Ticking coming from front of 4.0. - JeepForum.com
post #1 of 18 Old 04-28-2013, 09:13 AM Thread Starter
Tuffyace
I have a 98 ZJ and I have a ticking sound coming from front of engine. The ticking sound started or became noticeable after I cleaned the throttle body and ran Seafoam internal engine cleaner through to remove the carbon. I have read a few post that say the change the oil and use Lucas or Mystery Oil along with a higher weight oil. Other posts say change the lifters and other items that would require to pull the head. The performance has not gone done and everything seems to work fine. Can anyone shed some light on this situation?
Tuffyace is offline
post #2 of 18 Old 04-29-2013, 07:24 AM
Derph
1994 ZJ
Here
Derph is offline
post #3 of 18 Old 04-29-2013, 07:32 AM
wj4play
It's going to explode ... Be prepared .. My ticking turned into cracked piston skirt which ate itself ... Two separate motors
rebuild now before it recycles itself...
Sent from iPhone
99 Grand, 37" and mostly factory - Raised tank and trimmed fenders etc
wj4play is offline
post #4 of 18 Old 04-29-2013, 08:46 AM
bigb229
x2 on piston skirt cracked.....I just rebuilt the 4.0 after discovering the #3 skirt was in the oil pan
bigb229 is offline
post #5 of 18 Old 04-29-2013, 01:06 PM
wj4play
First you think it's a lifter . Then u think its a pulley ticking . Then you use some fancy STP motor hunny . Then change the oil.... When it actually starts knocking you try to race it home so your not stranded ... Then BOOM
Sent from iPhone
wj4play is offline
post #6 of 18 Old 04-29-2013, 02:27 PM Thread Starter
Tuffyace
If I pull the head will i be able to see if the piston is damaged or the skirt is cracked or is that something you need to take the piston out to see.
Tuffyace is offline
post #7 of 18 Old 04-29-2013, 04:56 PM Thread Starter
Tuffyace
Thanks for all the advice but figured out what the issue was. The spark plug in cylinder 1 came loose once I tightened that back up it sound like the engine I come to love.
Tuffyace is offline
post #8 of 18 Old 04-29-2013, 05:24 PM
bigb229
Lucky fella.....might wanna play the lottery tonight.
bigb229 is offline
post #9 of 18 Old 04-29-2013, 05:34 PM Thread Starter
Tuffyace
Never good at the lottery but have been winning pretty good at the casino. Thanks again fir the support.
Tuffyace is offline
post #10 of 18 Old 04-29-2013, 06:39 PM
wj4play
Lol lucky dog.. How many miles on theclock?
Both motors of mine did it at 150k
I think the weak skirt is on the 99-04 motors never heard the older ones cracking
Sent from iPhone
wj4play is offline
post #11 of 18 Old 04-29-2013, 07:06 PM Thread Starter
Tuffyace
I have just over 150k. Its been a great engine. Really looking forward to having it for a while.
Tuffyace is offline
post #12 of 18 Old 05-07-2013, 01:06 AM
xrunndonex
1994 ZJ
My 94zj i6 has 218k so if you treat the motor good you should be fine
xrunndonex is offline
post #13 of 18 Old 05-07-2013, 01:10 AM
micellis
Just rolled over 220k myself, have a slight tick and the oil pressure switch stopped working. Good weekend ahead of me to fix it
Sent from my Galaxy Nexus using JeepForum
micellis is offline
post #14 of 18 Old 05-07-2013, 08:56 PM Thread Starter
Tuffyace
This is the only issues I've had with the motor in 9 years except for common wear items. They made a great motor when they designed the 4.0.
Tuffyace is offline
post #15 of 18 Old 05-07-2013, 09:21 PM
xrunndonex
1994 ZJ
I'm thinking about seafoaming mine but sorta scared. Always told most additives are bad and cause problems. seafoam is different though so unno
