#1 | ||
zj tractor
timing spec for 5.9
need the timing spec for a 5.9 grand cherokee.
we are gona try to start it tonight... wish us luck.
hard working private first class in the United States Marine Corps. Quote:
build thread:http://www.jeepforum.com/forum/f197/5-9-andys-1-ton-zj-build-american-standard-1056365/ |
#2 |
not sure about the timing spec but good luck! i want some vids of the 5.9 taking it's first breath!!!!
1994 JGC limited 5.2l 4in F>R swap 31in. dune grapplers, soft 8's, flowmaster 40 series and duals out the sides, taurus e-fan, high flow intake, 231 swap, 44a swap, NGK plugs, Shell 93 octane only, homemade choppped and drilled light bar, gold>black stripes, in the process of making true cowl induction hood and putting 96-98 cladding, bumper cover, and grill on |
#3 | |
zj tractor
ok, ill viedo it... but it will be a few days till you can see it, ill install the program for my digital camera on this comp.
#4 |
Timing is controled by the crank position sensor and computer. If you're trying to stap the dist for the first time and you didn't mark it before the tear down (maybe different block?) set engine TDC #1 and place rotor to about the 8 O'clock position just to start it. You need to use a scan tool to properly set the dist(injector timing).
Jason |
#5 | |
zj tractor
thank you jason.... we have a timer...so when we go back to it we will try it.
and yes, it is a new block.
#6 |
Rotating the distributor will do nothing for the ignition timing. It will only change the timing of the injector firing.
Ignition timing is completely controlled by the pcm and is triggered by the flexplate and crankshaft position sensor along with taking in readings from the map, tps, ait, etc... But you can not alter timing by rotating the distributor. To set the injectors correctly you need a DRB-III so you can monitor pulse width timing and correctly set it by rotating the distributor.
99 WJ Laredo - the wife took it 96 Dakota - still mine |
#7 | |
zj tractor
humm, ill discuss this with my buddy, we went to auto motive school and got an ASE cert. so he knows this stuff better than i do.
#8 |
And here I thought this thing was running when you said "THE ENGINE IS IN" I should have known better
Nickerdoodle 03 WJ 4.7 242HD Kolak/IRO 5" Clayton LA's 35" BFGoodrich KM2 sira4x4.net North East Offroad Club www.carolinadriveline.com www.ironrockoffroad.com kolak@aol.com |
#9 | |
zj tractor
lol, there is a difference between it being in and it running...
#10 |
Belief In All Things Jeep
does this help?
http://www.jeepsunlimited.com/forums/showthread.php?t=874169 |
#11 | |
zj tractor
thanks five.nein.... that is helpful.... the only issue is, the entire motor, tranny, accessories.... EVERYTHING is in and bolted up, so as you might imagine... its kinda difficult to determine the status of everything,
EX. what cylnder is TDC on wich stroke... location of contact in dest. later when my friend gets off work, we get back to it, untill then, nothing can be done... only talked about.
#12 |
As long as the cam and crank are set right, the worst thing that can happen is you might need to pull out the distributor gear and reset it. Long needlenose pliers or a strong magnet should do it. The writeup explains how to find TDC cyl 1 on compression. Follow that writeup to the letter. I got 2 perfect running 5.9s using it.
#13 | |
zj tractor
ok, im sure that the engine is put together correctly, it was built by a good company, S&S engine....
ill read that over again, to the letter.
#14 |
| Thread Tools | |
Previous Thread
Next Thread
| Suggested Threads |
