tire confusion - JeepForum.com
post #1 of 8 Old 04-13-2011, 03:48 PM Thread Starter
blsbro
tire confusion
To start i will say i did read the FAQ's and yet i am some how still confused. I have a 96 ZJ Stock wheels and a 2" lift I just put on. I see how people are saying with a little bit of trimming I can get 31 x 10.5 on the jeep but then I am also seeing on Tirerack.com that i can't and since i am running 225/ i am stuck at 30"?
I am trying to get the biggest tires possible with my stock wheels (OR) i am willing to get new wheels but just dont know what to get. I am looking to get BF all terrains
Any help would be awesome
thanks
blsbro is offline
post #2 of 8 Old 04-13-2011, 04:04 PM
LordHobbit
I ran 30x9.50 on stock suspension with such minor rubbing it's not worth mentioning. Okay I'll mention it. Just the plastic shield in front of the front tires.
You can run 31x with bb
93 red ZJ 190k 4.0. Spent more money than I should have ...
Isn't red the only color a vehicle should be?
If at first you don't succeed, use more speed.
LordHobbit is offline
post #3 of 8 Old 04-13-2011, 04:08 PM
Technohead
You can fit 31x10.5x15 on stock wheels and 2" lift no problem. All you should need to trim is a bit off the front bumper. You will also rub a bit on the front lower control arms at full steering lock. Fix that with 1 1/4" spacers or just live with it.
I also recommend dropping the bump stops 2" if you will be wheeling.
-Eric
Technohead is offline
post #4 of 8 Old 04-13-2011, 04:09 PM
adamandjessyj
thanks
tirerack.com is giving you the tire size that you can fit without triming your fenders. your rims should be able to fit most any size tire you might want.
where thers a will, theres a way!
its not a just a truck, its my hobby.
adamandjessyj is offline
post #5 of 8 Old 04-13-2011, 05:21 PM Thread Starter
blsbro
thanks
Hey guys thanks for the quick response -
I think i am going to go with these BF AT 31X10.5R15
http://www.tirerack.com/tires/tires....ORWL&tab=Sizes
Unless anything has other tire suggestions?
Thanks
blsbro is offline
post #6 of 8 Old 04-13-2011, 05:41 PM
TheHalfWit
You'll love em as long as you don't play in the mud, if you like mud then you'll hate em.
Calm. C.
If a week goes by without needing to replace something, pinch me because I must be dreaming.
TheHalfWit is offline
post #7 of 8 Old 04-13-2011, 06:23 PM
melk
Holy crap $158 each?
http://www.treadwright.com/p-9-31-10...arden-a-t.aspx
Literally half the cost.
melk is offline
post #8 of 8 Old 04-13-2011, 06:40 PM
blackjack12982
1994 ZJ
Yep, my buddy runs their 37's, I'd definitely do a set of 35's, but I'd need to invest in new wheels which would cut down on the initial savings.
blackjack12982 is offline
confusion on 242? bayer ZJ Grand Cherokee Forum 2 02-18-2010 04:29 PM
tire size confusion! nquaint ZJ Grand Cherokee Forum 8 05-30-2007 05:56 AM
BB Confusion for ZJ Test ZJ Grand Cherokee Forum 8 07-10-2005 08:27 AM
PCM Confusion JLA ZJ Grand Cherokee Forum 6 01-01-2005 11:31 AM
94 GC Limited Tire Size Confusion gagnu ZJ Grand Cherokee Forum 4 11-29-2004 06:49 AM
