Timing Chain?? - JeepForum.com
post #1 of 6 Old 06-09-2008, 11:17 PM Thread Starter
1994LTD
Timing Chain??
Hi guys...newbie here
I've had my '94 GC Ltd for approximately 6 years and have had an excellent run with it. Very minor issues till now...
My engine (5.2 liter) died on me in traffic recently and though it cranks, it won't start. I had to replace the in-tank fuel pump a few years ago but this doesn't seem to be the problem this time (I put a little fuel directly into the throttle body but still no go). I have spark also so I'm leaning towards the timing chain being the problem...(214K on original 318).
So my questions begin
The engine isn't an interference type is it? (I don't believe it to be)
How can I confirm (prior to tear-down) that the timing chain is the culprit as I suspect?
Anything else I should be looking into that I may have/probably overlooked?
All opinions/assistance is appreciated...thanks in advance.
Jeff
1994LTD is offline
post #2 of 6 Old 06-09-2008, 11:26 PM
Kruzin
Kruzin's Avatar
2009 JK Wrangler
It's not likey to be the timing chain.
If the chain (or sprockets) was bad, you'd hear it.
This isn't some rice burner with a rubber timing BELT. The chains in these engines generally outlast anything else in the engine. And they don't just skip a tooth like a belt can.
I'd be looking at electronic sensors first, starting with the crank posistion sensor.
'09 JK Rubicon
'01 XJ Sport
'10 Fusion
Kruzin is offline
post #3 of 6 Old 06-10-2008, 09:58 PM Thread Starter
1994LTD
Thanks for the info...I'l give that a check tomorrow.
A possible sensor replacement sounds a lot better than a timing chain job
Any other ideas if this doesn't pan out?
1994LTD is offline
post #4 of 6 Old 06-10-2008, 10:29 PM
Virmagicus
Virmagicus's Avatar
The CPS would be a great start like Kruz stated. Where in Hoosierland ?
Jeff
Virmagicus is offline
post #5 of 6 Old 06-10-2008, 10:32 PM Thread Starter
1994LTD
Hi from one Jeff to another
I'm in Newburgh (near Evansville, IN) on IN/KY border.
1994LTD is offline
post #6 of 6 Old 06-11-2008, 06:23 PM Thread Starter
1994LTD
Ok, I give up ....any tips on getting to the CPS? Let alone testing/replacing it...
Hopefully, I'm overlooking the obvious but I can't see getting to it with the engine in the vehicle
1994LTD is offline
64 chain timing set up jeep795 ZJ Grand Cherokee Forum 0 05-16-2009 10:29 AM
4.0L timing chain ? jeepunlimited ZJ Grand Cherokee Forum 10 07-29-2007 08:11 PM
4.0L timing chain jeepunlimited ZJ Grand Cherokee Forum 7 02-02-2007 11:15 AM
Timing Chain eagleknight ZJ Grand Cherokee Forum 5 06-17-2006 11:22 PM
Timing Chain Tenssion Jgw50 ZJ Grand Cherokee Forum 1 09-01-2005 08:32 PM
