially younger) viewers here to understand why it's important to use the vehicle manufacturer's recommended pressure and not the tire manufacturer's maximum recommended pressure.
1995 5.2 ZJ Sold... but still in the family
Stocker
Stocker is offline
post #14 of 20 Old 05-03-2005, 06:59 AM
Woody
Woody's Avatar
1985
Exploders had those problems because Ford Motor Company was trying to use a tire that was not rated for the weight of the vehicle they were on. Firestone was getting hammered and yes they had some problems, but no worse than any other company. They are the ones that got caught, that's all. Firestone recommended to Ford to use a different tire and Ford said no, because the other tire was more expensive. Big Whoops on their part. The markings are still the maximum and can cause premature tire wear. Ask your tire shop what you should run at. They will probably tell you between 32-36 psi.
Woody
Woody is offline
post #15 of 20 Old 05-03-2005, 08:25 AM
Hooligan1
I'm sure your local tire store loves you... you must go through tires very quickly. Aside from a painfully stiff ride, you'll have terribly uneven wear by running at max pressure.
You're also GREATLY increasing the chances of a blowout by running the tires at a high psi... so if you think you're reducing your chances, you're wrong.
Do you have any idea what the Firestone/Ford controversy was about? Defective tires that were underinflated. Ford recommended too low of a pressure to give the trucks a soft ride, and Firestone made some shoddy tires. I haven't looked, but I think the max pressure on my Goodyear tires is somewhere around 60psi... Goodyear says that's absolutely the most that the rubber is designed to withstand. Jeeps are fairly light weight vehicles, considering the type of vehicle... the tires are designed to be considerably stronger than what a Jeep needs, so they're designed to run at a high pressure.
This is truly one of the dumbest things I've ever heard... running your tires at MAX PRESSURE!
Tire pressure 8black88 ZJ Grand Cherokee Forum 7 03-13-2008 11:32 PM
Tire pressure memo_98 WK Grand Cherokee & XK Commander Forum 9 03-01-2008 06:23 PM
tire pressure GRDCHRKE555 ZJ Grand Cherokee Forum 6 01-18-2007 07:08 PM
tire pressure 99wjman ZJ Grand Cherokee Forum 2 07-26-2006 01:30 AM
tire pressure automan25 ZJ Grand Cherokee Forum 2 07-02-2003 12:56 AM
