Throttle Valve Cable Replacement (TV cable) - JeepForum.com
post #1 of 12 Old 03-24-2010, 09:35 AM Thread Starter
orchimaxi
So, today while adjusting my TV cable I managed to snap the plastic bit that connects to the throttle valve. Whoops. So, 80 dollars goes to the stealership for a new cable...
Anyway, the cable should be coming in tomorrow, and I've never replaced one of these. Anyone have any pointers for the best way to go about this?
For those looking to adjust your TV cable, here's a tip - unlike some of the other connectors that attach to the TV this one you pull towards the FRONT of the vehicle, not straight off
1999 XJ SE 5 spd 4.0 -- Dead
2001 TJ Sahara 5 spd 4.0 -- Sold
1995 ZJ 5.2L -- Sold
1997 TJ 4 cyl 5 spd - still figuring it out...
orchimaxi is offline
post #2 of 12 Old 03-24-2010, 10:30 AM
JrMechanic
It's fairly easy. There are clips attaching the cable to various things like the oil dipstick and transfer case vent tube. It connects to the transmission with a ball and socket type connector, then it un-clips from the bracket. When you route the new one, make sure the bends are smooth and not forced, and that it's not rubbing against anything moving or hot.
For initial adjustment, pull the white clip outward from the assembly, open the throttle to WOT, then push the clip back in.
Want to swap an NP242 or NP231 into your ZJ? Here's how:
JrMechanic is offline
post #3 of 12 Old 03-25-2010, 10:14 AM Thread Starter
orchimaxi
Thanks, suppose that's what I'll be doing this afternoon!
post #4 of 12 Old 09-06-2012, 08:57 AM
FLATFENDER54
FLATFENDER54's Avatar
Anybody ever fix one of these or know a cheaper place to get one? I did the exact same thing. Part number?
01 TJ Sahara 4"short arm/rear gas&tire
carrier bumper/front winch bumper winch/detroitEz
1954 WILLYS CJ3B (under construction)
FLATFENDER54 is offline
post #5 of 12 Old 09-06-2012, 09:01 AM
bananaslug
Mopar-wholesale.com has em for $45.
bananaslug is offline
post #6 of 12 Old 09-06-2012, 07:57 PM
stageninja
That Rigger Guy
stageninja's Avatar
I just swapped mine this week and the one bit of advice I would give is if you haven't yanked the first one out... Tape the new one to the old one so that as you pull old one the new one snakes into place. Tape it with a taper so it doesn't snag anything along the way. Also the new ones from the dealer have a different adjustment. You push the tab with arrows in with one hand and slide the cable jacket with the other.
Mine '97 White, ZJ Ltd, 5.2, Up-Country Suspension, Kolak ignition, Kolak/Magnaflow Exhaust
Her's '98 Chargold ZJ Ltd. 4.0 2wd
Our 1st '97 White, ZJ Ltd, 5.2, The parts Jeep for 5 years...R.I.P. Sent to Pic-A-Part 5/17/2013
stageninja is offline
post #7 of 12 Old 09-06-2012, 08:22 PM
KoreaZJ
1994 ZJ
Originally Posted by stageninja View Post
...Also the new ones from the dealer have a different adjustment. You push the tab with arrows in with one hand and slide the cable jacket with the other.
New... like this?
My '94 came from the factory with one of these!
Was it only on the V8's where they used the clip style?
KoreaZJ is offline
post #8 of 12 Old 09-07-2012, 10:47 AM
PolkaPower
Originally Posted by KoreaZJ View Post
New... like this?
My 1995 limited v8 had this push button style. My 5.9 has the clip.
PolkaPower is online now
post #9 of 12 Old 09-07-2012, 07:49 PM
MaintMech
Old and in the way
MaintMech's Avatar
'96, 4.0 has the pushbutton.
'96 Grand Laredo, 4.0, Stock, Daily Driver
I fought Oracle and Oracle won!
Originally Posted by coralman
If the faith isn't there,the doubt is.
MaintMech is offline
post #10 of 12 Old 03-05-2013, 07:48 PM
Swifty729
I just broke mine today, cant i just jerry rigg on a new plastic end clip? I figur id cut off the crimp holding the wire on and slide on a new on the recrimp it
Swifty729 is offline
post #11 of 12 Old 03-06-2013, 06:04 AM
KoreaZJ
1994 ZJ
Check this thread... Broken Plastic end on TV cable
KoreaZJ is offline
post #12 of 12 Old 03-27-2015, 06:58 PM
jrh00800
Try this!
Below is a link to a replacement clip that simply slides onto existing cable.
Works great on my 2002 Jeep Grand Cherokee 4.0L, took about 5 min to install if you include crushing the old one up to take it off.
Modeled after the original that broke on my jeep. Didn't want to install a new cable for something so small and seemingly easy to fix....
http://shpws.me/F0rh
For a shorter style for older jeeps? Try this clip http://shpws.me/H32m
Please let me know what ya think, how it works for you, or doesn't work right. Can be tweaked, just ask.
jrh00800 is offline
throttle valve cable , tv cable
throttle valve cable return spring (98 zj 4.0) kevin_saun ZJ Grand Cherokee Forum 3 04-30-2009 06:16 PM
Help please throttle valve cable Sal ZJ Grand Cherokee Forum 0 08-22-2008 12:27 AM
Throttle Valve (TV) Cable Help ojingalena ZJ Grand Cherokee Forum 3 02-14-2005 02:46 PM
Throttle Valve Cable adjustment automan25 ZJ Grand Cherokee Forum 8 01-29-2003 09:19 PM
throttle cable automan25 ZJ Grand Cherokee Forum 2 01-03-2003 10:04 PM
