thumping sound and feel - JeepForum.com
post #1 of 4 Old 07-06-2001, 11:50 PM Thread Starter
ralph249
My 95 Grand Cherokee has developed a strange vibration. While driving on the Interstate or any other high everything is fine, however when I leave the Interstate and turn the front wheels approximately 10 degrees or more, something makes a thumping sound and seems to put the motor in a strain. When I straighten the wheels everything is OK, but if the wheels are turned in either directions the thumping starts. I have checked the CV joints and they are good. Outside of the vehicle I can not tell where the thumping is coming from and it is not easy to hear, but the thumping can be felt inside the vehicle, and seems to comefrom the rear part of the vehicle. The vehicle has to be driven at least 30 miles before this happens. Has this happened to others, if so what was the problem? Any ideas will be appreciated
ralph249 is offline
post #2 of 4 Old 07-07-2001, 06:14 PM
Kess
im no ase certified mech but my best guess on that would be powersteering, sys going bad or something along that line
In comission:2004 WJ, stock....
Retired:1994 JGC Laredo I6 4.0L, Smittybilt Outland brush guard, 1 3/4" Daystar coil spacers, custom air intake with tube K&N, Borla cat-back, KC Daylighters 6" 150w stainless steel, Xenon superwhite headlights 85/100w, 235/75/15 Pirelli Scorpian A/T, billit aluminum grill inserts
Kess is offline
post #3 of 4 Old 07-07-2001, 10:37 PM
taterjeep
I've got the same problem after highway driving. I was looking around the internet and on another forum, the consensus seems to be that it is the viscuous coupler going bad. It seems it has been a problem on the 93-98 Jeep Grand Cherokees. Several people reported the same problem. As I understand it, the VC has a bad seal problem and can leak Automatic Transmission fluid into the VC disrupting the fluid requirements for the VC. It works fine when the system is cool. But drive it on the highway and heat up the fluid, and you get the thumping that I get.
taterjeep is offline
post #4 of 4 Old 07-08-2001, 04:30 PM Thread Starter
ralph249
taterjeep,
This might well be my problem, it seem logical after looking at the Jeep transfer case diagrams. Have you corrected your problem? If so what is the solution? If not what do you plan to do? Do you have any idea how long it takes before the problem shows up driving on straight roads?
ralph249 is offline
"Thunking" sound/feel when stopping MizzouTiger WK Grand Cherokee & XK Commander Forum 27 02-15-2012 07:45 PM
Still have Thumping in rear of WJ ktplotts ZJ Grand Cherokee Forum 14 01-26-2010 07:45 AM
thumping noise 96 v8 GC roman177 ZJ Grand Cherokee Forum 13 05-25-2009 04:59 PM
What does pinging feel/sound like? Zoso ZJ Grand Cherokee Forum 9 08-29-2007 02:09 PM
Thumping sound from the rear ewtonyan WJ Grand Cherokee Forum 1 06-25-2003 05:52 PM
