-   -   Time for my thrid pcm? (http://www.jeepforum.com/forum/f13/time-my-thrid-pcm-1612361/)
cgcarpenter 09-22-2013 03:23 PM
Well this zj caught the electrical gremlin and it brought friends lol
It's continuously getting worse.
Stalling bucking hesitating misfire backfire. She decides she's a moody ***** lately. Whenever she wants. There's no tell on when it'll happen.
I've got codes:
P0108 map sensor voltage high
P0351 peak primary circuit current not achieved within maximum dwell time.
P0320 no crank at PCM during cranking(starts just fine)
And a cylinder 3 misfire code.
Where do I go from here. These sensors are all fine. Should I bite the bullet and buy a new PCM?
Oldfrog 09-22-2013 06:39 PM
It's not a Cardone is it?
If so, that's the PCM I just turned in, under warranty. They sold it to you...chuckle..:rtft:
Make sure you have NTK o2 sensors installed.
Next time it stalls, pull over, leave the key on and remove the TPS connector, check the voltage on the 2 outside wires. See if you get 5volts. Turn the key off, then put it back on.
I bet it has 5 volts and starts right up, too.
neonhomer 09-22-2013 07:52 PM
Do tell.... My 96 ZJ has a "die at random" issue... If you try to restart it without cycling the key, it won't refire. If you cycle the key off, wait a few seconds, and then try to start it, it will usually fire back up. I get the P0351 code - P0351 Ignition Coil A Primary/Secondary Circuit Malfunction.... I've replaced the coil, and the crank sensor was recently replaced with a Mopar sensor.
cgcarpenter 09-22-2013 08:09 PM
Originally Posted by Oldfrog
It's not a Cardone is it? If so, that's the PCM I just turned in, under warranty. They sold it to you...chuckle..:rtft: Make sure you have NTK o2 sensors installed. Next time it stalls, pull over, leave the key on and remove the TPS connector, check the voltage on the 2 outside wires. See if you get 5volts. Turn the key off, then put it back on. I bet it has 5 volts and starts right up, too.
Yeah I think it's a cardone one. But it's a year and a half old. I have smog soon so I'm ordering some from rock auto.
What would that test reveal?
Sounds like a fuel pressure problem
cgcarpenter 09-22-2013 11:52 PM
Disconnected my upstream O2 sensor and boom huge difference. Ran 95% better. Except for the cylinder 3 misfire.
Didn't get get a single hiccup all the way home from work or when I ran to the gas station.
Am I speaking too soon?
Probably but I'll see tomorrow morning when I drive to class.
Fingers crossed.
cgcarpenter 09-23-2013 03:45 PM
Ran great all morning.
Except for one complete shutoff in a McDonald's drive through. Lol
Ordering my O2 sensors and then I'll go from there.
cgcarpenter 09-24-2013 12:17 AM
Ran good all the way to work and all the way home.
Ordering new O2 sensors right now.
Felonious_monk 09-24-2013 05:11 AM
I can't help with your question, but I have a brand new computer for sale. I'd let it go for $150.
Oldfrog 09-24-2013 10:36 AM
Whether or not the 5 volt supply is getting shut down or pulled to ground by another sensor in that circuit....such as a crank sensor.
If you are getting ...say....2 volts..( key on, but not started) ..then you would disconnect the crank sensor, then re-check the tps sensor plug ( wiring harness side) and if it went back to 5 volts, you would know that the crank sensor was pulling it to ground. In that case....you would replace the crank sensor.
But if the tps had 5 volts to begin with, then something else is causing the PCM to activate the ASD relay and shutting the engine down....such as a bad 12volt feed to the PCM or, as in my recent case, the pcm itself.
The time now is 04:37 PM.
