Time for my thrid pcm? - JeepForum.com
post #1 of 10 Old 09-22-2013, 03:23 PM Thread Starter
cgcarpenter
Well this zj caught the electrical gremlin and it brought friends lol
It's continuously getting worse.
Stalling bucking hesitating misfire backfire. She decides she's a moody ***** lately. Whenever she wants. There's no tell on when it'll happen.
I've got codes:
P0108 map sensor voltage high
P0351 peak primary circuit current not achieved within maximum dwell time.
P0320 no crank at PCM during cranking(starts just fine)
And a cylinder 3 misfire code.
Where do I go from here. These sensors are all fine. Should I bite the bullet and buy a new PCM?
cgcarpenter is offline
post #2 of 10 Old 09-22-2013, 06:39 PM
Oldfrog
2007 WK
It's not a Cardone is it?
If so, that's the PCM I just turned in, under warranty. They sold it to you...chuckle..
Make sure you have NTK o2 sensors installed.
Next time it stalls, pull over, leave the key on and remove the TPS connector, check the voltage on the 2 outside wires. See if you get 5volts. Turn the key off, then put it back on.
I bet it has 5 volts and starts right up, too.
2007 5.7 Hemi, Ltd. QD II -
1997 ZJ, 4,0 select trac, Up country, track lok.
Oldfrog is offline
post #3 of 10 Old 09-22-2013, 07:52 PM
neonhomer
Do tell.... My 96 ZJ has a "die at random" issue... If you try to restart it without cycling the key, it won't refire. If you cycle the key off, wait a few seconds, and then try to start it, it will usually fire back up. I get the P0351 code - P0351 Ignition Coil A Primary/Secondary Circuit Malfunction.... I've replaced the coil, and the crank sensor was recently replaced with a Mopar sensor.
NeonHomer
Mid-Florida Jeep Club - Member
1996 Jeep Grand Cherokee, 4.0L/42RE/242 - Rebuilt motor w/ Comp cam (4/12), 3.5" Junkyard F>R lift, 31x10.5.x15 M/T's, Spartan Locked D44a, TC & tank skids, F&R adj trackbars, V8 steering arms
Galaxy DX99V CB, 102" SS Whip, Yaesu FT-2900R 2m, Larsen 1/4w mag mount, Sony HU, Massive 3way - F Door, Pioneer 3way - R Doors, MB Quart ONX304 Subs (x2), Lanzar 1600w amp.
"No Matter Where You Go... There You Are."
"Oh me oh my a lovely day is dawning. Oh what a joy I didn't wake up dead. So I can go to work and then resume my yawning, and get my sleep on site instead of in my bed" - Daria Morgendorffer (with my twist)
neonhomer is offline
post #4 of 10 Old 09-22-2013, 08:09 PM Thread Starter
cgcarpenter
Originally Posted by Oldfrog
It's not a Cardone is it? If so, that's the PCM I just turned in, under warranty. They sold it to you...chuckle.. Make sure you have NTK o2 sensors installed. Next time it stalls, pull over, leave the key on and remove the TPS connector, check the voltage on the 2 outside wires. See if you get 5volts. Turn the key off, then put it back on. I bet it has 5 volts and starts right up, too.
Yeah I think it's a cardone one. But it's a year and a half old. I have smog soon so I'm ordering some from rock auto.
What would that test reveal?
post #5 of 10 Old 09-22-2013, 08:09 PM Thread Starter
cgcarpenter
Sounds like a fuel pressure problem
post #6 of 10 Old 09-22-2013, 11:52 PM Thread Starter
cgcarpenter
Disconnected my upstream O2 sensor and boom huge difference. Ran 95% better. Except for the cylinder 3 misfire.
Didn't get get a single hiccup all the way home from work or when I ran to the gas station.
Am I speaking too soon?
Probably but I'll see tomorrow morning when I drive to class.
Fingers crossed.
post #7 of 10 Old 09-23-2013, 03:45 PM Thread Starter
cgcarpenter
Ran great all morning.
Except for one complete shutoff in a McDonald's drive through. Lol
Ordering my O2 sensors and then I'll go from there.
post #8 of 10 Old 09-24-2013, 12:17 AM Thread Starter
cgcarpenter
Ran good all the way to work and all the way home.
Ordering new O2 sensors right now.
post #9 of 10 Old 09-24-2013, 05:11 AM
Felonious_monk
I can't help with your question, but I have a brand new computer for sale. I'd let it go for $150.
88YJ
53CJ-3B
Felonious_monk is offline
post #10 of 10 Old 09-24-2013, 10:36 AM
Oldfrog
2007 WK
Whether or not the 5 volt supply is getting shut down or pulled to ground by another sensor in that circuit....such as a crank sensor.
If you are getting ...say....2 volts..( key on, but not started) ..then you would disconnect the crank sensor, then re-check the tps sensor plug ( wiring harness side) and if it went back to 5 volts, you would know that the crank sensor was pulling it to ground. In that case....you would replace the crank sensor.
But if the tps had 5 volts to begin with, then something else is causing the PCM to activate the ASD relay and shutting the engine down....such as a bad 12volt feed to the PCM or, as in my recent case, the pcm itself.
Oldfrog is offline
