Timing and vibration problems! - JeepForum.com
post #1 of 3 Old 05-28-2002, 12:51 PM Thread Starter
sccoupe30
How is the timing changed on the 4.0? I have to run plus all of the time and high test when pulling a trailer. It pings like it needs the timing backed off. If this cannot be done, what is another solution? This thing should be able to run 87 octane. Next question. I have a vibration in the front end. You really feel it above 50 mph. Ive put new tires all the way around and changed all 5 of the U-joints up front. What else is a common problem on these?
Thanks all!
sccoupe30 is offline
post #2 of 3 Old 05-29-2002, 09:29 AM
Big Dumb White Guy
Big Dumb White Guy's Avatar
did you get an alignment? maybe try rotating the tires. i know they are new but ya never know......
repost Nazi's suck!
A guy walks into the psychiatrist office wearing only Glad Wrap shorts. The shrink says, "Well, I can clearly see you're nuts."
Big Dumb White Guy is offline
post #3 of 3 Old 05-30-2002, 06:37 AM
head27
well i try what he said...also maybe a bent rim or try so tighten everything on the suspension..that was my problem
97 tj....and 96 grand
head27 is offline
How high can a suspension lift go before you have drive line vibration problems? Teamtini ZJ Grand Cherokee Forum 5 10-07-2009 11:07 AM
24K service and now vibration problems ukliberty WK Grand Cherokee & XK Commander Forum 5 08-25-2008 01:08 PM
Do lifted GCs have noise and vibration problems? hmd100100 ZJ Grand Cherokee Forum 15 11-25-2006 12:46 PM
timing ??? sdr93 ZJ Grand Cherokee Forum 3 12-11-2005 06:44 AM
Transmission vibration problems paNX2K&SE-R ZJ Grand Cherokee Forum 7 12-07-2005 02:24 PM
