Timing chain going bust? [ZJ-GC 4.0L] - JeepForum.com
post #1 of 7 Old 07-26-2011, 12:40 AM Thread Starter
cherokeen
Theres a slight engine grinding noise on my Grand Cherokee Ltd (1996,181000k) it sounds to be the timing chain going bust and seems to only do it when i go from Park to drive or Nuetral to Drive/Reverse and more common when im off road.
Would this be a possible timing chain problem? I used to hear something similar when i had my 97 Explorer with a fkd timing chain (sold that within 13 days of having it, piece of s**t.)
Cheers all
cherokeen is offline
post #2 of 7 Old 07-26-2011, 06:23 AM
Candymancan
Just replaced the timing chain on my 5.9, but i dont know much about timing chains in general, my old one was fine but i replaced it cause i was fixing the gasket leak i was having. Anyway, i heared if your chain is bad it can cause problems with starting and grinding noises in the engine.
Have you had someone actually put it in park/reverse ect while you were up front listening ? I ask this because it could possibly be the transfercase or transmission doing this.
Here is a writeup i found on replacing the I6 timing chain
http://www.naxja.org/forum/showthread.php?t=903937
Candymancan is offline
post #3 of 7 Old 07-26-2011, 07:11 AM
ratmonkey
R.I.P.
ratmonkey's Avatar
perhaps your fan is hitting the shroud when your motor torques over from bad motor mounts?
ratmonkey is offline
post #4 of 7 Old 07-26-2011, 08:10 AM
speedbucket
your talking about the timing chain at the front of the motor and not confusing it with the transfer case chain right?
V8 zj at 6" . Double tri rear and true 3 link front. Stretched to 108"
speedbucket is offline
post #5 of 7 Old 07-26-2011, 11:16 AM Thread Starter
cherokeen
honestly im not too similar with the timing chain on the grand cherokee's, i should be but im not, it doesn't seem like a bad problem but whenever it is idling it makes the sound.. if its something i should be worrying about i dont know.
a bit odd but does the transfer case make a sound when just standing still with the engine running?
post #6 of 7 Old 07-26-2011, 11:19 AM
speedbucket
Cheers all
no it does not but that was not specified in your first post, only that it makes noise shifting from drive gears
post #7 of 7 Old 07-26-2011, 11:37 AM
jreyes0a39oz
if it where the timing chain it would do it always no mater if it was idling or driven since the timing chain is running all the time
jreyes0a39oz is offline
grinding noise , timing chain
ZJ 5.2 97 timing chain cata123 ZJ Grand Cherokee Forum 1 10-11-2010 07:50 PM
64 chain timing set up jeep795 ZJ Grand Cherokee Forum 0 05-16-2009 10:29 AM
Timing Chain?? 1994LTD ZJ Grand Cherokee Forum 5 06-11-2008 06:23 PM
4.0L timing chain jeepunlimited ZJ Grand Cherokee Forum 7 02-02-2007 11:15 AM
Timing Chain eagleknight ZJ Grand Cherokee Forum 5 06-17-2006 11:22 PM
