Ticking coming from engine - JeepForum.com
post #1 of 6 Old 11-12-2013, 05:24 PM Thread Starter
KoltenZJ
So a quick background story: I was wheeling, flooded the engine, engine wouldn't start. Drained water, runs now just with a ticking coming from the engine. Thought it may be the lifters sticking due to water still in oil.
After getting ALL of the water out its still ticking. No bent valves/rods and nothing is cracked (that we can tell). Also while running after giving it gas the idle drops very low (100-200 RPM) and then goes back up. Any ideas? I've been without my ZJ for 3 weeks now. I'm having serious separation issues and need her back on the road asap! Thanks in advance!
*1997 Jeep Grand Cherokee Limited
3.5" Rough Counrty Lift, 265 75 r16 BF Goodrich All Terrain TA KO Tires
Check out my build thread!
KoltenZJ is offline
post #2 of 6 Old 11-12-2013, 05:35 PM
JasonStebbins
Did you try putting in new spark plugs?
Poop
JasonStebbins is offline
post #3 of 6 Old 11-12-2013, 05:48 PM Thread Starter
KoltenZJ
Could it really be as simple as that????
I did however replace the plugs/wires not too long ago. Could they still be a factor?
KoltenZJ is offline
post #4 of 6 Old 11-12-2013, 06:51 PM
JasonStebbins
I'm honestly not sure, but if it was my ZJ I would definitely do an ignition tune-up if I sucked in water to the point of stalling. Could be fouled plugs causing bad detonation. Is your exhaust manifold cracked? That could cause a ticking noise. Otherwise it's probably the common lifter tick.
Poop
post #5 of 6 Old 11-13-2013, 12:10 AM Thread Starter
KoltenZJ
No the manifold is all fine. I'll take a look at the lifters when I get a chance
KoltenZJ is offline
post #6 of 6 Old 11-13-2013, 03:08 PM
JasonStebbins
Don't get the evap solenoid click confused with an engine tick either. When I put the 5.9L vents on my hood, the sound is a lot more audible now.
Poop
engine , idle , low , ticking
