timing light ? - JeepForum.com
post #1 of 4 Old 08-05-2009, 06:46 AM Thread Starter
dksob81
timing light ?
Can you use a timing light to check timing on a 93 ZJ 5.2L? If not can anyone explain why?
Joe
dksob81 is offline
post #2 of 4 Old 08-05-2009, 06:50 AM
Kruzin
Kruzin's Avatar
2009 JK Wrangler
Timing is not adjustable on any modern vehicles.
It's all computer controlled.
'09 Rubicon
Kruzin is offline
post #3 of 4 Old 08-05-2009, 07:19 AM
greasefingers
greasefingers's Avatar
1994 ZJ
Of course you can use a timing light as the marks are there on the crankshaft pulley. You may have to clean them with some scotch-brite. I found it much easier to see the marks at night. Itís hard to find info for timing specs if I remember correctly (something like 8 to 13 DTDC). But at least you can monitor where it is currently, even though you cannot adjust it. I checked mine when I was failing Smog tests.
Cheers Steve
94 Black Laredo 4-Liter with QuadraTrac (42RE trans & NP249 TC) 200,000 + miles purchased new
88 Cherokee 2-door with 5speed manual 139K miles(deceased) purchased new
greasefingers is offline
post #4 of 4 Old 08-05-2009, 10:16 AM
kc8ztw
put a mark with a paint marker on the notch that helps you see it way better
kc8ztw is offline
Timing mjt252 ZJ Grand Cherokee Forum 3 02-11-2009 03:32 PM
timing ? jim75 ZJ Grand Cherokee Forum 2 01-18-2009 08:13 AM
timing ??? sdr93 ZJ Grand Cherokee Forum 3 12-11-2005 06:44 AM
Timing Raven ZJ Grand Cherokee Forum 1 11-17-2004 08:59 AM
98 4.0 Timing smiley ZJ Grand Cherokee Forum 2 11-20-2003 02:52 PM
