Tie rod ends - JeepForum.com
post #1 of 10 Old 04-22-2005, 02:05 PM Thread Starter
theone13
Tie rod ends
I was under my Jeep today trying to see if my u joints are actually worm out, there wasn't any play in them when I tried to rotate them or lift the driveshaft, so all appears well there. However I still have a pop in my front end somewhere, so I was cheching everyting and found that I can twist my tie rod assembly but when I twist it back it makes a metal on metal sound, like a pop. Is a little bit of twisting normal in tie rod assemblies? So I'm hoping this is what my problem is. Anyway I think I need to replace the seals that hold the grease in the tie rod ends. It looks like I need to on the tie rod ends and where it meets the pitman arm. I did't find any info on this in my Haynes and I have no idea where I would buy something like that. This pop is driving me crazy, the sooner I can get it fixed the sooner my sanity can be restored, thanks everyone.
-Steve
'95 ZJ Laredo 4.0L 4x4 : Stolen
theone13 is offline
post #2 of 10 Old 04-22-2005, 03:47 PM
-Joe-
-Joe-'s Avatar
Posted this same question a few days back.. dont think i had any replies..
Come on guys.. Its not a lift or tire question but surely someone knows..
- Joe -
'95 Jeep Grand Cherokee Laredo I6 4.0L
242TC - Extreme Engineering 2" Front Lift/1.75" Rear Lift - ES9000 Shocks + JKS BPEs
Moog Cargo Control Springs
Magnaflow Converter - Dynomax Muffler
235/75/15 AT Uniroyal Liberator Tires
-Joe- is offline
post #3 of 10 Old 04-22-2005, 03:51 PM Thread Starter
theone13
Is yours making a popping noise while driving as well? Mine is really weird, sometimes it'll do it slowing down, other times not, sometimes when going over bumps sometimes not, so I really have no idea what's going on.
-Steve
theone13 is offline
post #4 of 10 Old 04-22-2005, 07:50 PM
RAZZMANIAC
RAZZMANIAC's Avatar
I have the same problem, lots of play in the tie rod and lots of clunking in the front, steering has too much play in it too. . . dont know if thats the cause of the clunking or the control arms. . . .but im gettin the tie rod ends replaced SOON. . .drives me nuts.
1997 Grand Cherokee 5.2L Tsi
RAZZMANIAC is offline
post #5 of 10 Old 04-22-2005, 09:30 PM Thread Starter
theone13
When you twist your tie rod around does it make a pop noise when you do it?
-Steve
theone13 is offline
post #6 of 10 Old 04-22-2005, 09:38 PM
RAZZMANIAC
RAZZMANIAC's Avatar
hits metal on metal very easily on both sides, depending on which way its twisted. . . and twists WAY too easy too.
post #7 of 10 Old 04-22-2005, 10:33 PM
jeepholic
jeepholic's Avatar
Tie rods are cheap.
Get the ones you need, get a tie rod puller( I use a bfh and they pop right out), MARK the exact location of the tie rod and remove it, screw the new one on to the mark you made and use an impact gun to put the tie rod back in place, if you do it by hand, make sure you use a breaker bar and the tie rod all the way in. Most take a castle nut and a cotter pin to secure them and if it's not in all the way, you will not be able to install the cotter pin(and the wheel may fall off while driving).
The clunking sound you hear sounds like the track bar thoe, get a 15mm and make sure it's REALLY tight.
I use a Jeep
You drive a car
Big difference.
94 I6 ZJ at 4", 33's and front locker and 4.11 gears. Swampy Bypass.
Black Jeep Club Member Ver. 2 #51
jeepholic is offline
post #8 of 10 Old 04-23-2005, 06:36 AM
RAZZMANIAC
RAZZMANIAC's Avatar
dont know about the other guys, but my track bar, sway bar and shocks etc have all been replaced. . . its either gotta be the tie rod or control arms on mine. . .
post #9 of 10 Old 04-23-2005, 06:15 PM Thread Starter
theone13
Yeah I just installed my lift last weekend, and everything was replaced. I'll try to tighten everything down again and see if anything is loose. Maybe it has to do with my axle u-joints? I was thinking it could be a torn cv or something, but then I looked and I don't have cv's so that can't be it. I might break down and take it in if I can't figure it out soon.
-Steve
theone13 is offline
post #10 of 10 Old 04-23-2005, 10:14 PM
greasefingers
greasefingers's Avatar
1994 ZJ
If the U-joints on the driveshafts clunk when the tranny is shifted from Park to drive, then that is a sign of worn out U-joints. I believe the sound you hear is something other than this. Non-adjusting-arm ball-joint pullers are great for tie-rod rod ends, but as jeepholic stated, hitting the knuckle, not the tie-rod end, with a small mallet; is faster. Where the drag link connects to the pitman-arm is a different story. I don’t like hitting that. I did however to remove mine. My puller had to be positioned in a difficult way, so I was not able to use it there. Check that the front shocks upper bolts are tight. I had slack in mine and it made a “bang” going over pot-holes.
Cheers Steve
94 Black Laredo 4-Liter with QuadraTrac (42RE trans & NP249 TC) 200,000 + miles purchased new
88 Cherokee 2-door with 5speed manual 139K miles(deceased) purchased new
greasefingers is offline
tie rod ends perfectcircle ZJ Grand Cherokee Forum 9 02-25-2010 04:47 PM
Tie Rod Ends???? aagill225 ZJ Grand Cherokee Forum 3 11-28-2008 11:32 PM
tie rod ends + Drag link ends....will this work?? -cAcHe- ZJ Grand Cherokee Forum 10 07-03-2008 03:52 PM
tie rod ends.. lakailimited06 ZJ Grand Cherokee Forum 4 10-14-2007 01:47 AM
And so it ends Marine_Mike ZJ Grand Cherokee Forum 18 09-30-2007 12:21 AM
