Timing belt ? - JeepForum.com
post #1 of 10 Old 10-05-2009, 07:26 AM Thread Starter
melk
Timing belt ?
does my 96 zj 4.0 have a timing belt?
I ask because i know in the past cars should have them replaced around 75k or so otherwise they can cause serious damage when they fail. My jeep is at 95k but I don't see anyone here ever mention timing belts? Thanks
melk is offline
post #2 of 10 Old 10-05-2009, 07:28 AM
WiCkeDuDe
WiCkeDuDe's Avatar
No it has a chain that does not need to be replaced. Truck engines typically do not use timing belts.
I Have WJ Stuff for Sale
WiCkeDuDe is online now
post #3 of 10 Old 10-05-2009, 07:38 AM Thread Starter
melk
Oh good.... Thanks.
Any other routine maintainence I should be doing around the 100k mark?
I just bought the jeep 2 months ago so I plan on doing the usual stuff, plugs wires cap rotor, probably a new fuel filter too.
Also want to flush and replace coolant, tranny, front and rear diffs and TC fluids.
It already has a new alternator, battery, and Crankshaft sensor (had the infamous crank-won't-start problem, the new sensor pixed it for me)
any other basic stuff I should do at 100k? Thanks
melk is offline
post #4 of 10 Old 10-05-2009, 07:50 AM
Brian's 97 ZJ
Brian's 97 ZJ's Avatar
Your fuel filter is in your fuel tank and is part of the fuel pump assembly. Just so you know.
Air filter should be on the short list.
- Brian
For some reason, being a member of the
just isn't as cool... Member #1
Brian's 97 ZJ is offline
post #5 of 10 Old 10-05-2009, 08:02 AM Thread Starter
melk
Is it? I thought it was outside the tank... Maybe I was looking at the wrong thing underneath my jeep then... lol. It did look like the fuel filter pic I was looking at online though.
melk is offline
post #6 of 10 Old 10-05-2009, 08:09 AM
Brian's 97 ZJ
On your '96 it might me. Thought it changed to in-tank in '96 but I could certainly be mistaken.
- Brian
post #7 of 10 Old 10-05-2009, 08:29 AM
WiCkeDuDe
WiCkeDuDe's Avatar
I think the 96 did have a filter. I could be wrong. The WJs did but not all the ZJs did. Looks like your list is pretty complete.
post #8 of 10 Old 10-05-2009, 08:31 AM
WXman
My '96 ZJ has a fuel filter in plain sight in front of the fuel tank. Very simple to change.
'92 YJ - heavily modded
'96 ZJ - heavily modded
'05 KJ CRD Limited - 370 lb./ft. from a 4-cylinder and trail ready. Pure awesomeness.
'11 Mango Tango JKU Sport - Mods
'12 Dozer JKU Sport S - 6-speed - ACE rock rails - Max Tow package - Daystar spacers - 33x12.50 Duratracs
WXman is offline
post #9 of 10 Old 10-05-2009, 08:42 AM
Brian's 97 ZJ
Bingo, there is your answer. Super easy change.
- Brian
post #10 of 10 Old 10-05-2009, 08:48 AM
IslandManMitch
Ditto on filter outside of tank on my '96.
IslandManMitch is offline
when did you have your timing belt replaced? MEinSoCal ZJ Grand Cherokee Forum 9 09-09-2008 09:31 PM
Timing Belt 1star2 ZJ Grand Cherokee Forum 13 03-15-2007 11:24 PM
Timing Belt Cover grandCherokee06 ZJ Grand Cherokee Forum 6 02-16-2006 06:38 PM
5.2L Timing belt or chain? nvrmore100 ZJ Grand Cherokee Forum 6 07-25-2005 02:17 PM
Timing belt or chain sdjwm001 WJ Grand Cherokee Forum 2 04-10-2003 05:11 AM
