Time To Replace Brake Pipe - JeepForum.com
post #1 of 5 Old 08-17-2009, 09:38 AM Thread Starter
TORMULA
My local garage has quoted 2.5 hours to replace the front to back brake pipe on my WJ.
Does this sound right? Sounds like a long time to me but It could be more complicated than it sounds?
TORMULA is offline
post #2 of 5 Old 08-17-2009, 10:01 AM
micifus
Original GC'er
micifus's Avatar
you had me confused for a second, use to calling it a brake line. All the same though 2.5 hours sounds right they will prob bend up a new line and have to bleed it but you can always count to run into problems when doing brake lines.
- OME Springs - 30"x9.5" Yokohamma's A/T-S -RE Shocks - JKS Quicker Disconnects - FM70 - E-Fan Conversion - 249->242 Swap -
32"x11.5" BFG A/T
4" Lift
"For every one thing I fix two things break"
micifus is offline
post #3 of 5 Old 08-17-2009, 10:20 AM Thread Starter
TORMULA
Yeah sorry,
We have pipes not lines! They said it was a complicated run, I've never had to spend that long on a brake pipe / line before.
Thanks.
TORMULA is offline
post #4 of 5 Old 08-17-2009, 10:29 AM
driabyor
driabyor's Avatar
1994 ZJ
if they use an oem part, it's just basically a fishing job.....out. then in ,bleed ........
but if they are making it ... they will remove the line for a pattern, then copy it, then replace the line..bleed
the worst thing is the second bleed ,,,YOUR wallet
it is wallet in the UK right
94 Grand Cherokee ... 332,000 miles
5.2 liter 242 :)
Rancho 5000 steering stabilizer
driabyor is offline
post #5 of 5 Old 08-17-2009, 10:33 AM Thread Starter
TORMULA
Yeah we have wallets, usually empty apart from a few bits of plastic and a big pile of reciepts!
TORMULA is offline
mod TC 242 get rid of shift fork spring replace with pipe sdowney717 ZJ Grand Cherokee Forum 3 02-08-2010 07:14 AM
Time to replace O2 Sensors DRE97 ZJ Grand Cherokee Forum 7 01-20-2010 06:54 AM
Repaired leaking brake power booster, but now brake lights are on all the time MNWJ ZJ Grand Cherokee Forum 2 05-11-2009 07:59 AM
Time to replace the radiator - need help FishFan ZJ Grand Cherokee Forum 2 03-27-2004 08:47 AM
